Old 11-16-2009, 10:18 PM   #26
CG
BlahBlahBlah
Re: LFD's upper door seal idea!
None of my trucks go fast enough to create wind noise...but it does look like a good idea =)
Old 11-16-2009, 10:18 PM   #27
wancosc356
I Like Mine With No Shine!
wancosc356's Avatar
Originally Posted by Rokcrln View Post
No I think that would be over kill and it would not seal any better because the upper half of the door is the only place with a second edge close enough for a double seal. It is also the only place on the doors that stick out to grab the wind as it goes bye. The lower half of the door is smooth with the body and the wind flows over it much better with out the turbulence occurring.
Kevin
LFD Inc.
Oh ok. I get ya. Sounds good. Keep us all posted. Thanks for the great idea.
Michael
1967 Chevrolet C10 Short Fleet (Literal Ground Up....One Day)
2006 GMC Sierra Crew Cab 4x4
1969 Lincoln Continental Coupe Project FOR SALE
http://67-72chevytrucks.com/vboard/c...ct=4578&cat=17
1981 Honda CM400 C Bobber SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=384152
wancosc356 is offline   Reply With Quote
Old 11-16-2009, 10:19 PM   #28
mickeymouse
I am in for a set, especially if we can get it cheaper.
mickeymouse is offline   Reply With Quote
Old 11-16-2009, 10:28 PM   #29
jeffspower
Well, Whoop-dee-do!
jeffspower's Avatar
We use it as a secondary seal like you did on the lower compartment doors on the hauler below. I think it is from Hanna Rubber Co.
Link to their website & catalog: http://www.hanna-kc.com/
I'll grab a piece of the rubber we use on the steps too. I bet we could use it on the rocker thresholds.
'68 GMC shortbox 4x4 350/SM465/T221- bought it in '83 SOLD
'72 K20 500 Cad/TH400/NP205 SOLD
'92 Chevy 2500 6.5 mech TD 4L80E crusty daily driver
'72 Monte Carlo... sweet low mile toy
'11 Dodge Challenger IE 392 6spd... midlife car
jeffspower is offline   Reply With Quote
Old 11-16-2009, 10:40 PM   #30
72blue
72blue's Avatar
I am interested as well.
James
72blue is offline   Reply With Quote
Old 11-16-2009, 10:55 PM   #31
Mondo
Mondo's Avatar
Count me in.... now just tell me how to get rid of all the rattles
Mondo is offline   Reply With Quote
Old 11-17-2009, 12:04 AM   #32
Rokcrln
Rokcrln's Avatar
Remove everything and as you put it back in make sure nothing is loose
You would be surprised if you start checking things for movement and fastening them down or to other objects (like zip tying any loose wires together to make one solid bundle) it will start making a big difference.
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 11-17-2009, 12:09 AM   #33
Rokcrln
Rokcrln's Avatar
Originally Posted by 67cheby View Post
i
what brand door seals have you found work best and what to glue them on with ??
Sorry I missed the second half of your question.
I bought mine from ECE and they are the standard ones for a 67-72. I also liked how easy the 73 and later one's just push on but they were just a bit to large and you had to really slam the doors and still had wind noise.
I have tried several different kinds of weather stripping adhesive but I found the yellow 3M works the best. It is a contact type of cement and holds great. I recently tried their Black version thinking it would hide any over run or the glue but it did not hold for more than 203 months before it just started letting go from the rubber.
Kevin
LFD Inc.
Old 11-17-2009, 12:49 PM   #34
k2rm
k2rm's Avatar
Intersted as well!
k2rm is offline   Reply With Quote
Old 11-17-2009, 01:13 PM   #35
nicolas72gmc
nicolas72gmc's Avatar
Kevin, I would be interested in a set also. Just let me know when you are ready. HHHHMMMMMMMM........lowbuck..... I'm still in love with your truck.
Nick
"Everyone has a plan, 'till they get punched in the mouth".........Mike Tyson
1968, GMC, SWB, Project
1972, GMC, LWB, Daily Driver, 383, headers, 2.5"/3" exhaust, 200r4, 3.5/5 ECE components.
1972, C/10, LWB, 350 vortec, th350
nicolas72gmc is offline   Reply With Quote
Old 11-17-2009, 02:00 PM   #36
Custom 68
Custom 68's Avatar
count me in also I have beat on my upper mounts to make them fit better and it is not bad but could always be better.
Dave
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 11-17-2009, 02:20 PM   #37
jorgensensc
jorgensensc's Avatar
Okay, what about the burbs? Would your seals work on the third door since they are more right angled than contoured?
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 11-17-2009, 04:35 PM   #38
Rokcrln
Rokcrln's Avatar
Shawn
Yes it should work the same you will just need to angle cut the corners to fit but most of the wind noise is coming from the wind hitting a swirling in the open vertical pockets between the door and the jamb. Since the burbs don't have the vertical drip rail at the door edge to catch and redirect the wind I would think the noise would be even less then the truck with everything else being the same.
Kevin
LFD Inc.
Old 11-17-2009, 04:38 PM   #39
Rokcrln
Rokcrln's Avatar
Ok here are some very scientific lab results on the decrease in wind noise. Normally with my windows up I have my stereo turned up to 29 anytime I am doing over 45 mph. I just had to run into town for an appointment that I was running late for so I was pushing it and with out realizing it I was cruising at 80 and I had to turn the stereo down from 29 to 24 because it seemed too loud
Kevin
LFD Inc.
Old 11-17-2009, 09:31 PM   #40
jrdv
jrdv's Avatar
I would be interested in 5 sets! I hate wind noise.
John
jrdv is offline   Reply With Quote
Old 11-17-2009, 09:33 PM   #41
scottrod71
scottrod71's Avatar
I'm definitely interested. The wind noise from a recent trip (on a very windy day) nearly drove me crazy. The only way I saw to fix it would ruin the door gaps and reveals by setting the door deeper into the opening, so this sounds real good to me.
scottrod71 is offline   Reply With Quote
Old 11-17-2009, 09:50 PM   #42
Rokcrln
Rokcrln's Avatar
Sounds good I should have some $ in a few days. It looks like I will be needing a few hundred feet of each type so that may drive the price even lower I hope. I had a few feet left over so I fit it in the 3rd door of my 72 Tahoe and it fits just as well as the truck with a couple placement changes because of how the front edge of the door closes compared to the trucks.
If you want a set you can PM me and I will start a file so that way once it is ready and priced I can send out a PM to everyone on the list.
Kevin
LFD Inc.
Old 11-17-2009, 11:22 PM   #43
07SSSC
07SSSC's Avatar
Ooh, I hate wind noise too even though the engine is plenty loud wind noise drives me crazy every drive.
'69 Chevy C/10-under reconstruction -- '68 C20 Camper 50th Anniversary-runs, but sorely needs a resto --
'07 Cobalt SS/SC-very fun DD -- '93 Chevy K2500-LQ4/4L80E swap --
'84 Trans Am-awaiting (LS) drivetrain -- '00 Trans Am-road tripper -- '06 Z06-577 WHP beast
07SSSC is offline   Reply With Quote
Old 11-17-2009, 11:33 PM   #44
Rokcrln
Rokcrln's Avatar
Yep I would take a healthy V8 over wind any day
Kevin
LFD Inc.
Old 11-17-2009, 11:47 PM   #45
thelonerife
thelonerife's Avatar
I have thought about this for a while now and am glad your doing it. Put me down for a set.
thelonerife is offline   Reply With Quote
Old 11-18-2009, 12:25 AM   #46
jugernot
Life, Be In It.....
jugernot's Avatar
Oh you know I want a set
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows"
http://67-72chevytrucks.com/vboard/s...d.php?t=200082
jugernot is offline   Reply With Quote
Old 11-18-2009, 06:50 AM   #47
darkhorse970
darkhorse970's Avatar
I'm in for one set.
Keith
SOLD - 1963 C10 Short Fleet
350/700R4
4/6 drop
1967 GMC Super Custom - Short Fleet
COPO concept w/427 BBC
T-400 w/Doug Nash overdrive
4/6 Drop, Buddy Buckets, etc...
Frame Off (In Progress)
I call it "Vulgar Display of Power"
1980 Silverado
Original paint
49k Original miles
4/6 drop
Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941
darkhorse970 is offline   Reply With Quote
Old 11-18-2009, 09:21 AM   #48
JJanzen
JJanzen's Avatar
Count me in....PM Sent
Blue72
Red72
JJanzen is offline   Reply With Quote
Old 11-18-2009, 11:32 AM   #49
rustyescott
rustyescott's Avatar
will this kit work on other years allso . ie 60-66 73-87 rusty
rustyescott is offline   Reply With Quote
Old 11-18-2009, 12:05 PM   #50
Rokcrln
Rokcrln's Avatar
I will be checking into it. Once I start getting the seals in bulk I can play with other years to see what works but it will take some time. These are the right seals for 67072's but may not be right for other body styles.
Kevin
LFD Inc.
