Old 08-30-2010, 05:55 PM   #26
Bugeyev8
Bugeyev8's Avatar
Re: My 1962 C10 Build Thread "Grandpa's Truck "
doors
Bugeyev8 is offline   Reply With Quote
Old 08-31-2010, 12:26 AM   #27
Captainfab
60-66 Nut
Looks good
You're making some nice progress.
Old 08-31-2010, 12:54 AM   #28
amueller454
amueller454's Avatar
Nice work so far!
i noticed on the interior side of the door where you have the holes for the speakers that the two body lines stop before. what did you do to change the ends of the body lines?
1960 short bed fleetside factory 4x4
1960 panel 454 NV4500 Daily driver
1961 Short Bed BBW Fleetside 5.3 th400 swap in process
amueller454 is offline   Reply With Quote
Old 08-31-2010, 02:55 AM   #29
Bugeyev8
Bugeyev8's Avatar
Originally Posted by amueller454 View Post
Nice work so far!
Good eye, its the little details..
I cut the rib in the center and re shaped the metal and welded it up, I did not really want to cut the holes but really there is no other way if you want decent sound and it gave me acess to clean and treat the rust and I actually Por 15 the inside of the doors and installed dynamat too
Old 08-31-2010, 02:56 AM   #30
Bugeyev8
Bugeyev8's Avatar
Originally Posted by Captainfab View Post
Looks good
Thanks man !! the progress is very very slow. its hard to stay motivated on this thing
Old 08-31-2010, 06:49 AM   #31
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Nice work on all the repairs and modifications. It may seem tedious now, but it's going to look great when your finished. Your family legacy will live on.
Old 09-02-2010, 03:02 PM   #32
Bugeyev8
Bugeyev8's Avatar
got the hood sprayed with epoxy high build...needed to get some protection on the metal..because of my lazy ass not venting the dryer properly...everything in the garage gets a nice coating of rust, still needs alot of work
Old 09-02-2010, 03:05 PM   #33
Bugeyev8
Bugeyev8's Avatar
did the tailgate mods a while back, got a perfect tailgate...this pos was the test bed
Old 09-02-2010, 03:10 PM   #34
Bugeyev8
Bugeyev8's Avatar
lots of work in these damn things, I have 6 of these things and these are the only set that fit right, little rust repair and body work and coated the insides with por 15, filled the emblem holes while at it, these are straighter now than they were from the factory !!
Old 09-02-2010, 03:15 PM   #35
Chris65GMC
Looks Really good! Any chance you could do a step by step on the rocker replacement?
Thanks!
Chris
Chris65GMC is offline   Reply With Quote
Old 09-02-2010, 03:22 PM   #36
Bugeyev8
Bugeyev8's Avatar
Thanks!
Chris
I don't know if I have enough pics to do that
I am not a big pic taker, I will see what I can find
I have been doing this for a long time, what are you wanting to know?
Old 09-02-2010, 03:46 PM   #37
Bugeyev8
Bugeyev8's Avatar
step one
was to remove the old rocker...I see alot of prople trying to grind and drill the spot welds out...this is a waste of time, cut the outer rocker in smaller pieces using a cutoff wheel or tin snips, as to make it easier to remove, the smaller pieces allow you to just twist and pull the spot welds loose, the panels I worry about distorting I take a flapp disk and grind the spot weld area down, the metal will turn blue very fast when its getting thin..then just use a chisel and a vise grip and pull the old metal off, along the lower rocker spot wekds cut the rocker so that just about 1/2 inch of teh rocker is there, then take your chisel and start between a pair of spot welds and start to roll the metal up with your vise grips like you are opening a tin can, rock the vise grips when you come to a spot weld and the spot weld will break, remember spot welds are only strong in multiples , a single one is very easy to break
step 2
Grind and clean all loose rust and grind all spot welds down, clean and treat metal with metal etch, I used phosphoric acid and then treated al areas where I was not going to weld with POR15
Step 3
if you are just doing the rocker test fit and use a few screws to align it while you are working, be sure to have the door installed and adjusted before fitting the rocker , its very IMPORTANT to have the door installed, I had to massage the new rocker in the front where it slips over the pillar to fit perfect, if you are using a mig welder drill holes on the new rocker where the old one has spot welds, I used a spot welder along the lower seam, don,t weld anything till you are happy with the fit
step 4
weld it up and grind to your liking then shoot with epoxy primer and then seam seal and another coat of epoxy
If you are changing the inner rocker you will need to do that first, I fabbed the inner rocker and the repair panel for the kick panel and floor, I ordered a inner rocker from LMC and then Brothers and was not happy, the floor was rotted more than it would cover, and I did not want to buy a whole floor section...so I just fabbed it up, templates out of cardboard and then off to the brake with some 18 gauge
Just be sure to fit everything before you weld anything, use sheet metal screws, the inner rocker goes on first and then the pillar support and then the outer rocker
I will dig up more pics if I have them and post them for you
Old 09-02-2010, 03:50 PM   #38
Bugeyev8
Bugeyev8's Avatar
more pics
Old 09-02-2010, 04:33 PM   #39
Hanky
Hanky's Avatar
Man am I glad I found this build. Looks fantastic. I will be sure to use your wisdom as refrence for my 62' Thanks in advance. Damn shame you are not in Texas lol!
Hanky
Hanky is offline   Reply With Quote
Old 09-03-2010, 12:15 PM   #40
Chris65GMC
Originally Posted by Bugeyev8 View Post
more pics
Thanks! this is a great start. Is it ok to do the inner and outer rocker with the door on?
Thanks!
Chris
Old 09-03-2010, 01:59 PM   #41
Bugeyev8
Bugeyev8's Avatar
Thanks!
Chris
The door will have to come off to do the work. also the front fender will need to be removed if your door fits good now...you may want to drill some alignment holes in the hinges, I use a 1/8 drill bit, makes it faster to get the door back on in the correct place
Old 09-03-2010, 02:02 PM   #42
Bugeyev8
Bugeyev8's Avatar
other side pics
Old 09-03-2010, 02:04 PM   #43
Bugeyev8
Bugeyev8's Avatar
more
Old 09-04-2010, 12:47 AM   #44
Captainfab
60-66 Nut
Yes the door will need to be removed as Bugeyev8 said. However you will want to do one of two things when replacing the rockers. 1) if the original rocker is somewhat complete, take a couple measurements from the rocker to the top of the door opening. This way you can install the new rocker in the same location as the original. 2) you will need to re-install the door after you have the rocker clamped into place to check the lower door to rocker gap.
Thanks!
Chris
Old 09-16-2010, 12:39 PM   #45
Bugeyev8
Bugeyev8's Avatar
got some work done on the underside of the hood this week, stripped it to the metal and gave it a few shots of epoxy, still deciding about what to do..paint it color of truck...black or do a light spray of bedliner and then paint color of the truck ??
Old 09-16-2010, 11:08 PM   #46
narx66gmc
same color as your engine compartment will be. the project looks like it is coming along nicely.
Build Thread - Papa's truck build up
narx66gmc is offline   Reply With Quote
Old 09-29-2010, 08:30 PM   #47
Bugeyev8
Bugeyev8's Avatar
Got the rear bumper installed today, I fabbed the brackets and the hidden reciever hitch too, I used the smaller hitch because after I fabbed the bumper brackets where I wanted them I had no room for the 2 inch class 3, oh well in all the years of towing I never towed anything over the 4k rating on the reciever anyway...at least its in the done pile now !!
Old 09-29-2010, 08:31 PM   #48
Bugeyev8
Bugeyev8's Avatar
more pics
Old 10-15-2010, 04:46 PM   #49
Bugeyev8
Bugeyev8's Avatar
Got a bit more work done on my 62 today, got the repaired hood test fitted...need a new DS hinge I guess...it wont pull down in the ds rear corner, got the interior sanded and prepped for paint, a little more sanding and a hit with pre paint cleaner and a few shots of epoxy and the gold interior color will fly, plan is to shoot the interior hang the new repaired doors , paint the jambs and the area around the glass and re install the interior and glass and drive it again for a while before I blow it apart for a full paint job
Old 10-18-2010, 05:44 PM   #50
Bugeyev8
Bugeyev8's Avatar
got the inside of the cab prepped and primed with epoxy primer, block it tomorrow AM and shoot the color and then reassemble...the work never ends
1962, lsa supercharger, rust repair, tuned port
