Old 09-14-2009, 01:06 PM   #26
nastyc10
nastyc10's Avatar
Re: New member new Project
Well its actually not fully aligned yet. I used a tape measure on the front and back of the tires and adjusted the tie rods accordingly to get the tires pointed straight. Then I used the factory shims behind the upper arms but didn't have enough to get the tires straight up and down. Now this is just temporarily until I Can get it to an alignment shop. Make sure your alignment is done at ride height.
nastyc10 is offline   Reply With Quote
Old 09-14-2009, 02:30 PM   #27
SCOTTMO
powdercoater
Looking Good !!
scott
sm.powder coating
SCOTTMO is offline   Reply With Quote
Old 09-14-2009, 08:06 PM   #28
Ricks' 72C10
Going Down?
Ricks' 72C10's Avatar
Originally Posted by SCOTTMO View Post
Looking Good !!
scott
sm.powder coating
If your shop was down here I probably would have had my frame powderecoated
Just another day in Paradise
Rebuild thread
http://67-72chevytrucks.com/vboard/s...d.php?t=354512
Ricks' 72C10 is offline   Reply With Quote
Old 09-14-2009, 10:30 PM   #29
EA69TRK
EA69TRK's Avatar
looks like this is gonna be a truck
subscribed
EA69TRK is offline   Reply With Quote
Old 09-17-2009, 05:59 PM   #30
sgrier
Man we are headed in the same direction with the builds. You have a good start going. I will be watching. Good luck.
sgrier is offline   Reply With Quote
Old 09-28-2009, 07:00 PM   #31
Ricks' 72C10
Going Down?
Alright! I'm excited again! My parts came in after four weeks wait
Things will start moving again
Fitted Performance Online aluminum fuel cell, had to trim the rearmost crossmember to let it slide down into place
FYI .. Believe it or not if you buy the Magaughys' big 13" brake kit, you will have to pull the rear axles and have the hubs turned down in two places so they will fit in the rotors. So it was back to the shipyard again today.
Rebuild thread
Old 09-28-2009, 07:15 PM   #32
Ricks' 72C10
Going Down?
Painted spindles, calipers, and hubs in last two days, now I can finally move toward a rolling chassis.
More free advertisement for Nate
Rebuild thread
Old 09-28-2009, 07:20 PM   #33
lolife99
67-72 parts collector,…
lolife99's Avatar
Those pics look beautiful to me.
Very jealous!
Keith
Convert to disc brakes.
Old 09-28-2009, 07:27 PM   #34
Ricks' 72C10
Going Down?
Very jealous!
Thanks, but
Why are you jealous? I can see that sweet Blazer!!
Same wheels I have by the way
Rebuild thread
Old 09-28-2009, 07:35 PM   #35
lolife99
lolife99's Avatar
I want to build a complete 67-72 Dropmember chassis like you.
I can't make myself cut up the blazer,... so it will never be that low.
I've started a Dropmember project with my '86,... but I really want to do a 67-72 model instead.
Keep those pictures coming!
Keith
Old 09-28-2009, 10:54 PM   #36
sgrier
Truck is looking good. Keep the pics coming. Almost have my chassis rolling. Nate does have some awesome products. Good luck with your build.
Old 09-30-2009, 07:03 PM   #37
Ricks' 72C10
Going Down?
Thanks Man
Good luck with yours also!
Update: For last couple days.. Finished up control arms
Jumped into the Mcgauhys' Big Brake kit.. it was a MF!.. no directions, had to go trial and error all the way. They didn't even put.. Some assembly required on the box! Finally figured out the way the rear caliper brackets will work I think. Got the spindles and hubs on, calipers and rotors, I think they will be OK.
Installed air bags, rack and pinion, and sway bar.
Rebuild thread
Old 09-30-2009, 07:07 PM   #38
Ricks' 72C10
Going Down?
A couple more pics
It's beer thirty
Rebuild thread
Old 09-30-2009, 07:16 PM   #39
bmfpeterson
bmfpeterson's Avatar
Rick,
Lookin good! I havent touched my truck since before i was in rocky pointe. But as soon as I get back from this horse show its game on.....
and I just cracked a beer with ya
bmfpeterson is offline   Reply With Quote
Old 10-02-2009, 06:57 PM   #40
Ricks' 72C10
Going Down?
Originally Posted by bmfpeterson View Post
Rick,
Thanks Blake
Send me some pics of your truck
I put some temporary air lines on so I can roll the chassis around
Roughed in the wheel alignment and installed shocks
Come on back down to Rocky Point and we'll drink some ice cold Tecate lights!
Rebuild thread
Old 10-02-2009, 11:37 PM   #41
nuke1
nuke1's Avatar
wow, that frame just makes me wanna cry it is so purty, wish mine looked that good, way to go!
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 10-12-2009, 02:53 PM   #42
bmfpeterson
this link has a few pics..... http://67-72chevytrucks.com/vboard/s...=1#post3564823
Old 10-12-2009, 04:11 PM   #43
mcbassin
Still Learning
mcbassin's Avatar
Nice progress! Cool how you painted all the components.
mcbassin is offline   Reply With Quote
Old 10-12-2009, 09:20 PM   #44
Ricks' 72C10
Going Down?
Thanks Nuke, Blake, and mcbassin,
I thought it would look cool to color coordinate the components to the original truck color rather than just all black or silver, somethin' different.
Set the cab on it today, body drop worked out really well, just had to trim floor a little for driveshaft carrier bearing support. After that it layed right down on pinch with room to spare in cab mounts. (Thanks Nate, you were right, .75" was perfect on the body drop mounts specs)
Rebuild thread
Old 10-12-2009, 09:27 PM   #45
Ricks' 72C10
Going Down?
Couple more pics
Rebuild thread
Old 10-12-2009, 09:35 PM   #46
vegaschevy
very good looking project and looking great so far!!!
vegaschevy is offline   Reply With Quote
Old 10-13-2009, 04:48 PM   #47
Ricks' 72C10
Going Down?
I'm so excited about getting it running and driving it that it is hard to sleep at night. I'm laying there in bed thinking: I gotta do this and then I gotta do that and on and on.
Did some more trimming on body parts today to get them to lay down over the tires.
Was going to attach some pics but I can't figure out how
Rebuild thread
Old 10-14-2009, 11:44 PM   #48
64shortc10
64shortc10's Avatar
Nice Truck! On the body drop, Did you also drop the front mounts .75 for the core support? Cant tell from the pics, and you already painted the frame so I can assume you are not cutting it like a traditional body drop right? Thanks for any info. Again Nice Truck!
Tony from Norcal
64shortc10 is offline   Reply With Quote
Old 10-15-2009, 12:00 PM   #49
Ricks' 72C10
Going Down?
Tony from Norcal
Thanks for the compliments Tony
When I decided to drop this truck to the pinchwelds last May, I had no clue. The guys on the forum directed me to Porterbuilt and he gave me advice and direction on the project. Nate told me how to do the body drop. You have the four cab mounts and two core support mounts. Cut the rivets off and bring the supports down and drill holes and put bolts. As for the bed, just notch out the sheet metal on the bed where it sits on the frame the same amount as you drop the other mounts.
Rebuild thread
Old 10-16-2009, 09:55 AM   #50
domsan
domsan's Avatar
Beautiful deep the truck, the work is clean.
domsan is offline   Reply With Quote
