Old 05-04-2010, 08:12 PM   #26
jyaughn
jyaughn's Avatar
Re: my first 62
got my new rocker put on but found out that when i welded in my patch panel for the lower part of the door i warped the front corner. does anyone know how to fix this?
jyaughn is offline   Reply With Quote
Old 05-04-2010, 08:59 PM   #27
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Re: my first 62
Got any pics??
Alan's Classic is offline   Reply With Quote
Old 05-04-2010, 09:01 PM   #28
jyaughn
jyaughn's Avatar
Re: my first 62
its too dark outside. th hole corner is pulled in to far and doenst sit flush with the rocker
Old 05-04-2010, 10:32 PM   #29
Alan's Classic
Re: my first 62
Trying to visualize this. I would try to bump it back out from the inside with a block of wood and hammer. Don't beat the heck out of it. A little at a time. Then fine tune it with hammer and dolly. If you have a slide hammer with a L shaped flange that you could put on the inside of the door skin with the door closed and slowly bump it out. You can see it move and stop when it gets close to lining up with the rocker.
Old 05-05-2010, 07:42 AM   #30
jyaughn
jyaughn's Avatar
Re: my first 62
do i need to cut my patch panel off?
Old 05-06-2010, 11:49 PM   #31
Alan's Classic
Re: my first 62
I would say no for now.
Old 05-07-2010, 12:16 PM   #32
jyaughn
jyaughn's Avatar
Re: my first 62
ok ill try the hammer and dolly and see what i can get
Old 05-07-2010, 02:03 PM   #33
irish1966
irish1966's Avatar
Re: my first 62
First off, looks like you are flying. Looks great. I'd be interested in seeing how the warped panel looks. I am about ready to do the same work you are doing. I got the old rocker cut off and it's kinda making me think long and hard about doing the patch repair after reading yours and some other guys talking about warping during welding.
Cheers
David
66 LWB Fleet (on hold)
64 LWB Fleet (daily driver)
65 SWB Fleet (almost finished as a driver)
64 SWB Fleet (just started - "Tommys Hot Rods" tribute truck)
Nothing worth doing, is easy.
irish1966 is offline   Reply With Quote
Old 05-07-2010, 04:40 PM   #34
jyaughn
jyaughn's Avatar
Re: my first 62
i hammered mine out it it all lines up good now. as for welding on the doors i would spot weld it instead of fully welding it up like i did. after you spot weld it get some fiberglass jell to go over everything and it will look good. it takes alot of sanding but mine is coming out pretty good for my first time doing any panel replacing.
Old 05-07-2010, 04:40 PM   #35
jyaughn
jyaughn's Avatar
Re: my first 62
its not as hard as alot of people make it seem.
Old 05-07-2010, 04:43 PM   #36
jyaughn
jyaughn's Avatar
Re: my first 62
still got alot of sanding to do
Old 05-07-2010, 04:44 PM   #37
jyaughn
jyaughn's Avatar
Re: my first 62
and if you cant tell all this is going on in the back yard. no shop no carport not even level ground. i just work on her alittle everyday after work
Old 05-07-2010, 04:48 PM   #38
irish1966
irish1966's Avatar
Re: my first 62
Looks good man. What kind of welder are u using? How did u find the rockers? I'm looking at mine and thinking I may have to replace the lower cab supports. They are rusted at the bottom, but then I'm thinking i might just weld in some pieces and bang in the rockers. All this thinking is bad for me. lol
Cheers
David
Old 05-07-2010, 09:33 PM   #39
jyaughn
jyaughn's Avatar
Re: my first 62
i just had to replace my front cab support. its not hard just cut trim your patch panel and weld it in. im using a crapy welder. its one of those little ones that dont require gas it has the flux built on the wire
Old 05-08-2010, 01:46 PM   #40
jyaughn
jyaughn's Avatar
Re: my first 62
slowly but surly
Old 05-08-2010, 03:05 PM   #41
daverod
SSN 706
daverod's Avatar
Re: my first 62
I think the best idea is to just replace the part that is bad insted of trying to make the whole panel fit. I was talking about the doors. The rocker looks nice. Make sure your doors line up with it before you weld it for good.
daverod is offline   Reply With Quote
Old 05-08-2010, 11:04 PM   #42
jyaughn
jyaughn's Avatar
Re: my first 62
i did everything looks good. the reason i did the whole bottom patch panels on the doors was because the bottoms where completely rusted out.
Old 05-11-2010, 10:08 PM   #43
TimE
Hey Y'all!!
TimE's Avatar
Re: my first 62
Nice work so far. Keep it up!
Just hopin' I live long enough to finish something!!!
TimE is offline   Reply With Quote
Old 05-11-2010, 10:41 PM   #44
jyaughn
jyaughn's Avatar
Re: my first 62
thanks
Old 05-12-2010, 12:53 PM   #45
REDNOSE65
REDNOSE65's Avatar
Re: my first 62
this is my first 62 chevy short bed step side truck. i sold my jeep a few weeks ago and bought it. i am 20 years old and work in fast food so my build will be slow. this is how she looked when i first got her.
Good choice of truck...I'ts always cool to see younger cats into these trucks.
Doing good on the progress too...keep up the good work!!!
RED NOSE '65
LOS HITTERS C.C
DALLAS, TEXAS
The making of a Red Nose...
http://www.67-72chevytrucks.com/vboa...d.php?t=396518
REDNOSE65 is offline   Reply With Quote
Old 05-12-2010, 02:09 PM   #46
jyaughn
jyaughn's Avatar
Re: my first 62
doin some body work today before i go to work. also workin on my buddys tahoe
Old 05-14-2010, 09:51 PM   #47
jyaughn
jyaughn's Avatar
Re: my first 62
my step moms mustang my dad and i painted today. sorry no work to the chevy
Old 05-22-2010, 10:52 AM   #48
jyaughn
jyaughn's Avatar
Re: my first 62
the new motor. vortec 454
Old 05-22-2010, 09:23 PM   #49
scotts62
One day...
scotts62's Avatar
Re: my first 62
Cool! Going in the 62? Good looking stepper you have there
Scott
93 crew cab build
Project 62
Old 05-22-2010, 10:57 PM   #50
jyaughn
jyaughn's Avatar
Re: my first 62
yep thats going in my truck. thanks yours looks better tho
