Old 04-19-2009, 12:44 AM   #26
spinning wheels
spinning wheels's Avatar
Re: This sounds crazy. Anyone know?
Originally Posted by El Jay View Post
In the olden daze, the water injectors were used to help control detonation on cars & trucks that were working real hard, like pulling a trailer, etc.
It was an after market "sprayer" that had a nozzle going through the top on the air cleaner.
If the engine started to detonate, the driver turned on the water & let it spray into the carburetor.
A lot of folks made their own using windshield wash pumps instead of paying premium $'s for an aftermarket kit.
June 2009 issue of Hot Rod magazine, has an article on water injection.
'72 GMC custom camper 350/350
spinning wheels is offline   Reply With Quote
Old 04-19-2009, 01:08 AM   #27
mosesburb
I had a V-8
mosesburb's Avatar
I have used the water down the carb for years. It works great.
My Grandma had a '79 Z28 that was not stock and she drove it, well, like a grandma. She'd roll in every four to six weeks with it running on three or four cylinders. I'd put a couple soda cans worth of wather through it (birds would fall out of the sky during the procedure), beat it around the block a couple times and give it back to her running tip-top, smooth as silk.
Water works great provided you give it to it in digestable amounts.
1972 K20 Suburban, 5.9L Cummins, Banks Power Pack, NV4500HD, NP205, H.A.D., D60/14FF ARB Link To Build: HERE.
mosesburb is offline   Reply With Quote
Old 04-19-2009, 01:16 AM   #28
crazy longhorn
Fabricate till you "puke"
Originally Posted by mycool72 View Post
I just poured a bud light down my carb, now the damn thing pulls to the right
Swerves for every bar?
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 04-19-2009, 01:21 AM   #29
El Jay
Gone to greener pastures
I've used ATF to free up sticky lifters.
Having said that, the car/truck never left my driveway. I just let it sit there & idle, sometimes fast idle, for a 1/2 hour, or more.
After that, it was an immediate oil & filter change.
'69 Chevy 1/2 T LWB Stepper: Daily Beater
'72 GMC 3/4 T Fleet: Another Daily Beater
'72 Plymouth Gran Coupe: ?
"Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche
"Never kick a fresh turd on a hot day." Harry S. Truman
GUN CONTROL: Never having to say, "I missed you."
Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck
El Jay is offline   Reply With Quote
Old 04-19-2009, 01:28 AM   #30
Musclerodz
I have used a quart of ATF in the oil mulitple times on high mileage engines. It is a very high detergent fluid and will loosen carbon build up and stuck rings. Marvel mystery oil works good as well but more expensive.
Mike Redpath
Musclerodz is offline   Reply With Quote
Old 04-19-2009, 03:07 AM   #31
Camper Power
Camper Power's Avatar
iv heard of pouring atf into the tank but not into the carb or the crankcase, maybe il try the crankcase to clean up some of the sludge.
eh
1970 Chevy C20 daily driver
1975 GMC Jimmy 4x4 project
1966 GMC C10 Dad's project
Camper Power is offline   Reply With Quote
Old 04-19-2009, 07:07 AM   #32
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
GM sells a specific product called Upper Engine cleaner specifically for this purpose.
I have used it many times and it works. You meter it into the carburetor or throttle body like everyone here is saying, then when you get to the end of the can, you allow the engine to die and leave it soaking for awhile.
After a few hours, you restart the engine and drive it hard for a mile or two. It will blow out a lot of smoke and carbon deposits, often curing pinging issues and other problems associated with carbon deposits.
Old 04-19-2009, 11:37 AM   #33
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
This has nothing to do with this discussion, we are talking about pouring it into the carb, where it goes into the combustion chaimber and burns, then goes out the tail pipe.
What you are quoting, is pouring it in the oil, where it goes into the luberication system and then drained out the oil pan.
Your info is quite good, and something I'd like to see a link on or something, as I happen to agree with, these oil chainge places should be fined for false advertising for doing this.
You have great info, just not exactly the convorsation going on here.
Originally Posted by spinning wheels View Post
There was recently a report on tv about the internal engine cleaning some shops are pushing on their customer. They had a lubrication engineer explaining what the shops were trying to sell. He highly recommended staying away from the internal cleaning devises. He stated that they do more harm than good to an engine. He was referring to a newer fuel injected engine, not sure how he would feel about an older carb motor. As for cleaning the lubricated parts, he recommended adding a quart of ATF, when you are going to do an oil change. Warm up the engine to operating temp. Then draining the oil/ATF. He stated that the ATF is more of a solvent than a lubricant, and would help remove built up sludge deposits in the motor. Just thought I would pass this info on.
Old 04-20-2009, 12:33 AM   #34
Pont406
I use seafoam at every other oil change. It smokes a little but not too bad.
Pont406 is offline   Reply With Quote
Old 04-20-2009, 12:41 AM   #35
El Jay
Sea Foam and Deep Creep are my friends.
Old 04-20-2009, 01:10 AM   #36
spinning wheels
Post #1 reads, that, "he was advised by a guy at a shop", on how to clean the inside of an engine. Does not specify if its the combustion chamber or entire engine including the lubrication system. I passed info concerning cleaning both combustion chamber and the lubrication system. I am not a lubrication engineer, so I found the info very interesting. I found it very interested when he said to add a quart of ATF into the engine before doing an oil change. I had never heard anybody recommend this procedure before. But he strongly advised to stay away from cleaning solutions going into the intake of the motor. I have never heard of adding ATF thru the carb to clean an engine, so I would think we are discussing the same thing. Cleaning the inside of an engine. Right?
Old 04-20-2009, 01:23 AM   #37
WorkinLonghorn
WorkinLonghorn's Avatar
They stopped selling that product in Calif. about 4 years ago,(check your local chevy dealer) but it did work.
Note; If your engine is in good shape you probably don't need to "clean" it.
I used to use the above stuff on an old worn out engine that smoked and leaked oil past the valve seals and after a few thousand miles it would start knocking from all the carbon in the heads. After "cleaning" the knock was gone.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent.
WorkinLonghorn is offline   Reply With Quote
Old 04-20-2009, 01:30 AM   #38
easydoesit
when i use to work at a wrecking yard a few years back, we would add a bit of AFT to sour running engines to boost compression. some of the engines would run better and the compression would go up as well. i would do it on an old carb engine in my rig if it seemed to need it.
easydoesit is offline   Reply With Quote
Old 05-09-2009, 10:32 PM   #39
57ExtCab
I got a good friend thats a Mech. at a Mercides Dealership seen him, more than once (pour) sowly or metering like put ATF in newer gas Mercides , Manually working throttle and choke. And yes it fog like a MOFO for a bit, thought he was crazy but he just looked at me and grin saying thats the easist $75 dollar side job that he knows of. He's Going on his 25+ years at same dealarship.
Then again the Wife could be RIGHT
"Just cause I Drink alot of Bud that does'nt make me WISER"
57ExtCab is offline   Reply With Quote
Old 05-10-2009, 11:00 AM   #40
piecesparts
Parts and more parts
piecesparts's Avatar
We used to do "Liquid Vale Jobs" at the shop that I worked at years ago. It works to take the carbon off of the engine's valves and piston tops. The process works if you don't do it to fast.
piecesparts is offline   Reply With Quote
Old 05-10-2009, 11:00 AM   #41
piecesparts
We used to do "Liquid Valve Jobs" at the shop that I worked at years ago. It works to take the carbon off of the engine's valves and piston tops. The process works if you don't do it to fast.
Old 05-10-2009, 11:30 AM   #42
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
I worked at an ESSO station in the mid-60's. We sold several different liquids that were sometimes poured in the carb and/or poured in the gas tank. Wynns made an upper cylinder lube. Bardahl was another additive. We sold/installed water injection units (owner/boss was money hungry). At Sears automotive center where I worked in the mid-70's, all kinds of stuff got poured in the carbs to cut the carbon from the combustion chambers. Seems Sears sold a can of "Combustion Chamber Cleaner" under their brand name. I don't know who made it, but you know it had to have come from some where else. My dad swore by Risolone. We had bought a '67 Cougar new in Dec. '66. By the time both of my brothers and two of my sisters had learned to drive, it was getting a bit sluggish. A mechanic turned dad on to the idea of pouring the Risolone down the carb (half a can) and the other half in the gas tank. He credited that process with being able to add another 40K miles to it. When I got it back in '74, it had about 130K miles on it. Within another 10K miles, it was torn down for a possible rebuild. The mechanic said he had never seen an engine that was so completely worn out. I guess the Risolone distributed the wear more evenly......
There was an earlier comment about hydraulic lock and the statement about liquids not compressing. That is the principle of hydraulics....that a liquid can not be compressed. So, be careful how you pour anything down the carb. Don't flood it with liquids of any type. The "fogging" method is right.
Member Nr. 2770
Old 05-10-2009, 01:15 PM   #43
71/454
Turbo Guy
71/454's Avatar
I have heard about the atf and water thing, and have personally done the atf and it works well. I learned it prob like the rest of you from the guys I grew up with. They also talked about water too, but they said not to do it. They said it works too well, as in it will take a big chunk of carbon and free it up but it will get stuck in the valve because the steam makes it come off so well. I was told the atf works a little slower and won't cause a burnt valve.
I won't use atf on anything with an o2 sensor because it may damage it. On those vehicles I use seafoam or the Gm stuff that was mentioned earlier. I'm not sure if either was better than the other.
1972 Gmc Custom swb intercooled twin turbo 327 10.5-1 and 12 lbs of boost, Nodular iron case super t-10 4 speed with a blowproof bellhousing, 12 bolt eaton posi soon to have moser axles.
1998 Honda CR250 fully ported, case matched, milled head, vortexed carb and revalved suspension but don't forget the woody woodpecker decal kit!
Things I've broken so far:
12 bolt diff
saginaw 4 spd many, many pieces
Aluminum case Super t-10 4 spd
71/454 is offline   Reply With Quote
