Old 07-20-2010, 11:55 AM   #26
hotrod1
56 - autocross
hotrod1's Avatar
Re: my 57 buid thread
Nice Build. We have decided to do the same suspension. Any suggestions? Did you box the frame completely? What is your desired end result?
hotrod1 is offline   Reply With Quote
Old 07-20-2010, 07:31 PM   #27
blindman
thanks i boxed just the front end back to the master cylinder nice set up i dont have exact measurements yet but its 5-6 lower than stock my only suggestion is c notch the rear and raise your shock mounting tabs 3 higher on frame if you want in weeds lmk if i can help
blindman is offline   Reply With Quote
Old 08-04-2010, 09:41 PM   #28
blindman
Old 08-04-2010, 09:58 PM   #29
hotrod1
56 - autocross
hotrod1's Avatar
Blindman
This looks great. Your build is close to the road that we are traveling. Do you have any side pics of the truck and the stance? What size tires and rims? Any other suggestions on the suspension? You mention that you would change the rear shock position up 3 inches to lower it a bit more. Does this seem to put it more in line with the front suspension? Do you know how far forward from the back of the frame that you marked your axle centerline? Where did you get the dash extension? Sorry for all the questions, but it is cool to find someone that has already done it and done it well.
Old 08-05-2010, 01:36 AM   #30
Tri5Nerd
Tripple Five Fanatic
Tri5Nerd's Avatar
If you don't mind me asking what type of air filter you are using now? I'm looking for something like that.
Tri5
1955 Chevy Stepside/LS1 drive train
http://67-72chevytrucks.com/vboard/s...d.php?t=371513
Tri5Nerd is offline   Reply With Quote
Old 08-05-2010, 05:42 AM   #31
blindman
Tri5
contact street and performance those guys are killer to work with lil pricy but they cater to ramjet and ls series aftermarket parts look at there site you wont be dissapointed
Old 08-05-2010, 05:48 AM   #32
blindman
Originally Posted by hotrod1 View Post
Blindman
i didnt move the rear shock mounts by moving them up it would level out the truck right now i got a 3 rake thats about right for me .. im gonna run 235/70r15 coker ww in rear and 215/70r15 cokers ww in front rims im not sure yet probably chrome reverse or radirs .... the dash extension i fabbed pretty easy just use a brake and measure twice i couldnt find a aftermarket one i liked so i made one i will be posting more pics in the next few weeks im trying to get it done before goodguys show in charlotte in october thanks for the compliments hows your ride coming along ?
Old 08-05-2010, 10:18 PM   #33
hotrod1
56 - autocross
hotrod1's Avatar
We are coming along OK. We have been trying to weld in the front IFS cross member and have had issues getting a good weld. It looks real contaminated, like molten. In fact, the weld has a slag on top of it like you would get when stick welding. Have tried TIG and MIG. We ground the frame and cross member well before starting but it did not seem to help. Need to figure out the problem. Did you have any luck with getting a good weld on your IFS to the frame?
Old 08-06-2010, 06:32 PM   #34
blindman
i had my friend mig weld it no problemd that i knew of ill ask him and see maybe not grounded good i dunno just guessing... ill let you know tommorrow what i find out
Old 08-17-2010, 12:43 AM   #35
hotrod1
56 - autocross
hotrod1's Avatar
Do you have any pictures of the truck from the side to see the stance and how low it sits? Did you go with the stock spindles or the lower ones?
Old 08-22-2010, 11:39 AM   #36
hotrod1
56 - autocross
hotrod1's Avatar
Blindman, we are about to install the rear shock mounts on the frame. We want a low truck that will handle, but one that can go over speed bumps and driveways with no issues. What is the frame height of your set up? How is the stock No Limit Suspension ride height? I am not sure I quite understand your statement about suggesting moving the shock mounts up 3? Is that 3" up (higher) on the frame? This would mean that you would have to build a mount extender, correct?
Old 09-03-2010, 03:55 PM   #37
blindman
ewww lala
Old 09-03-2010, 04:42 PM   #38
Kim57
Kim57's Avatar
That looks very nice.
Kim
Kim57 is offline   Reply With Quote
Old 09-03-2010, 05:00 PM   #39
hotrod1
56 - autocross
hotrod1's Avatar
NICE!!! I like any color as long as it is red.
Old 09-05-2010, 12:30 AM   #40
blackdiesel
blackdiesel's Avatar
amen to that!
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
http://67-72chevytrucks.com/vboard/s...light=speedway
blackdiesel is offline   Reply With Quote
Old 09-06-2010, 07:12 PM   #41
hotrod1
56 - autocross
hotrod1's Avatar
How did you know where to mount the transmission crossmember if you boxed the frame to the master brake cyl? Did you do an engine and tranny mock up before you welded it all shut? Did you weld nuts in the frame before you boxed it or are able to reach for the nuts to tighten them, or some other option? We are just about to weld it all shut but dont know where to mount (weld) the cross nuts. Thanks
Old 09-10-2010, 07:27 PM   #42
blindman
more pictures got some black out today check it
its ppg dbc9700 with concept 2002 clear
Old 09-10-2010, 09:12 PM   #43
Kim57
Kim57's Avatar
Thats shiny.
Kim
Old 09-11-2010, 12:47 AM   #44
ambryatim
ambryatim's Avatar
I like the black, but on post #42 last photo....look in the lower right corner between the cowl and the door....I actually like the color effect from the flash....kind of a dark purple...hmmmm. That would look good on one of the TF trucks IMO.
ambryatim is offline   Reply With Quote
Old 09-30-2010, 12:58 PM   #45
blindman
finally got some paint on her check it
Old 09-30-2010, 12:59 PM   #46
blindman
i think my camera lens needs cleaned
Old 09-30-2010, 02:05 PM   #47
a5Ben
Thats some sweet paint man!
a5Ben is offline   Reply With Quote
Old 09-30-2010, 10:04 PM   #48
Breader
Breader's Avatar
looks like some great progress
Breader is offline   Reply With Quote
Old 10-01-2010, 12:22 AM   #49
Kim57
Kim57's Avatar
Looks great.
Kim
Old 10-01-2010, 02:04 AM   #50
bobinbc
bobinbc's Avatar
Nice paint and nice straight panels! That represents a LOT of work. Check out the reflections on the door....
1962 Chevy blue SBFS
1957 Chevy yellow SBSS
1956 GMC red SBSS Nov 2017 ToTM
https://www.facebook.com/groups/Cana...geChevyTrucks/
bobinbc is offline   Reply With Quote
