03-10-2011, 06:00 PM | #26 |
someday
Re: blazer project
Not really any updates its been to cold and my spending cash is being eaten up heating my house. I did manage to get the exhaust built but did'nt take pics yet.
Click Here to search ebay for all 67-72 parts My 72 CST blazer build 72 CST Blazer 4x4 67 2wd swb ( project onion crate ) 86 4x4 lwb plow truck 40 x 60 foot barn to work on all this stuff |
03-18-2011, 01:13 AM | #27 |
Re: blazer project
On your frame to put the Blazer on its side - is the box tubing touching the side of the body on the floor side?
Or is all the weight on the (four?) bolts holding the L to the frame? Did your bolts bend at all with this setup?
-Ben 1972 CST K5 - Undergoing frame off, 8.1/4L80E/NP205, 3/4 ton, 8" lift, currently a pile of parts that when assembled resemble a Blazer 1972 K10 - Rust Bucket, TBD 1976 C10 SWB, 350 / T350 My blazer build thread: https://ck5.com/forums/builds/72-k5-...17-update.410/ |
03-19-2011, 11:34 AM | #28 |
someday
Re: blazer project
My "L" shaped rig for tipping it has some old exhaust pipe welded on that the bolts go through. Actually i had to use threaded rod because in the rear the bolts had to be 12 inches or so. I did not have any of the bolts bend. It does not touch the body on the bottom side but i had to make it real close so i would have room to tip it with my low ceiling. Once it was tipped up i used blocks under my cross braces that were across the top of the bed for extra support. Also i used a rope to ease it over when tipping ,i did it alone, but if you have help it would be cake without it.
03-19-2011, 11:50 AM | #29 | |
Re: blazer project
Your build is very impressive! I like it. What is going on in picture above though? I don't see your L supports? I love your tip setup there - and totally want to use it, but needs some more explanation please... Could you explain in short words (I'm slow today) what you mean about "blocks under the cross braces" - do you mean the cross braces at the door? So blocks between floor and door bracing?
-Ben 1972 CST K5 - Undergoing frame off, 8.1/4L80E/NP205, 3/4 ton, 8" lift, currently a pile of parts that when assembled resemble a Blazer 1972 K10 - Rust Bucket, TBD 1976 C10 SWB, 350 / T350 My blazer build thread: https://ck5.com/forums/builds/72-k5-...17-update.410/ Last edited by IGOR; 03-19-2011 at 11:53 AM. |
04-24-2011, 01:21 PM | #30 |
PROJECT 7DEUCE
Re: blazer project
Very nice man that fresh paint has got to get you motivated..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
04-28-2011, 05:47 PM | #31 |
someday
Re: blazer project
yeah, i have some more fresh paint to put on. The warmer weather sure helps motivate me too. More updates coming soon i hope................
05-05-2011, 09:15 PM | #32 |
someday
Re: blazer project
put the windshield in and also started the soundproofing on the firewall. I'm waiting for my firewall pad set to come in so i can install the wiring, heater/AC parts, parking brake pedal, dashpad, glove box, and gauges. I gotta remember to take pics of the exhaust that is done except for some turndowns.
05-31-2011, 11:18 AM | #33 |
someday
Re: blazer project
I have been working on the blazer a lot lately. I took a bunch of pics the other day and i'm going to catch up the build thread over the next couple days.
here are some pics of the exhaust, what you can see of it at least. I used the newer style hanger because i like the clean look.
05-31-2011, 11:21 AM | #34 |
someday
Re: blazer project
I also change the parking brake cables to this newer style system. It works great and it is simple.
06-01-2011, 11:02 AM | #35 |
someday
Re: blazer project
I got the heater core and a\c evaporator installed. I changed the evaporator to one that would go in a late 90's van. It was real close to the same size as the original but is for 134a. I plan to buy a sanden type compressor and buy or make the hoses. I'm going to look at a salvage yard for a suitable 134a condensor. I also rearranged the wiring so that all the engine wiring comes out near the wires that go to the rear lights. I never liked the wiring in the channel across the firewall. On the inside i pulled the connectors out of the fuse block plug that i wanted to re-route and used an old fuse block plug as a connector.
06-01-2011, 11:04 AM | #36 |
someday
Re: blazer project
forgot the pic of the fuse block and homemade connector
06-02-2011, 11:53 AM | #37 |
someday
Re: blazer project
got the wiper panel and inner fenders painted I need to wet sand and buff the wiper panel. the last pic is how it sits right now.
07-27-2011, 09:59 PM | #38 |
someday
Re: blazer project
after lots of busting but this is where she is at. Still a lot of stuff to do but its drivable.
07-28-2011, 02:44 PM | #39 |
Re: blazer project
Looks great!
07-29-2011, 02:12 PM | #40 |
needs more $$$
Re: blazer project
Wow! Doesn't look like "a lot" to me...great job! I like the wheels.
1970 2wd Blazer |
07-29-2011, 05:39 PM | #41 |
Re: blazer project
do you have any more info on the evaporator core u used? why did you switch was it cost?
07-29-2011, 07:20 PM | #42 |
someday
Re: blazer project
The evap. core i used is for a late 90's astro van. napa part #288097. It fit almost perfect. I had to use some foam gasket i got from the hardware store to seal one side because there was about a 1/4 inch gap. I also fabbed a filler peice to fit around the top tube. I changed it because i like the cleaner less cluttered look of the newer system and my system had a leak and i didnt want to mess around with the old parts. I plan to run 134a refrigerant so i will probably get a sanden type compressor and a 134a condenser. I have the accumulator/drier also i cant remember what that fits but it will point the fittings in the right direction. I dont know the retail price because i get a discount through work. It was less than $100 with my discount. I probably wont get the a/c finished until this winter my truck budget it spent for the year.
07-29-2011, 07:21 PM | #43 |
someday
Re: blazer project
And, Thanks for the positive comments. I makes all that work worth it.
07-29-2011, 08:41 PM | #44 |
Re: blazer project
Well done! Always was a big fan of black, but sure is alot of work to pull off...
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
08-08-2011, 08:44 PM | #45 |
someday
Re: blazer project
playing with a design for my custom seat backs and rear side panels. I used some of it to make this new avatar. I took a photo of the scroll on the factory door panel and traced it out and traced a photo of the k5 emblem.
08-08-2011, 09:37 PM | #46 |
needs more $$$
Re: blazer project
Damn cool...just made my PC's wall paper.
1970 2wd Blazer |
08-28-2011, 01:12 PM | #47 |
someday
Re: blazer project
made these seat backs from mdf board. It takes several coats of primer with sanding in between to get the edges smooth but the result looks pretty good. My plan is to have the design that i posted engraved into them. The guy that is supposed to do it is too backed up and i want them on for the adirondack nationals so i'm gonna redo them over the winter.
08-28-2011, 01:35 PM | #48 |
someday
Re: blazer project
i have also been working on making the rear seat fold down. The seat i have is not from a 72. I got it out of a 69 blazer but i think its really from a 73 or newer. I'm not sure what the differences are besides the mounts, I just welded some plates with holes drilled and tapped where the mounts need to go. After several hours of trial and error i came up with this setup. I wanted it to look somewhat factory. The tricky part is making it fit between the wheel wells. I used iron water pipe for the new peice that runs from the arm rest down. The first pic shows my fancy bender, next are the new pieces, then the modded part of the seat, after that is the almost finished product. I need to fix up my cheap autozone cover.
09-11-2011, 08:22 PM | #49 |
someday
Re: blazer project
Took the blazer on its first long trip this weekend. My fiance and i drove to lake george, NY for the adirondack nationals car show. It was a 300 mile round trip and we averaged 9 miles per gallon. It was a blast the local police block off a section of streets that form a loop and only show cars can get in. They do this from 8pm to 10pm and it make this show far better than any other show i have been to. anyway here are a sample of the pics i took.
09-11-2011, 08:24 PM | #50 |
someday
Re: blazer project
when the cars leave the show for dinner they get a little crazy!!!!! i have some more of these but there is so much smoke you cant see anything
