Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 02-02-2010, 04:05 PM   #26
CWT
Re: 60-66 Big Red Heavy Chevy C60
Here is a GMC I seen here in town. He was a auctioneer from KY.
CWT is offline   Reply With Quote
Old 02-02-2010, 07:49 PM   #27
nbrfd007
nbrfd007's Avatar
That's Nice!
nbrfd007 is offline   Reply With Quote
Old 02-03-2010, 08:53 PM   #28
hugger6933
I have been thinking about a c40- c-60 in the 67-72 model range because that is the models of trucks I am building currently. My brother in law just retired from farming and said I could get his trucks. He has a 61 with a 409 and a 65 with a 6 cyl. What rear gear ratios would something like that have? Been thinking about a rollback bed on one to haul my wrecks from the sale. The plan with the c50 [67-72] would be a late model 6.0 or a duramax maybe with tilt steering and late model seats and air. Jim
hugger6933 is offline   Reply With Quote
Old 02-03-2010, 10:01 PM   #29
j.kirn
Im not into the modifications of these trucks i like the way they came from factory
j.kirn is offline   Reply With Quote
Old 02-03-2010, 10:07 PM   #30
bushytlb
bushytlb's Avatar
j.kirn; I've got to get under it and see what it looks like. If sheet metal is good. Maybe. I'm acting as if I am. rims tires, starter, battery, two speed vacuum switch, probably the rubber diaphragm needs replacing rear brakes. So you know some other miscellaneous issues. Rest assured that you will be the first to know. I recently found a Gmc 73-80 something. May be coming out of fire service. Got to continue to do some reserch. bushy
bushytlb is offline   Reply With Quote
Old 02-03-2010, 10:20 PM   #31
Woogeroo
bushy, good find.
J.kirn - that is a sweet truck!
judging from the doors, I'd guess it's a 64-66.. but I'm not 100% sure if they swapped doors/cabs at the same time as the smaller trucks.
The stovebolt page has a 'big bolts' section for the 1.5 ton and bigger trucks. Check out the site and go to the forums, then Big Bolts.
-W
Woogeroo is offline   Reply With Quote
Old 02-03-2010, 10:48 PM   #32
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
the first truck posted is a 66....
Old 02-07-2010, 03:27 PM   #33
Eagletucky
Where did THAT bolt go?
Eagletucky's Avatar
Are the inner fenders and core supprts the same as a c10?
Just curious, I have a line on a c60 cab, i could get the inner fenders and core supprt if its the same as a c10.
The Swiss Car Club......A drinking club with a car problem....
Eagletucky is offline   Reply With Quote
Old 02-07-2010, 04:49 PM   #34
jonzcustomshop
1961 crewcab
the inner fenders and core support are taller than a c10, I heve a good set of inners that I think I can modify for one of my 1/2 tons, I havent tried yet , but I think I just need to trim about 4 inches off the bottom....
