Old 11-09-2009, 12:41 AM   #26
ClifBlazer
ClifBlazer's Avatar
Re: cut truck frame for blazer/jimmy mode?
Well found frame for jimmy tube with out the big cut jimmy frame is comeing from teeitup out in KS was a 4x4 jimmy ironicke but he's keeping frount springs puerchs and axlas crossmember motor and trany basicly Im buying frame rails rear lefsprings and apice of frame to patch were 4x4 frame has been cut for headers may be hope I can get it in next 2 weeks pics good you can see were frame is cut left frame in engin bay I know Ill have to get two wheel motor cross member what more will I need trany crossmember is tran spicific isinit
ClifBlazer is offline   Reply With Quote
Old 11-10-2009, 08:02 PM   #27
ClifBlazer
ClifBlazer's Avatar
need help with this do I get it or not frame at cross member ??????
Old 11-10-2009, 08:19 PM   #28
ClifBlazer
ClifBlazer's Avatar
damage to frame need some advice about pic 2 pic 1 shows a repair and 3 is a frame end
Old 11-10-2009, 08:29 PM   #29
lolife99
67-72 parts collector,…
lolife99's Avatar
First,... did you tell Teeitup you would take it?
Now you are trying to decide if you want to back out?
You were just about to shorten your swb frame and fab all the new tub mounts, correct?
A few repairs like this shouldn't be a problem,...
Keith
Convert to disc brakes.
Old 11-10-2009, 08:30 PM   #30
ClifBlazer
ClifBlazer's Avatar
no he is asking me if I want to cool I got you here what will I need for two wheel frount end
Old 11-10-2009, 08:38 PM   #31
lolife99
lolife99's Avatar
That hole in the 4x4 front crossmember won't matter since it will be removed.
You need a good 2wd disc brake (complete) crossmember assembly with all steering components.
Auto trans crossmember.
And you need to decide if the rear suspension is going to stay leaf spring or will you be changing to coil spring.
Keith
Old 11-10-2009, 08:55 PM   #32
ClifBlazer
ClifBlazer's Avatar
thought you when away sent pm more questions you where saying some thing about 73-87 trucks could be used for that
Old 11-10-2009, 09:11 PM   #33
lolife99
lolife99's Avatar
Read this:
http://www.sporttruck.com/techarticl...ion/index.html
Keith
Old 11-11-2009, 11:28 PM   #34
ClifBlazer
ClifBlazer's Avatar
Ill get frount end in and than move back or if i find axle for the right price Ill start there look for the deal thats what i have to do besides the little woman now has plane for short bed BIG BLOCK 454 a friend has it and has been talking to her. than there will be trany th400 motor has been twisting the 350trubos in two and drive shaft not for getting it still needs bed good news brake swap and m/c are all ready payed for hell mite have to sell blazer just to do swb you never know what she may come up with
Old 11-12-2009, 03:46 PM   #35
brian26
Eleven inches cut
between the trailing arm crossmember and where the automatic tranny mount would be.
That is how i got mine.
brian26 is offline   Reply With Quote
Old 11-12-2009, 03:47 PM   #36
brian26
I would do something different next time though--
I like the material thickness of a 3/4 ton 2wd frame........ Less flex
Old 12-08-2009, 05:48 PM   #37
ClifBlazer
ClifBlazer's Avatar
well i have a new adition got a half ton lwb frame with pos.5 lug on coil springs with a disk brake 5 lug coil front end I will be puting on the blazer frame pics will come later
Old 08-16-2018, 07:29 PM   #38
67see10
67see10's Avatar
Anyone have the dimensions for where the blazer specific mounts would go on a cut down lwb frame?
67see10 is offline   Reply With Quote
Old 08-17-2018, 11:07 AM   #39
billthompson
might find some ideas here
http://www.trucktrend.com/how-to/cha...wd-conversion/
billthompson is offline   Reply With Quote
Old 08-18-2018, 12:48 PM   #40
67see10
67see10's Avatar
Originally Posted by billthompson View Post
Thanks I've read the article.
Old 08-18-2018, 09:07 PM   #41
82sdale
stock 1972 2wd blazer frame pictures.
82sdale is offline   Reply With Quote
