Old 09-01-2009, 09:06 PM   #26
JoeKan
JoeKan's Avatar
Re: Got a new Burb, need some info...
That's awesome! But how do you run the vents to the back? And where do you get this at? Thanks.
JoeKan is offline   Reply With Quote
Old 09-01-2009, 10:02 PM   #27
decodan
C-20 Long Stroker
decodan's Avatar
Hey,
I do not have any seats in mine other than two front buckets. I use it to haul stuff. That is what we were discussing earlier. What kind of rear unit to put in. You can tee into the lines and add another evaporator in the back somewhere. I do not know of any after market rear units.
Go online and search Vintage Air and then you can find who is your local dealer.
Dan
"A Hand Shake Is Your Word."
Decodan
1951 Chevrolet Suburban
1952 GMC Suburban
1963 Mercury Comet 2-dr (Sorry, I know)
1963 Mercury Comet 2-dr Parts Car, (better than what I originally started with)
2010 F-150 4WD
2015 Subaru Outback (what the hey, got to have one that is not a gas hog)
decodan is offline   Reply With Quote
Old 09-10-2009, 03:54 PM   #28
Muleman100
Muleman100's Avatar
What are your plans for the ceiling headliner? If you replace with the original cardboard, where do you get it?
Muleman100 is offline   Reply With Quote
Old 09-10-2009, 07:01 PM   #29
decodan
C-20 Long Stroker
decodan's Avatar
Hey MM100,
I was thinking of going to a headliner shop and having a cloth liner put in. If not that, I'll probably get sheets of ABS plastic and cover them instead of cardboard.
If anyone else has ideas on headliners let me know.
Thanks, Dan
Decodan
1952 GMC Suburban
2010 F-150 4WD
Old 10-26-2009, 03:23 PM   #30
decodan
C-20 Long Stroker
decodan's Avatar
Hey,
Latest update to Burb. I put in a small cap HEI, new wires and plugs. Put on a rebuilt Q-Jet carb.
I put heavy rubber matting in the rear so things don't go sliding around. The kind you stand on in a restaurant kitchen.
Working on getting the disc brake front end ready to swap.
More pics coming in a few days.
Dan
Decodan
1952 GMC Suburban
2010 F-150 4WD
Old 10-30-2009, 10:38 AM   #31
Rokcrln
Rokcrln's Avatar
Originally Posted by decodan View Post
Hey MM100,
Thanks, Dan
Dan your burb is coming right along. For a headliner in my 72 Tahoe I am planning on doing a fiberglass unit. My plan is to get the roof body work 100% and then spray a mold release agent on it before laying out the cloth and resin. Then after I do a few tight thin layers let it dry and trim it down to fit the inside then have it covered in material. I have done this for early rods and it should work out well for a burb also but it will be a big piece.
Check out this post to see what I am talking about, not mine but same concept.
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 11-02-2009, 04:57 PM   #32
scottydawg
Dan,
Very cool, what are the seats from, look like a GMT800 suburban/Tahoe? How did they mount up and did you wire in the electrics too?
scottydawg is offline   Reply With Quote
Old 11-02-2009, 06:21 PM   #33
decodan
C-20 Long Stroker
decodan's Avatar
Hey Rokcrln,
Thanks for the input on the headliner. I was thinking maybe some ABS sheet plastic could be used and covered also.
Dan
Decodan
1952 GMC Suburban
2010 F-150 4WD
Old 11-02-2009, 06:28 PM   #34
decodan
C-20 Long Stroker
decodan's Avatar
Hey Scottydawg,
The seats are out of a 1999 Chevy extended cab. I found that you just have to have the two orange wires and the black ground. Then all the seat adjustments and the heat will work. I am putting the heat on fused switch/relays so the wiring is protected.
As for the fit, all I had to do was use a 1"x2" square tubing to shim up the back two mounts to make the seat sit right. The height and the adjustments all work within range great. I even had room for the console but had to do away with the console mounting bracket. I just made a couple of angle mounts for that.
Thanks, Dan
Decodan
1952 GMC Suburban
2010 F-150 4WD
Old 11-02-2009, 06:55 PM   #35
scottydawg
Hey Scottydawg,
Thanks, Dan
Dan, that is sweet, I would love to see more pics of your burb. If you have a chance, please post them, I'm sure I'm not the only one. Also want to see your headliner project when you do it, it might be worth it to do a couple of overlapping sections, that's a lot of square footage to try all at once without breaking the mold.
Old 11-23-2009, 01:04 PM   #36
decodan
C-20 Long Stroker
decodan's Avatar
Hey,
Just wanted to let everyone know how much I appreciate this board and the people you meet here.
I bought a second row seat from Dullyjams, he was making a trip to Kansas City from Annapolis and offered to bring the seat with him. We worked out a meeting place and you would not believe that we both arrived at the meet within a minute of each other. It was 12 hours on the road for him and 2 1/2 for me.
Anyway, I want to say thank you to James for the kindness and let everyone know what a great guy he is. Thank you James !!!
Well, I dropped the seat off this morning and should have it back in a couple of weeks. It is being recovered to match the front buckets I already have in the Burb. I'll post some pictures when I get it back.
Hope everyone has a great Thanksgiving,
Dan
Decodan
1952 GMC Suburban
2010 F-150 4WD
Old 11-23-2009, 08:25 PM   #37
oldgold70c10
Who's got steelies?
oldgold70c10's Avatar
That is an awsome burb!!! I can't wait to see it when your done!
I also want to know how quiet it is inside with all that insulation when your going down the road.
1969 C10 LWB W/ 250 I6 & 3spd
1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver.
1975 Chevelle Malibu Classic Coupe 350/th350 mint green
1970 C20 Suburban 350/700R4 4.10 gearing green & white
1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver
1983 GMC 1500 Sierra 305/SM465 2.73 rear end
How to add a trip odometer to your 67-72 stock speedometer
How to rebuild your Q-Jet
My Truck Page
My Youtube Channel
oldgold70c10 is offline   Reply With Quote
Old 11-24-2009, 12:51 PM   #38
decodan
C-20 Long Stroker
decodan's Avatar
Hey OldGold,
Thanks,
The insulation made a BIG difference. When i got the Burb you could hardly hear yourself think. Now, I can talk on a cell phone while driving, listen to music without having to have it so loud it shakes everything and even the tire noise is not noticeable with the windows up.
I fully recommend putting the insulation in. It was a little pricey but well worth it.
Dan
Decodan
1952 GMC Suburban
2010 F-150 4WD
Old 11-24-2009, 05:11 PM   #39
duallyjams
duallyjams's Avatar
Hey,
Dan
I could not believe how our timing worked out for a place to meet, it took the two of us working together to make it happen so a really big THANKS to Dan.I was not delayed on my trip at all.
I am glad the seat will be put to use instead of being tossed out.
Dan burb looks alot better in person then it does in the pics.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 12-06-2009, 02:14 PM   #40
decodan
C-20 Long Stroker
decodan's Avatar
Hey James,
Here is a picture of the rear seat after I had it covered to match the front seats that were out of a 1999 Extended Cab Chevrolet Pickup. Now, just to get it installed. I have the arms off now, I bead blasted them and have to paint them. Then I should be ready for the install on the seat. I think I may try to make it flip up in case I need more room to load things in the back.
Thanks, Dan
Decodan
1952 GMC Suburban
2010 F-150 4WD
Old 12-06-2009, 03:40 PM   #41
duallyjams
duallyjams's Avatar
Wow that seat looks GREAT.
James
IG duallyjams
