Old 02-20-2010, 12:17 AM   #1
Tony_SS
Tony_SS's Avatar
Re: Here is my 1990 Suburban
I cant imagine going smaller on the tires with a 6" lift though??
Tony_SS is offline   Reply With Quote
Old 02-28-2010, 01:03 AM   #2
RIDDLA
RIDDLA's Avatar
Good lookin burb
68 GMC-Stripshow
70 Chevy Monte Carlo
72 Chevy Monte Carlo LOLO
72 Chevy Suburban Blurban
74 Vw Bug
78 Chevy k10 lwb
78 Chevy k10 swb
03 Cadillac Escalade-Duecesix
84 Cadillac Coupe Deville DeElegance
B.O. A Lifestyle Money Cant Buy!
Win,Lose, or Tie
I'm a Raider till i die
RIDDLA is offline   Reply With Quote
Old 03-06-2010, 10:39 AM   #3
bigblock79
67 Chevy Stepside
bigblock79's Avatar
i would love to have that lift hint hint
1967 Chevy stepside
1976 BIG DOOLEY 454 turbo 400 4:11
bigblock79 is offline   Reply With Quote
Old 03-06-2010, 05:37 PM   #4
1976K5CHALET
1976K5CHALET's Avatar
Caster can make that same issue...however it is highly unlikely that is your issue.
First thing i'd do is give the front end a once over to see where your at parts wise...then decide what lift tire combo you want vs. gear ratio...
Years ago my 79 K5 had a 4 inch lift...and 33" tires. I ended up going to 4.10 gears to get it back in the power band. I always thought that combo was the best...and you can wheel hard and stuff the tires and never effect the turning ratio and or crinkle fenders...once you hit 6"s and 35's you are going to rub.
DW
Doug Wright aka K5NUTT over @coloradok5.com
Owner of http://groups.yahoo.com/group/ChevyK5BlazerChalets
Certified K5 Nut
1976K5CHALET is offline   Reply With Quote
Old 03-06-2010, 06:08 PM   #5
Tony_SS
Tony_SS's Avatar
I think I like the 6" lift now, with the 33's. So I'm going to stick with it for awhile.
I just replaced a leaky trans gasket and changed the oil/filter. Everything looks great underneath and no more leaks...... until, I saw a drip of antifreeze.
I'm going to put in a new radiator as this one look original, and I'll tighten up any leaks along the way.
After that I'll get back to the drivabilty issues.. It needs tires bad.
Old 03-11-2010, 02:25 PM   #6
Tony_SS
Tony_SS's Avatar
Just an update. Since the warm weather, I was able to replace the radiator with those new plastic tank/alum ones. (they are light). I also replaced the t-stat with a fel-pro oring gasket (nice too), the upper and lower hose and heater hose. All were very corroded inside. She now runs a consistent 180º with no more anitfreeze leaks. The trans pan doesnt leak anymore either.
I double checked the psi in the tires and found 45 in the drivers side and low 20s in the pass side. This explains why it handled horrible I think. I put 36 in them all and it rides nice and straight. I drove it around plenty today and she really rides nice.
Next up is a stereo and some more cleaning. Then eventually tires. Im open for suggestion on tires if anyone has any.
Old 03-11-2010, 02:35 PM   #7
Jonboy
Slots go on anything!
It's hard to go wrong with BFG All Terrain TA's for looks and decent street manners. I've always had good luck with them, and like the way they look, too. I'd run a 35/12.50 with your lift.
1974 Jimmy- 5.3/4L80e/NP241
Old 03-11-2010, 03:59 PM   #8
68Timber
I know the pieces fit
68Timber's Avatar
Ditto that. They look killer and run as quiet and tight as regular highway tires. But be prepared for sticker shock, at that size you'll spend most all of a grand on them, even at Sam's, but at least road hazard, yearly balance and rotation comes with the deal.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 03-11-2010, 04:57 PM   #9
cochino12
It followed me home?
cochino12's Avatar
Im with these guys about the BFG A/T, Thats all I run on my 4x4's. I've got over 45k on my current set.
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 03-11-2010, 05:20 PM   #10
68Timber
68Timber's Avatar
Ditto the 40K+.
Forgot to say, they will wear a long time. Those tires don't wear out quick like the cheap copies.
John
74 Honda Z50 build
Old 03-11-2010, 06:23 PM   #11
Tony_SS
Tony_SS's Avatar
I was looking at them, but yes the price is up there. Sounds like I'll get what I pay for with them though. You guys think I should go 35x12.50's??? Or should I stick with 33's?
I'll have to measure to see if it still fits in the garage sitting another 2" higher.
And I'd like the tires to have nice street manners... judging by the tread design that does not look like the case, but I did run a set of these years ago, and I do remember them riding very nice and quiet. I like the feedback on the mileage.
The other tire I was looking at was the Yokahoma Geolanders. They run around $150 and have a 40k milage rating. Any feedback on those?
Old 03-11-2010, 06:28 PM   #12
cochino12
cochino12's Avatar
with a 6" lift I would go with 35"s
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 03-11-2010, 07:43 PM   #13
68Timber
68Timber's Avatar
Tony, I hate to say this because I've bought one big set of BFG AT once for a F250 Super Duty Diesel I had a little over a year ago.
They are expensive. If you don't have the cash, get out the CC like I did.
It's worth it. The look is insane and they are quality tires that will last long enough to get your money back out of them.
That truck is a keeper, if you can swing it put the 35" BFG AT's on it.
John
74 Honda Z50 build
Old 03-11-2010, 07:51 PM   #14
CLASSIC87'
OL BLUU
CLASSIC87''s Avatar
It will only sit an 1" higher... not 2". I also had the BFG All Terrian... they were awesome in appearance and quality... and go with the 35x12.50.
CLASSIC87' is offline   Reply With Quote
Old 03-12-2010, 12:47 AM   #15
Driveway Dreams
I have car A.D.D.
Driveway Dreams's Avatar
I can not disagree at all on the BFG's. I had 2 sets on a Samurai a few years back. Very good on road. Great in snow, great in mud, awesome on rocks! Just all around PERFECT tires. I would never run another type of A/T tire if I can help it.
-Gerald
Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace.
61 GMC Suburban SOLD
The 86 build thread SOLD
Are you a Colorado member?Click here.
Driveway Dreams is offline   Reply With Quote
Old 03-15-2010, 10:01 PM   #16
78swest
78swest's Avatar
i just picked mine up to today 38 inch tires 10 inch lift it floats harcore i know what my problem is ....steering box is toast and the middle link is shot its a dropped s middle link i just need new ends
78swest is offline   Reply With Quote
Old 03-31-2010, 06:39 PM   #17
abebummy26
abebummy26's Avatar
Washington heh? I've been trying to escape New Haven for a while now still haven't managed to I'll have to keep an eye out for your rigs man.
-Lincoln
1987 GMC S15 (soon to be a chevy clone)
2.5l, 4 speed, no ps, no pb, no ac
Silence is golden, but duct tape is silver.
Spoken by Cletus the hillbilly
I like stickers... a whole bunch.
abebummy26 is offline   Reply With Quote
Old 03-31-2010, 10:12 PM   #18
Tony_SS
Tony_SS's Avatar
Hey neighbor! I'm always around town somewhere.. its hard to hide in this thing.
Update, I"m getting 35" BFG A/T put on tomorrow... so I'll have to update here with some pics.
I guess I'll be using D more the OD until I can upgrade the 4.56's too.
Old 04-01-2010, 01:47 AM   #19
y5mgisi
Second Chance Program
y5mgisi's Avatar
Why cant i see the pics! I want to see them so bad!
y5mgisi is offline   Reply With Quote
Old 04-01-2010, 08:09 AM   #20
justpball
justpball's Avatar
post up some pics bro as soon as you can.
Fuzzy Dice Club Member
87 Crew SWB
Build for the crew
http://67-72chevytrucks.com/vboard/s...d.php?t=430082
http://www.cardomain.com/ride/3232925
90 burb 2wd
Build Thread For The Burb!
http://67-72chevytrucks.com/vboard/s...d.php?t=383055
justpball is offline   Reply With Quote
Old 04-01-2010, 02:05 PM   #21
Tony_SS
Tony_SS's Avatar
New 35's!
Old 04-01-2010, 03:41 PM   #22
68Timber
68Timber's Avatar
That's the way you do it.
That truck is insane, love it, want it.
John
74 Honda Z50 build
Old 04-01-2010, 04:13 PM   #23
abebummy26
abebummy26's Avatar
nice work looking sweet!
-Lincoln
Old 04-01-2010, 04:13 PM   #24
Jonboy
That looks great, Tony.
Old 04-01-2010, 04:21 PM   #25
Tony_SS
Tony_SS's Avatar
local shop says I should go with 4.88's. $1300 for the job front and back...
