10-20-2009, 05:51 PM | #1 |
Re: Another Lks Dcvn Project - 1970 LWB for my Dad
Thanks -
I got some more done today - swapped out the A/C Controls for a newer set and also replaced and lubricated the cables as well. My blower doesn't kick on with the switch...I tested the blower with a hot wire and it turned on - so I must have a wiring issue somewhere - that might also be what is causing my dash lights not to work (everything else works - but the dash lights) - I will look into that tomorrow. I did encounter a PITA moment today with the door weatherstripping... I used some 88-98 Dodge Dakota ones on the passenger side - worked flawlessly... Did the same on the driver door - too tight - wouldn't close so I used the repop stuff (LMC weatherstrip) the PO had that came with the truck - went and got the 3M adhesive and put it in - then the door sill - now the damn door won't close all the way. I will latch - but it won't close all the way that pretty much sucks! |
04-27-2010, 09:17 PM | #2 |
Update - finally.
My Dad wasn't sure if he was going to take the truck or not [long story], but now it sounds like he will be...whatever - just let me know. After having this in storage for the past several months while it warmed up here - I spent some time this afternoon finishing up some loose ends on this project. I lubed up the window channels, installed the cleaned up door panels and then wired in my new Sony 3 way 6x9s I snagged off ebay over the winter months for a few bucks. Then I put her up for the night admiring my work - only to find out that I neglected to install the new mirrors and arms that I have. So it looks like I will be redoing that work again [twice - once off then on again] since I need to get to the inside of the door to install these stupid mirrors... Few things left to do: Speakers and Door Panels - done [for now] Resolve heater wiring issue - I might just remove/rebuild the dash harness Replace the carb with a 1406 and spacer to prevent fuel boil Resolve issue with throttle rod linkage [currently ghetto but it works] Swap out tires and rims [these are going to my 2wd Blazer project for now] Adjust driver door so it shuts correctly [new weatherstrip issue] Overhead light - adjust pin in door jam to initiate interior light |
05-09-2010, 07:11 PM | #3 |
wow ok this is the cleanest truck i have seen in a while from the east. so wat did u pay for it when you got it?
02-15-2022, 10:30 AM | #4 |
Ten unkind years, still a good looking truck.
Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd |
02-15-2022, 04:07 PM | #5 |
Thought the same thing when I saw the latest pix. Oh well - it wasn't my truck after I sold it a decade ago. Everybody maintains their stuff differently.
Nice to see the truck mostly unchanged though... |
