Old 04-01-2009, 05:48 PM   #26
GRIMSS
GRIMSS's Avatar
Re: My long term 57 project
Here is a good site to post pics to and it will let your resize them.
http://photobucket.com/
2001 GMC SIERRA
1956 Chevy Panel Build Page with a Scott's Hotrods IFS
1953 Chevy trucks Project Dime Time
1968 Camaro
1968 Volksrod "NOBACK"
55-59 one piece window Video
55-59 one piece window template files
Jared
GRIMSS is offline   Reply With Quote
Old 04-02-2009, 01:25 AM   #27
nuke1
nuke1's Avatar
If you have windows xp, go to microsoft and download image resizer, it works great, that is what i do
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 04-02-2009, 11:00 AM   #28
discodadee
discodadee's Avatar
You can also re-size using MS Paint, it will be in your start menu under "Accessories". Once you have the pic pulled up in there you can go to "Image" and then "Stretch/Skew" to re-size. You can also check it to see if it small enough by clicking on "Attributes" which is also in the "Image" heading.
1957 GMC (mostly) on 1980 4wd chassis 350/th350 np203 w/part time conversion
discodadee is offline   Reply With Quote
Old 04-03-2009, 03:35 PM   #29
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Here's a try at posting using the MS Paint to resize.
ChuckDriver is offline   Reply With Quote
Old 04-03-2009, 03:46 PM   #30
ChuckDriver
The Van column was shortened by Mike Chesser when he installed the camaro clip. I reworked it by cutting the shaft and having my Dad machine it for the a DD coupler. I also put two bends in the shift arm to get the Kugel linkage arond the stock brake pedal. It all works great. The mount on the engine side of the firewall is from Juliano's. I welded a tab on the inside to sandwich it all together.
Old 04-10-2009, 10:36 PM   #31
ChuckDriver
There was very little rust in this truck when I bought it. The only spot was the cab corners and it's very small, just a few pencil eraser size holes in the outer panel. I saw an article were they removed the entire inner panel completly, so that's what I did. I made a pattern of the floor area and installed a panel to cover the hole, eliminating the cavity that always held water and dirt! All of the seams were sealed with sealer and painted with eastwood paint and dynamat on the inside and undercoating on the bottom. As far as the swiss cheese holes on the outer panel they were filled with JB Weld and smooth over. I didn't want cut out the corner until I'm ready for paint so its a temp repair, but it's hardly noticable.
Old 04-11-2009, 09:26 AM   #32
renegade6
I like the idea of getting rid of the inner cab corner panel. Do you remember where the original article was?
Brandon
63 Biscayne https://www.pro-touring.com/threads/90718-63-Biscayne
57 Chevy Truck (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=321380
72 K20 Long bed stepside (wife's)
72 K20 Long bed 396 (flip or keep...?)
The latest build: http://67-72chevytrucks.com/vboard/s...76#post8438476
renegade6 is offline   Reply With Quote
Old 04-11-2009, 04:05 PM   #33
ChuckDriver
No, sorry I don't. It was either in Truckin or Clsaaic Truck several years ago. But if you take your time you can do it. It's a lot of work to get it out with out removing the outer corner!!! I may still have the pattern that I used to make the filler panel.
Old 04-11-2009, 10:13 PM   #34
hotrodsbyray
The Brothers truck parts web site has a series of tech articles - in the article on replacing cab corners they left off the inner corners
hotrodsbyray is offline   Reply With Quote
Old 04-12-2009, 12:54 AM   #35
ChuckDriver
Yep! That's the one I got the idea from. Here's the link:http://www.brotherstrucks.com/techar...20INSTALLATION
Old 04-12-2009, 08:38 AM   #36
renegade6
Thanks. Exactly what I needed.
Brandon
Old 04-16-2009, 09:04 AM   #37
ChuckDriver
I wanted to get the gas tank out of the cab for safety reasons and to eliminate the smell . So I got a universal tank from Tanks and had it powder coated chrome. It comes with the straps, pickup-up tube, cap and a nice trim ring to fit into the bed wood. I did have to fab the upper pieces running across the top of the tank between to frame crossmembers. This gives the straps something to pull up against and insured that the bed cross sills would stiil work without any mods.
http://www.tanksinc.com/index.cfm
Old 04-16-2009, 12:18 PM   #38
mylow53
mylow53's Avatar
nice tank i like how the filler hole is in the back mine is more forward. how many gallons does it hold?
GT
Greg
1953 chevy 1/2 ton 5 window, chevy 350 330 horse 700r tranz, lowering spindels mustang 2 frount. ford 9", airbags on 4 corners . purchased in 1983 for $325 while in high school
http://67-72chevytrucks.com/vboard/s...=215079&page=5
mylow53 is offline   Reply With Quote
Old 04-16-2009, 01:44 PM   #39
ChuckDriver
I believe is 15 gallons.
Old 04-21-2009, 03:52 PM   #40
ChuckDriver
Here are e few pics of the exhaust. I bought some 2 1/2 in. mandrel bends from JC Whitney and Flowmaster Super 40's from summit. Using the bends and straight pipes I layed out the system tucked as close to the frame as I could get it. I also wanted to get the mufflers out from under the cab for heat and noise. This is my first try at making my own and I must say it wasn't that hard. Once I figured were everything should be I just started cutting and welding. I did tack it togehter first just to be sure I liked how it looked. My plan is to run it out the back, but I think I'll have to go under the rearend. The pipes I painted with a high temp silver and the mufflers I just touched up the existing black.
Old 04-22-2009, 12:08 AM   #41
Kim57
Kim57's Avatar
Looking good.
Kim
Kim57 is offline   Reply With Quote
Old 04-24-2009, 07:11 PM   #42
Kabwe
Certified Car Nut
Kabwe's Avatar
Nice tank, how many gallons is it?
Kabwe is offline   Reply With Quote
Old 04-24-2009, 08:28 PM   #43
ChuckDriver
I'd have to measure it for sure, but I believe it's 15 or 16 gallons.
http://http://www.tanksinc.com/index...rod/prd173.htm
The link is to the company I bought it from in '99. I looks like the design has changed slightly. It shows it as 16 gls.
Old 04-24-2009, 09:10 PM   #44
ChuckDriver
Link corrected!
http://www.tanksinc.com/index.cfm/pa...rod/prd173.htm
Old 05-19-2009, 07:00 PM   #45
ChuckDriver
Here's a teaser shot of what I've been working on lately!
Old 05-19-2009, 09:58 PM   #46
ezekiel
That looks suspiciously like a 57 Chevy car dashboard.
How does it fit? Like a glove or "some assembly required"?
ezekiel is offline   Reply With Quote
Old 05-19-2009, 10:15 PM   #47
nickp51chevy
Registered Chevy Owner
nickp51chevy's Avatar
I like what you've got going on! Keep up the great work.
Love is fleeting, but Chevy trucks are forever!!!!
1970 Chevy CST C10 long box 350/400
2008 Chevy Silverado short box 4x4
Had;
1951 Chevy short box 307/T5
1988 Chevy shot box 4x4 350/350
1971 Chevy C10 long box 4x4 350/350
1971 Chevy C20 long box 350/350
1971 Chevy C10 long box 350/350
nickp51chevy is offline   Reply With Quote
Old 05-21-2009, 02:02 PM   #48
ChuckDriver
Actually it's from a '59 and yes "some assembly required"!!
Thanks it's been a lot of work and fun! My 3 year old son loves it!!
Old 05-21-2009, 02:26 PM   #49
Bigblue29
Thanks 'til you're better paid
Bigblue29's Avatar
schwinggg! Sweet.
-Luke
1950 Chevy AD 3100 pickup
2000 GMC Sierra
1970 Jeepster Commando
Bigblue29 is offline   Reply With Quote
Old 05-21-2009, 03:01 PM   #50
Kabwe
Certified Car Nut
Kabwe's Avatar
The dash will look good in there, seen it done before. I put a 55 belaire dash in mine. And yes some assembly is required, but thats what makes this stuff fun right? Good luck with your build and keep up the good work.
