Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 02-24-2010, 01:32 PM   #26
71chevytruckguy
71chevytruckguy's Avatar
Re: pro gears in truck rear
Those are the right bearings. Got everthing set up last nite. If i can get the trans re-built and someother things, headin to the track sat. Thanks yall, Chris.
its a work in progess.
71 c-10 lwb, in the middle of frame off restoration.
69 c-10 swb, drag truck, 406 sbc, balanced, comp 292 cam, ported, polished, gasket matched, and bowl blended pro comp 210cc heads, 2.02/1.60 ferrea valves,1.6 roller rockers, re curved hei with msd 6al box, 2-step rev limter, accel 300+ wires, ported victor jr intake, holley 750 double pumper carb, dynomax 1 5/8 headers, 4 spd munci m-20 with super case and iron midplate, mr. gasket vertigate shifter, 5.38 pro gears with full spool, 33 spline moser axles and c-clip elimators, line-loc, 5 gal fuel cell, holley blue pump.
7.807 @ 88.37mph 1.60 60FT
80 g-20 van, tow rig, cammed 305, th350, 10 bolt
88 jeep wrangler, dd, 258, ax-15 swap, 4.5" lift, 33x12.50's, lockers, 3.55's
71chevytruckguy is offline   Reply With Quote
Old 02-24-2010, 02:33 PM   #27
Alex1
Alex1's Avatar
Can the housing be machined for the larger input shaft (car 12 bolt)?
Alex1 is offline   Reply With Quote
Old 02-25-2010, 01:13 AM   #28
Captainfab
60-66 Nut
So I assume that the Timken #26882 and # 26823 are the correct bearing and race for installing the passenger gears into a truck housing?
Last edited by Captainfab; 02-26-2010 at 01:20 AM. Reason: corrected bearing number
Old 02-25-2010, 03:18 AM   #29
71chevytruckguy
Originally Posted by Captainfab View Post
So I assume that the Timken #26882 and # 26923 are the correct bearing and race for installing the passenger gears into a truck housing?
Yes they are. The only other things you'll need are a crush sleeve and pinion shims for a car 12 bolt. Chris.
Old 02-26-2010, 01:23 AM   #30
Captainfab
60-66 Nut
Thanks for confirming that. Let us know how she runs at the track.
For those reading this, I originally copied the wrong bearing number in my post. I have corrected it.
Old 02-26-2010, 10:41 AM   #31
Pyrotechnic
Pyrotechnic's Avatar
How do the carrier splits work with this, for example if you have a 3 or 4 series truck 12 carrier, what car gears will fit on each one ?
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 02-27-2010, 03:47 AM   #32
71chevytruckguy
That i cant tell ya. I know I have 5.38 pro gears for a 12 bolt car 4 series, with a 4 series truck spool. IMHO, if you don't want pro gears or a ratio above 5.38, I'd stick with truck gears. Chris.
Old 10-10-2012, 06:16 AM   #33
justahoby
old thread making reference!
justahoby is offline   Reply With Quote
Old 02-05-2013, 10:40 AM   #34
Benlugchev
Benlugchev's Avatar
Originally Posted by fast_dev View Post
super 73, i gotta weight it again at the track, i weighed it once at a local truck scale and it said 3300#, don't know if its really that light.
71. don't worry, no copies here i put this one together about 6 years ago. also glad to see someone else who isn't afraid to go old school with a 4 speed. launches nice around 4-4500 supercase is very nice, mine is all autogear on the outside and all internals are from a place called four gear trans. he doesn't think the maserio gears were strong enough so he made his own that are stronger and relieved for better oiling and some other tricks. he says it will take 750 hp. super nice guy to deal with too.
Im thinking about ordering the street/Race Muncie M22W from four gear trans? His price seems cheaper than a normal AG M22W. Any suggestions if his gears are really better than the Italian gears? Would you recommend buying another M22 from him? Mine will be going in a street/strip turbo charged LSX C-10
71' Chevy C10-Turbo 6.0L-80e-JFR218-738hp/700tq-10.1@133mph... 1.54 60' (3737lbs)
00' GMC-c2500-Turbo 6.0L-80e-JFR212-500hp/560tq -11.67@116mph (5182lbs)
Benlugchev is offline   Reply With Quote
Old 02-14-2013, 11:19 PM   #35
fast_dev
fast_dev's Avatar
don't know if his are any stronger, but i can say i've been 11.80's, pulled the front wheels, and flat shift it all the time, so far so good, and he is a great guy to deal with, super nice, and highly recomended.
68 chevy 406 small block, budget drag racer, new best e.t 11.91 @112
67 nova numbers matching 327 4 speed 13.6 @ 102mph
70 longhorn c-30 402/4 speed
70 c-10 swb 402, muncie 4 speed
94 s-10 350/th350 3:73 posi
71 c-20 402/th400 towrig for racetruck.
72 4wd lifted on 35's
72 350/3 speed winter beater
fast_dev is offline   Reply With Quote
Old 08-26-2013, 06:39 PM   #36
1968k1500
1968k1500's Avatar
This is my first post in a forum, I can see this is an older thread, I'm just hoping I can get some helpful advice!
*This topic, swapping "car for truck gears, and vice versa" always seems to bring a lot of "grey area" when it comes to definitive knowledge as to what EXACTLY needs to be done in order to be done correctly. For years I've heard it could be done, however, there just never seems to be a clear answer.*
*In this case, putting 12 bolt CAR gears, into a TRUCK housing.
* What, EXACTLY, does this entail?*
*What I understand so far,
1. You've cleared up the pinion bearing diameter issue, (thanks!)*
2. The carriers, Casting-wise, are basically the same, just machined differently to accept the different series gears e.g. 2, 3, 4, car*or 2, 3, 4 truck.
Q:
Did you have to machine your carrier?*
*If so, which carrier did you start with and what machining was done?*
*If not, which one are you using?*
Let us in on it!
It'd be GREAT to have a wider selection of gear ratio's available to choose from!
*Thanks.
1968k1500 is offline   Reply With Quote
Old 08-27-2013, 01:39 PM   #37
fast_dev
fast_dev's Avatar
wow, old thread, but still glad it can be help to anyone who needs it. I just happened to be on here again, haven't frequented this site much anymore, I got into dirt track racing and that has put the drag racing and trucks on the back burner. anyway.....the bearing is br26823 and br26882 just as chris said earlier in the post, I actually found my receipt and those are the ones I used. as far as the carrier, I have a moser spool in my truck for a truck. so I can't confirm what carrier, but if you look on mosers site I believe the car and truck spool are the same part, so I would say the stock truck carrier will work. thanks, Devin
