Old 06-25-2009, 05:40 AM   #26
70GMCer
70GMCer's Avatar
Re: Headers hit the motor mounts
I'm using these. Although I'm not using the same headers as you, I'm sure you would get the clearance with these. http://www.performanceonline.com/sto...cat=455&page=1
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 06-25-2009, 06:22 AM   #27
stevewhitmore
stevewhitmore's Avatar
What brand of headers are you running?
stevewhitmore is offline   Reply With Quote
Old 06-25-2009, 09:16 AM   #28
MisterE72
Keep Your Nose Clean
I set the old transmission crossmemeber in place and measured the distanace from the floor to the top of crossmember and compared it to the same measurment using the tubular trans crossmember: the old one sits about 1 inch higher than the tubular. I'm running the same transmounts, so that may be why i'm getting the engine tilt. Raising the trans 1 inch however, still doesn't make the engine level at the manifold..2 inches does. Here is what i'm going to try based on the advice: 1) Raise the tranny about an inch at the mount using square tubing (thanks Tx Firefighter) 2) modify the existing motor mounts for header clearance. I'll post pics later. I'm going to HE-MAN: beer,guns, and fishing .
MisterE72 is offline   Reply With Quote
Old 06-25-2009, 09:20 AM   #29
MisterE72
They are not name brand headers..the box has model#S9972. That doesn't tell me much. I still think I should have saved up some more and got the ECE Sandersons.
Old 06-25-2009, 10:03 AM   #30
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Remember that your carburetor mount flange should be about level at fully assembled ride height. It's not really that important though. Close is good enough. Think of it, anytime you are driving up a slight hill, it's not level. Same with downhill. I'd just raise it enough to get the header tube clear and not worry about it any further.
So, who made the crossmember ?
Old 06-25-2009, 10:20 AM   #31
big_al_71
big_al_71's Avatar
Mr E. The problem is that you have the crossmember upside down, flip it over and your problem will be solved....Look at the picture of mine....Let me know it this solves your problem.
Moving the engine towers back will still be the same distance to the headers....Trust me.....
I look forward to hearing that I solved your problem,,,,
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 06-25-2009, 10:29 AM   #32
my67chevytruck
Under Construction
my67chevytruck's Avatar
I thought that at first too Al, soo i asked for pics... by looking at the mounting tabs on the frame it looks like he has it installed correctly, maybe the Manufacturer installed the ends wrong. where is a pic of your Al? It does look like the center support is upside down however. that is probably why Kevin asked who made it......
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
Last edited by my67chevytruck; 06-25-2009 at 10:32 AM. Reason: Added pic of Mr E's
my67chevytruck is offline   Reply With Quote
Old 06-25-2009, 10:51 AM   #33
big_al_71
big_al_71's Avatar
Here are the picts I have of mine here in my office I could take some tonight when I get home....I did mine last year and mine went on and it cleared everywhere my assistant who worked on my truck also thinks that it is upside down...
Old 06-25-2009, 10:54 AM   #34
chevy_mike
Never Ending Projects
chevy_mike's Avatar
I was going to post the same thing. I thought it looked upside down but the mounting flanges looked right.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 06-25-2009, 11:12 AM   #35
69sixpackbee
My Hedmann Elites hit in the exact same place on my '72.
I just ground off the lip on the mount tower and notched it back with my cut-off disc. Problem solved.
Bud
69sixpackbee is offline   Reply With Quote
Old 06-25-2009, 11:52 AM   #36
MisterE72
This is the trans mount from Classic Perforormance Products. It should install as shown in the pic iside the frame rail.
Old 06-25-2009, 01:39 PM   #37
big_al_71
big_al_71's Avatar
As I am here reading the different posts I thought of something else, could you have gotten the wrong part or misalabeled being that your tranny is a 700r4 and mine is a th350...just saying....
Old 06-25-2009, 01:42 PM   #38
MisterE72
Thats true. I'm getting on the phone with them right now. Thanks
Old 06-25-2009, 03:04 PM   #39
chevy_mike
chevy_mike's Avatar
It does seem like the one on your truck is somewhat flat across the frame and the one you pictured from CPP is raised. Kind of hard to tell from the angles but that could be the problem.
Old 06-25-2009, 03:21 PM   #40
MisterE72
You know, your right..Al's and mine do look flat when compared the website pic. Maybe they use a generic pic for for all trans crossmembers on the website.
Old 06-25-2009, 03:25 PM   #41
Tx Firefighter
I understand that everyone has different desires and situations, but stuff like this is why, more and more, I prefer the good old original GM parts. They may not be sexy looking, but they fit.
Old 06-25-2009, 03:43 PM   #42
stevewhitmore
What brand of headers are you using?
I am ready to order a set and don't want the problems you are having
Thanks,Steve
Old 06-25-2009, 05:09 PM   #43
jbristo67
resident oilfield trash
jbristo67's Avatar
Order the ones I am using they clear fine. I personally think he has the wrong headers
1967 SWB C10 396/400 factory air
factory tach (sadly had to send to a new home)
1986 Honda 70 Fourtrax
1991 Chevrolet K5 blazer 2wd
1982 Mastercraft Pro Star 190 Stars and Stripes
2002 Chevrolet Tahoe
2011 Nissan Armada
jbristo67 is offline   Reply With Quote
Old 06-25-2009, 05:23 PM   #44
bigsnookmaster
bigsnookmaster's Avatar
I bought a kit and made mine, about the same you guys got. I measured from the bottom of the frame rail to where the mount is on a stock crossmember, and duplicated that height on the tubular one. Piece of cake! And yes, the carb flange should be about level at assembled ride height. Good luck
bigsnookmaster is offline   Reply With Quote
Old 06-25-2009, 05:28 PM   #45
MisterE72
Thanks,Steve
Did a little research and found out the headers are made by a company named Racing Power Company and distributed through Racing Products Warehouse. The online price is about $280. I paid $100. Keep in mind these were originally designed for a Chevelle. I took a chance. If you want a sure bet, get the Sandersons from http://www.earlyclassic.com/
Old 06-25-2009, 08:28 PM   #46
john02fxdl
MisterE, I bought those headers on ECE website and all I can say is WOW!!! They are not long tubes but I have tons of room around the frame, firewall, and motor mounts. No clearance issues whatsoever. one of the fine investments I made on my truck. Just my .02
When I grow up, I want to be the man my wife married.
I used to be schitzophrenic, but we're O.K. now
john02fxdl is offline   Reply With Quote
Old 12-21-2011, 09:10 PM   #47
LEX
LEX's Avatar
Question Re: Headers hit the motor mounts
Originally Posted by jbristo67 View Post
look at the front tube on my headers they clear the mount by a mile
I know this is a old thread, but can anyone tell me a part number or any info on these headers? These are the exact ones that came with my '70 I just got and the poster above hasnt posted in over a year to ask him.
I've tried searching for a while and it brought be right back to thus site when Google showed me this pic. From what I understand, it's not that easy to find headers that fit like a glove. I'd like to keep these and get them coated with a high temp powder, but it will cost me $340. If I can find the p/n for these, I'd rather just get another set of headers by cross referencing the number.
I hope I'm making sense. I hate posting from my phone.
*edit*. These are by Dynomax btw. Looks like they no longer make headers?
LEX is offline   Reply With Quote
Old 12-21-2011, 10:48 PM   #48
chevykevy
chevykevy's Avatar
I have the same headers and i got them from jegs. They are Jegs Part #
500-69890. Look at the picture above
chevykevy is offline   Reply With Quote
Old 12-21-2011, 11:21 PM   #49
LEX
LEX's Avatar
After running out to the garage to look again, the passenger side is a little different, but the driver side is identical. Works for me. Thanks!
So did Hedman takeover making headers for Dynomax or something?
Old 12-21-2011, 11:23 PM   #50
chevykevy
chevykevy's Avatar
not sure
