Closed Thread
Old 01-17-2010, 10:42 AM   #26
Gemp
Gemp's Avatar
Re: Custom 1987 GMC Crew Cab Short Bed
<--------In
06' GMC 1500 Crew cab.....
Gemp is offline
Old 01-17-2010, 03:21 PM   #27
OYMC
It's Raining...
Axle is out...
OYMC is offline
Old 01-17-2010, 07:07 PM   #28
Hoffman65burb
Hoffman65burb's Avatar
Heres a cool lookin crew cab short box
1978 GMC Jimmy
454bbc
Turbo400
NP205
3.73 gears
4inch lift
33's
Hoffman65burb is offline
Old 01-17-2010, 10:25 PM   #29
Stitch
Location: Where I come from, it's cornbread and chicken...
I didn't think that thing was ever going to get out of the bowl...
Stitch is offline
Old 01-17-2010, 11:56 PM   #30
Patriot
In
Patriot is offline
Old 01-18-2010, 10:35 AM   #31
justpball
justpball's Avatar
scoot over guys, i brought peanut M&Ms if anybody want some...LOL
Fuzzy Dice Club Member
87 Crew SWB
Build for the crew
http://67-72chevytrucks.com/vboard/s...d.php?t=430082
http://www.cardomain.com/ride/3232925
90 burb 2wd
Build Thread For The Burb!
http://67-72chevytrucks.com/vboard/s...d.php?t=383055
justpball is offline
Old 01-18-2010, 11:48 AM   #32
CHEESE
The Cheesiest
CHEESE's Avatar
Mmmmm pop corn! Looks like a fun build!
CHEESE is offline
Old 01-18-2010, 12:43 PM   #33
dan76
Originally Posted by OYMC View Post
It's Raining...
In CA?????
dan76 is offline
Old 01-18-2010, 01:05 PM   #34
Restrorob
The One And Only !!!
Restrorob's Avatar
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Restrorob is offline
Old 01-18-2010, 02:45 PM   #35
OYMC
Looks like rain until Wednesday or Thursday...
We really need the rain, but it's killing me right now!
I'm in Northern CA. by Chico
I'm building a 1955 GMC 4x4, which fits nicely in the shop, and out of the rain... I'll upload my photos, and post today:
1955 GMC deluxe cab short bed
Dana 44 8 lug front axle
14 bolt FF rear
1/2 ton 4" skyjacker lift
700r4 w/ 205 transfer case
OYMC is offline
Old 01-18-2010, 11:48 PM   #36
OYMC
Here are the photos of my 55 GMC 4X4 front leaf spring mounts.
The previous owner welded the stock spring mounts off a 1979 Chevy 1/2 ton truck to the 55' frame rails. He set the axle center line to far back (If he meassured it at all, and as a result, the tire was hitting the back of the fender, and had miles of clearance in front of the tire.
I think my mounts look better
After cutting the old mounts off with a plasma, I finished surface prep with a grinding wheel, and finally a 5" sander.
Bumper nuts were welded to the inside of the chassis. I will be bolting the bumper brackets to the outside of the frame rails.
Drilled out the bottom of the chassis in two places using a 3/4" drill bit, where the new mounts were welded. This aloud me to weld directly to the new mounts (Through the chassis holes), and as the whole filled in with the weld puddle, it penetrated the chassis (Outer edge of drilled holes), this gave the mounts additional holding strenght.
The mounts were made of 1/4" wall, 4X4" box tubing...
The rain has kept me from the crew cab, but not the 55' (It's in the shop)!
OYMC is offline
Old 02-02-2010, 06:04 PM   #37
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Cool project! hopefully you aren't planning on using big turbos for the 6.2. It might not like to spool them at lower rpm's. Any info on what you're planning? It sounds pretty cool!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline
Old 02-03-2010, 01:41 AM   #38
OYMC
Well, as far as the turbo's are concerned, I am going to run a two stage twin turbo setup. The first turbo will be a quick spool (Smaller Turbo) for low end power, and the second will be slightly larger, allowing for higher RPM power...
This setup is similar to a Toyota Supra twin turbo.
After I have determined the proper turbo mapping for my 6.2, I'll post the results...
Right now my focus is on building the chassis, but as soon as it is done, I'll be attacking the motor and drive train....
I'm thinking of running an NV4500 with a Hydraulic clutch...
I haven't looked into adapters yet, but I'm hoping I can use my 205 transfer case... Anyone have any leads?
OYMC is offline
Old 02-03-2010, 02:16 AM   #39
CLASSIC87'
OL BLUU
CLASSIC87''s Avatar
Looks like I got a seat before the previews were over... I'm grabbing a magazine and beer. Let's kick it!
CLASSIC87' is offline
Old 02-03-2010, 02:21 AM   #40
Dieselwrencher
You can use a 29 spline dodge NP205 from a 1989-1993 dodge d250 and d350 with a getrag 5 speed. Then you can use a 29 spline mainshaft in the nv4500.
Ryan
Old 02-03-2010, 09:50 AM   #41
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Originally Posted by wfomkivdrvr View Post
I'm watching too i've seen the adds on craigslist too! Is the front axle a dana 44?
Definately a 44. Someone probably took the 60 out years ago to build a rock crawler of some sort.
--Josh
STOCKISH is offline
Old 02-06-2010, 12:28 AM   #42
OYMC
Yep, it's a 44... The previous owner sold the Dana 60....
Now, as far as a Dana 44 being a weak axle... Give me a break (Ha, ha). I have never seen a broken Dana 44 unless it was in a rock crawler...
Any "Talented" person building a crawler would laugh at the idea of using a crew cab 1 ton truck... So, now the smart A#$'s are going to post photos of crew cab crawlers.
Here is the equation: Light, low, equally distributed weight + short (But not to short) wheel base = Crawler
Here is what I have: Extremely nose heavy + long wheel base = Christmas tree getter, and a "Pavement Princess". Yep, I said it! I'll leave my wheelin' up to my land cruiser, and the cruisin' up to my Chevy...
So here are a few update photos:
Installed front 8" skyjacker springs, and wheels...
OYMC is offline
Old 02-06-2010, 12:32 AM   #43
OYMC
One other note:
I just bought a 2 wheel drive power steering box. This will be used to convert the factory push - pull style steering over to a cross over steering system. The splines on the 2wd steering box will allow the pitman arm to be install at 90 degrees from it's original position. The original pitman arm will not be used.
OYMC is offline
Old 02-06-2010, 12:42 AM   #44
Dieselwrencher
Very cool! Nice progress!
Ryan
Old 02-07-2010, 06:40 PM   #45
87 chevy silverado
nice build
87 chevy silverado is offline
Old 02-07-2010, 09:22 PM   #46
Restrorob
Restrorob's Avatar
Man, I got a nose bleed just lookin at the pics !!!
And that's not good with salt and butter all over your fingers....
Lookin good.
93 Jeep XJ
88 Buick La Sabra
Toys;
97 GMC Ext. Cab
Old 02-28-2010, 01:36 AM   #47
OYMC
Little by little...
1. Pulled saddle tanks
2. Cut off unneeded cross-members / parts
3. Took some measurements and placed some tentative marks on chassis (Playing with different ideas)
Next steps
1. Strip Chassis of rust and paint
2. Make final cut marks and measurements
3. Weld Chassis back together
4. Install new springs (6" skyjacker)
5. Set Pinion angle on rear axle, and weld on new spring perches 2 1/2" lift (No blocks)
I hope to have the above completed by next weekend...
OYMC is offline
Old 02-28-2010, 09:01 AM   #48
Restrorob
Restrorob's Avatar
Thanks for the progress report, Keep those pics a comin !
93 Jeep XJ
88 Buick La Sabra
Toys;
97 GMC Ext. Cab
Old 03-07-2010, 12:28 AM   #49
OYMC
The frame is cut...
The stock short bed measurements were taken from the trailing edge of the rear bed mount bolt hole to the leading edge of the front bolt hole mount which came to 71 5/8".
To keep the factory gap between the cab and the bed I decided to make my cut 1 1/2" behind the front bed mount bolt hole.
Now remember, we are measuring from leading edge of bolt hole mount to trailing edge of bolt hole mount. It is always a good rule to measure from either a leading edge or trailing edge, but not from center. Many times bolt holes are not perfectly round from wear, or by design so find the edge of the bolt hole, measure back to a point of reference. The point of reference used should be relative in location for both chassis rail measurements. Make a scribe line that is equal in measure from the point of reference to the leading or trailing edge of bolt hole. *If I have lost you just refer to photo.
OYMC is offline
Old 03-07-2010, 12:34 AM   #50
OYMC
Now to set up the rear mark.
From the trailing edge of the rear bed mount bolt hole on chassis I measured 71 5/8" forward on chassis, and made a temp mark. Because I decided to use the stock bed mount bolt hole on the chassis, I measured 1 1/2" back from my temp 71 5/8" mark.
Remember to make a reference mark on the rear bed mount bolt hole on chassis to keep all measurements square to each other.
OYMC is offline
Closed Thread
