Old 05-08-2009, 01:18 PM   #26
my67chevytruck
Under Construction
my67chevytruck's Avatar
Re: project BIG RED (gen3 on air)
Don is the man!! he has incredible hulk and big red going on right now that i know of.... great work and progress as usual don. I will probably be contacting you in the future...... wiring and i dont get along
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 05-08-2009, 10:58 PM   #27
nuke1
nuke1's Avatar
You know, it is not fair that you get to have so many projects at once, especially with a nice sized garage like that, you and Matt (spraybomb) hmmmmmm,
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 05-08-2009, 11:09 PM   #28
68 short step
come on now, i actually finish my projects tho
68 short step is offline   Reply With Quote
Old 05-10-2009, 02:21 AM   #29
nuke1
nuke1's Avatar
LOL so true, sorry matt.
James
1968 GMC "HAVOC"
1986 GMC "Frank"
Old 05-23-2009, 03:36 PM   #30
68 short step
after i got it all tore down, i put the rear end and trailing arms back in, so i could do a mild c-notch..then i modified the frame to accept the bags..afther that i modified the front arms to accept the bags, the front steering stops will be added later (ill have to make some diffrent ones).....and finally i put the engine and trans in, in preporation to make it a roller again (on 22/20 combo)
Old 05-23-2009, 03:47 PM   #31
killer71
killer71's Avatar
where'd ya get the tires/wheels?
R.I.P.
Killer 71
10/26/07
killer71 is offline   Reply With Quote
Old 05-23-2009, 04:40 PM   #32
Hart_Rod
Hart_Rod's Avatar
What he said....... I think you have ADD worse than me, (68SS)........
Hart_Rod is offline   Reply With Quote
Old 05-23-2009, 05:14 PM   #33
68 short step
coys wheels......
Old 05-23-2009, 05:59 PM   #34
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Nice! Hoping to learn from your LS installs!
ChuckDriver is offline   Reply With Quote
Old 05-23-2009, 10:43 PM   #35
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Looking great.
--Josh
Old 05-24-2009, 10:45 PM   #36
MrBeast
high-Tech Red Neck
MrBeast's Avatar
Nice to see another short bed being built to be a DD instead of a show pony, these trucks were way too awesome to be trailer queens.
"He used to be a pretty nice feller, now he's a welder!"
MrBeast is offline   Reply With Quote
Old 05-29-2009, 11:43 PM   #37
68 short step
ok here is a little update,i had to put the bad back on, so i could mount the airtank and compressor, then took the bed back off after everything was mocked-up...also mounted and plumbed the tranny cooler.. got the wheels /tires put on..... put the headers on, welded the v-band clamps on for the collector, and cut the holes in the crossmember for the exhaust to go through....finally, i got my valves mounted, just behind the rear axle.....
Old 05-30-2009, 12:13 AM   #38
my67chevytruck
Under Construction
Nice Progress...
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 06-01-2009, 12:23 AM   #39
little nick D
keep up work the work man looks good!!!
little nick D is offline   Reply With Quote
Old 06-01-2009, 01:05 AM   #40
Hoffman65burb
Hoffman65burb's Avatar
Looks great, how much did those coys run you if you dont mind me asking?
1978 GMC Jimmy
454bbc
Turbo400
NP205
3.73 gears
4inch lift
33's
Hoffman65burb is offline   Reply With Quote
Old 06-01-2009, 06:00 PM   #41
68 short step
bout 2g
Old 06-01-2009, 06:15 PM   #42
68fixeruper
68fixeruper's Avatar
2g just for wheels? or with tires?
68fixeruper is offline   Reply With Quote
Old 06-01-2009, 06:24 PM   #43
68 short step
that was wheels, tires, lugnuts, mounted/balanced, and shipped
Old 06-01-2009, 06:50 PM   #44
68fixeruper
did u order them straight from coys? anyways love your work and your builds cant wait for you to do my truck
Old 06-01-2009, 10:35 PM   #45
68 short step
yes i called coys wheels directly, and i talked to dave (david).....they are the gunmetal with the polished lip.....the chrome ones are a bit more $$, but for this project i didnt want chrome......
Old 06-02-2009, 01:54 PM   #46
greystoke
that's looking great man, what size tires are you running? Do you like the Goodyears? or were they just the least expensive at the time?
greystoke is offline   Reply With Quote
Old 06-02-2009, 07:28 PM   #47
au03z71
au03z71's Avatar
What size wheels are those? They are the exact ones that I'm thinking about getting...
au03z71 is offline   Reply With Quote
Old 06-05-2009, 07:51 AM   #48
my67chevytruck
Under Construction
Don, states this in post # 30....
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 06-05-2009, 02:31 PM   #49
Number98
Prestige Worldwide
Number98's Avatar
Looking good man! I will have to keep an eye on this project...
Number98 is offline   Reply With Quote
Old 06-14-2009, 09:54 AM   #50
68 short step
a little progress to report, started smoothing the firewall.....and only found a little rust over the blower motor hole (easy fix), but other then that it was very clean and solid....
cut original heater holes out, made my templets, transfered to 16ga. sheetmetal, cut/fit, then weld and grind....
