10-07-2009, 05:14 PM | #26 |
Eat My Rust
Re: Pro Street anyone??
10-07-2009, 05:59 PM | #27 |
Redefining LowBudget
yea baby more cow bell!!!
10-07-2009, 07:03 PM | #28 |
I found that if you use the E brake cables off of a longwheel base leaf spring truck you won't have that problem.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
10-07-2009, 07:18 PM | #29 |
not sure what year the next truck I build will be I'll have to see whats out there but I plan on the pro street look with a min of a 454 under the hood and then slam the hell out of it so cutting the bed floor is no big deal 2" drop spindles and cupped LCA will lay the stock X hard...I noticed you guys area all running 5 lug wheels so I'll have to do something there I have a dana 60 (8 LUG) but since I do have some wide wheels I may go that route than slam some salt flats caps over all 4 and go for that look
nothing beats pulling up behind a set of gumbos hearing a little rumble from the tail pipes and maybe a litle second gear bark when they roll out of the light..gives me wood thinking about it!! |
10-07-2009, 09:19 PM | #30 |
dazed and confused
i love that sleeper truck!!!
members met: redbaron69, billsbowtie,nc67 Last edited by bigguy69; 10-07-2009 at 09:19 PM. Reason: hit to many buttons |
10-07-2009, 09:27 PM | #31 |
This might be an old idea,is there a coil-over set you can put in to get more tire clearance?
10-07-2009, 09:56 PM | #32 | |
hmmmmm??? need that # I guess before I get ahead of myself |
10-07-2009, 09:57 PM | #33 |
67-72
heres a couple pictures of the backhalf in my truck. I made it all myself from the crossmember back. it is a cpp crossmember that i filled the exhaust holes in. there is still alot of work to do and im re doing the rear suspension a little bit adding a wishbone and mounting tabs for a 9in instead of the 12 bolt i had in it.
10-07-2009, 09:59 PM | #34 |
67-72
10-07-2009, 10:04 PM | #35 | |
and thanx this is something else I may work on with the truck I have now and then tranfer it to the next build...you always learn from the first one and the second you can make it better..
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. Mikes Sandwich Fair Run OCT 8th 2011
10-07-2009, 10:22 PM | #36 | |
10-07-2009, 10:35 PM | #37 |
hartrod do you think if you where c notched you could tuck your wheels up?? it could be the pic but it looks like your wheels are even with the fender lip?? I want to bag it so I need the clearance out there ..by the looks lof things you could have gone wider as long as it was with back space??
10-07-2009, 10:36 PM | #38 |
Active Member
Hottrucks - I will get you a picture =- I looked thru my existing photos and I do not have any like you want.
I will have to lay a straight edge up into the fender well to see how much additional drop I could go. The back currently has a 5" drop. I love the prostreet look and the sound.
1968 SWB 454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts 781 heads Ported with 2.19/1.88 SSTvalves Lunati 60204 cam, Micro Trol lifters, Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition Holley 770 Street Avenger carb,Headers armor coated Built by Watson Ruppel Performance in Sarahsville Ohio. Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall 12 Bolt Eaton Posi 4.10 Richmond Gears moser axles 18.5" x 31" Hoosier Pro Street Radials ET Classic 5 Wheels - polished Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone) Custom Paint & Body Work Special thanks to my wife, my son and my money tree |
10-07-2009, 10:45 PM | #39 |
Is there any rule it has to be a short wheel base? A Satin Black,slammed ProStock look would be sweet.
10-07-2009, 11:01 PM | #40 |
thanx like I said I want to c notch it so I can all I can and keep the bed floor flat narrow but flat!!
I hope theres no rules because I hate paint!! to much work!! rhode island red oxide oh and I'm working on a lwb.... the look I want is old school, long,low, and flat the wide wheel tire combo on the back just brings it to the next level when I air up ... but a burn out with them tucked its just..... Kool... besides the hole big wheel thing isn't my style now wrinkles with 8 to 10 lbs of air yea baby
10-08-2009, 10:49 AM | #41 |
Not a truck, but like this?
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD Click here to support the board Philippians 4: 6-7 |
10-08-2009, 03:37 PM | #42 |
ok guys I scored some 29x18.5x15 rubber now who has a set of rally wheels (6 lug) that are 12" wide stockton wants more for the rim then the tires!!!
someone please tell me these are going to fit my 70 LWB or do I have to measure the axle width......never mind it's 58" from plate to plate Last edited by Hottrucks; 10-08-2009 at 03:39 PM. |
10-08-2009, 09:21 PM | #43 |
Active Member
You may want to double check but I do not think they recommend a 18.5" tire onto a 12" rim - they will bow to much ie ride only on the center of the tread
10-08-2009, 10:11 PM | #44 |
67-72
i have a 29x18.5 on a 15x14in rim.
10-09-2009, 08:01 AM | #45 |
well here is my plan for today going to hit local race car shop to check on a piece of 6"X 44" then I'm going to see of I can get it rolled..the stock rally with my spare will become the victum...Once the rubber is stripped I'm going to clean the cut area so welding will be easier then mount it on the front of the truck...the truck will become my fixture.....wish I had one of those fancy plasma cutters but a wiz wheel will have to do for us poor people....by slowly spinning the wheel I will cut it about 1.5" from the center....
Once cut it I will get some short pieces of angle iron to hold the rim to the new width and get it close using a framing square ...then back to the fixture (truck) to try to true it up and get that piece of 6" rolled filler in...I think it could be a slow process kinda like body work so as to try to keep it as square and true as I can...If it works out at all then I will bubble balance the rim by adding weld where it's needed Ok thats my dream..when done it should be a 14" rim that looks stock from the side well just had a dumb idea need to check the width of stock car wheels??? hmmm might be easier to just cut the 4 welds holding the center in???...dam it!! I hate it when that happens....
10-09-2009, 10:10 AM | #46 |
English Chevy Owner
Don't do it, you'll kill yourself! You can get wheels widened (banded) by specialist companies (well you can here in the UK) and they have the proper precision gear to cut them true, weld in the band properly and keep them trued up. Just a millimeter or two out and it'll shake the truck to bits and probably kill you. Widening wheels is a job for the pro's.
Phil '67 C10 long fleet. 350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon 2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission |
10-09-2009, 11:00 AM | #47 |
http://www.google.com/search?q=steel...8&sourceid=ie7
here ya go. lots and lots of companies that widen wheels..... i got my 15x14 corvette rallys from http://www.wheelvintiques.com ... not sure if that was them or not... i know i used 15x14 w/ 10" bs corvette style rally and it worked perfect w/ stock frame etc.. (widened wheel tubs of course) Last edited by QKENUF4U; 10-09-2009 at 11:02 AM. |
10-09-2009, 03:02 PM | #48 |
ok for starters the only dif between a pro and a guy in the shop is one is getting paid so any and all work I do is done with the same care and safety...
QKen I called and @ $200 a wheel is out of my budget...Stockton wanted $192 new and $225 if they us my wheel go figure?? so heres where it stands.. I have searched the hell out of the internet and came up dry other than the fact that carlile makes the hoops(15x14) ..you may know them as Cragar..unfortunatly they won't sell them to me so me swapping centers is out so far...so back to plan A well off to the race car shop to see about getting that 6" flat stock and rolling it...well come to find out there is a plan C I found a guy local that cuts race wheels and puts new halfs on steel race car wheels?? I guess they beat the bead lip off these things like crazy?? well I have a meeting with the old gent at the end of next week to size up whats going to happen next....from what is sounds like he has a jig to cut the wheels and keep them square while he welds them up......rumor has it that he get $75 or so from the race guys but being an old time rodder.. I'm hoping to roll up in the truck and make a new freind and maybe get a deal... I pick up 4 more rallies with rings and caps this weekend so I'll have some to work with?? Maybe I will just weld 2 of them together and have a 16" wheel...lol!! Jeff thanx for the ok on the fit?? is my rear axle the same width as yours??? 58"
10-09-2009, 03:47 PM | #49 |
Hartrod's my fave, hands down. So sneaky, I love it.
Josh '70 Custom Camper / 20 |
01-11-2010, 10:36 AM | #50 |
well like all things tires have changed I went to talk to the guy who was "Holding" the tires for me and he gave me the I wasn't sure so I Ebayed them??" but sitting as coffee tables are a set of 31x16.5x15....a bit taller than I wanted but couldn't pass up the deal so now back to the rims...I'm going to freeze my lug nuts off and get a trailing arm to rim # to work with and take a rim to another shop to see what they can do...the first shop that does the work all the time for the race guys turned out to be a ...well never mind but he couldn't be bothered...
