03-31-2009, 08:04 PM | #26 |
Re: Need help with wiring stock temperature and vacuum gauges
Excellent! So the temp gauge does not have a wire going to the back of the gauge, instead the signal is sent though the printed circuit, correct?
Photo Gallery of 1972 K/5 Blazer CST |
03-31-2009, 08:06 PM | #27 | |
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" Last edited by msgross; 03-31-2009 at 08:06 PM. |
03-31-2009, 08:57 PM | #28 |
How does the vacuum hose attach to the vacuum gauge? I only have a gauge but don't know what type of hose to attach or how to attach the hose.
03-31-2009, 09:46 PM | #29 |
good question.. post some pics when you figure it out.. I have yet to mount mine as well... I'm think vacuum hose but not sure on the gauge connector...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" Last edited by msgross; 03-31-2009 at 09:47 PM. |
04-01-2009, 08:47 AM | #30 |
Just looked at mine, 1/8" copper tube and ferrule with the female locking nut. Just like your oil pressure gauge if you have a manual, comes off the block by the distributor and not electric
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 04-01-2009 at 08:50 AM. |
04-01-2009, 08:05 PM | #31 |
Not a bad nut after all..
IIRC the vacuum gauge fitting is larger (1/4"?) than the oil fitting (1/8"?).
'05 Chevy 2500HD 4x4 '72 GMC LWB 4x2 driver '72 Chevy LWB 4x4 plow truck '71 Blazer 4x4 driver '70 GMC LWB trailer |
04-02-2009, 05:37 AM | #32 |
I could be wrong, I'll go look again
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
04-02-2009, 05:39 AM | #33 |
vac gauge is just hooked up to the manifold vacuum source. May have to do some custom fitting.
04-02-2009, 07:04 AM | #34 |
Looks to me it is a 1/8" tube, but it could be a 1/4" ferrule. I could measure if needed
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 04-02-2009 at 07:05 AM. |
06-25-2009, 11:11 PM | #35 |
spirit rider66
Location: pahrump, nevada, in the bowels of the Mojave desert
OK guys it's my turn to ask for help, I'm sure there are a lot more younger guys than i am, that could help me out, my problem is my horn , everything else is OK, i went for a test run to check things out and i try to use my horn and nothing happened ,,i came back to the house and find out that the horn had been by passed, with a horn bottom,,why would any one do that and i have been trying to figure this out with out tearing the steering wheel apart ,, so give me some idea what i might have to do OK,,thanks ,,i hope i posted in the right area to ask for help ?
Larry
:Chevy: If you don't run your own life,, some one else will. to our vets,, welcome home,, and thank you for your service.:Chevy: Last edited by seldomseen65; 06-25-2009 at 11:13 PM. |
06-26-2009, 11:45 AM | #36 | |
I would repost this down on the Electrical section, or have a Mod. move it. Really smart guys down there and I'm sure one of them could help you out. I had a question for them and they even drew up a schematic for me to follow along I'm electrically challenged, so I can't help
06-26-2009, 05:51 PM | #37 | |
spirit rider66
:Chevy: If you don't run your own life,, some one else will. to our vets,, welcome home,, and thank you for your service.:Chevy: |
03-08-2010, 08:59 PM | #38 |
It's been a while but I finally got around to refurbishing my instrument cluster. Out is the hand throttle and aftermarket Sun Pro gauge. I installed a new bezel, lens, printed circuit, and tin along with the correct factory temp gauge with vacuum gauge. It looks awesome.
I was able to get the vacuum gauge to work by buying a brass adapter to attach a 1/4" barb to the back of the gauge. The adapter and 1/4" barb were threaded on with teflon tape. I used six feet of 1/4" vacuum line and ran it to a T that I installed about two inches from the vacuum line coming out of the rear of the intake manifold that leads to the AC canister. The gauge reads right down the center at "15" during idle and drops to "0" if I stab the throttle but bouces right back to "15". I guess that's what it should be doing? I found a few cut wires behind the block wile under the hood. One wire on the passenger side and another on the driver side. Not suprising to me, the volt meter and temp gauge do not work. I installed a new temp sensor. I think the cut green wire I found needs to be connected to the temp sensor and that will resolve my temp gauge issue. I'm not sure what I have to do to get the volt meter working. Any ideas? Thanks, John
03-08-2010, 11:46 PM | #39 |
GM - do you have any pix of the new setup with the hookups under the hood - I have a vacuum gauge that I want to get hooked up this year at some point.
03-09-2010, 12:16 AM | #40 | |
03-09-2010, 10:37 AM | #41 |
There should be a brown/white wire from the junction block on the passenger fender. The small wire from the positive battery cable hooks on it. I think the other wire (brown) comes off the voltage regulator. Both of these wires go through the firewall at the bulk head and go into the back of the guage cluster like the temp. I might have the colors backward, but you can look at the diagram for a start.
03-09-2010, 02:36 PM | #42 |
I'll see if I can get some pix.
Thanks for the tips. Jaros - If I can't get this corrected then can I stop by for some help? From your pictures, it looks like you have experience with wiring.
03-09-2010, 03:40 PM | #43 |
[QUOTE=Green Monster;3849901
Jaros - If I can't get this corrected then can I stop by for some help? From your pictures, it looks like you have experience with wiring.[/QUOTE] Sure anytime! But don't use that as a reason to visit...got my cell number? sposed to rain this weekend
03-09-2010, 03:45 PM | #44 |
Rain will stop me. GM is a fair weather vehicle only.
I don't have your cell number. Can you PM me with it?
03-09-2010, 04:47 PM | #45 |
I knew that that's why I posted it up, but maybe Sunday
03-09-2010, 09:58 PM | #46 |
I miss this truck.
Congrats, I bet it looks great.
'07 GMC Acadia SLT. Sweet ride. '08 Crew Cab Z-71 short bed. Really like this truck A LOT. |
03-09-2010, 10:02 PM | #47 |
03-10-2010, 09:55 AM | #48 |
I'll get pictures up soon. I have an under hood picture and dash picture to share.
03-23-2010, 04:57 PM | #49 |
Jim (aka Jaros44sr) was gracious enough to host myself at his home on Sunday morning to help me get the stock temperature gauge wired up and operating again. Jim knows his wiring and wasted no time finding chopped up wiring under my hood and quickly identifying where it belongs and what it was for. The previous owner installed a new motor and aftermarket SunPro temp. Gauge. Jim supplied the correct advice, wire, connector, heat shrink tubing and crimping tools to help me get the job done right. Jim is both patient and knowledgeable. Great guy and super nice. Jim has a neat project Jimzer with a 67 Chevy pickup front clip he is working on. It was great to look at his project with the oak bed and to share my 72 Blazer with someone that REALLY appreciates it. Thanks again Jim!
Attached are photos of the vacuum gauge set up as requested.
03-23-2010, 05:01 PM | #50 |
One more.
