Old 07-23-2010, 09:24 AM   #26
blitz'd
vintage car junkie
blitz'd's Avatar
Re: project: WTF did I get myself into 50 chevy
Thanks guys, I really need to update this thing. Its all back together now, all painted minus the bed since ive been reading kabwe's build thread ive got some ideas brewing for that. I finally realized im not going to be happy with my frame setup so im thinking about an S-10 swap. Ill try to put the grille and bumper on and take some pictures. Just finished remodeling my house so its been crazy lately.
1950 chevy truck, s10 swap, bagged, v8, 18s
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=392761
blitz'd is offline   Reply With Quote
Old 07-23-2010, 03:06 PM   #27
Tanman
Tanman's Avatar
What type of rims are those? Is the group buy still available?
Tanman is offline   Reply With Quote
Old 09-22-2010, 11:22 PM   #28
blitz'd
vintage car junkie
blitz'd's Avatar
Well time to get back on track with this thing. I got it all mocked up tonight on the S10 chassis I got saturday. Trying to decide where I want the wheel to sit in the front fenders. I like it pushed back off center a little I think.
Ill throw the bed on tomorrow, I need to move the axle back a few inches since its a SWB S10. Plan was to take a few inches out of the bed anyway and maybe make the front of it curve more with the back of the cab. We will see. The frame should be going to see Slammy for the rear suspension this weekend, while he is doing his thing I need to fix some bodywork im not happy with. That fender was painted but when I drove it with the old frame I screwed it up. I also messed up the driver cab corner when I took the cab off, and chipped the driver door. BTW if it hasnt been said before CAMARO CLIPS ARE TOO WIDE FOR THESE TRUCKS. lol.
I love the deep lip on the rears but man they look small, the 20s dont have this much lip.
Old 09-22-2010, 11:23 PM   #29
blitz'd
vintage car junkie
blitz'd's Avatar
Boss 338s, seems to be some drama going on with the group buy right now so I would say no.
Old 09-23-2010, 04:11 AM   #30
55dude
55dude's Avatar
great project so far! the clips that work are the GM a-body 78-85.
55dude is offline   Reply With Quote
Old 09-23-2010, 10:48 AM   #31
53GMC
53GMC's Avatar
im new to doing a bunch of body work...what type of body filler did you use....how did you get it so smooth?
thanks for helping me with my chronic stupidity
1953 GMC/S 10 Swap
http://67-72chevytrucks.com/vboard/s...d.php?t=357365
53GMC is offline   Reply With Quote
Old 09-23-2010, 12:05 PM   #32
blitz'd
vintage car junkie
blitz'd's Avatar
This is my 1st full body work and paint job too man. I used rage filler then blocked with 180, most of the truck got 3-4 coats of high build with block sanding in between then a sealer. There is still things im not happy with, like when I painted the cab I didnt use a sealer and you can see some variation in the sun on the roof. I missed a wave under the body line on that driver corner also.
Live and learn. Thats what this hobby is all about for me, the learning process. I normally dont keep cars long after I build them, building them is the fun part.
Old 09-23-2010, 02:27 PM   #33
53GMC
53GMC's Avatar
thanks man....im going to get me a can of that stuff...looks like lot better stuff than what i was using here and there....im going to slap some of that on the old girl and see if i can't smooth her out some!!
love your project and thanks again!
1953 GMC/S 10 Swap
Old 09-23-2010, 11:23 PM   #34
blitz'd
vintage car junkie
blitz'd's Avatar
No problem, most everything ive learned about these trucks has come from this forum and the HAMB. Search through the paint and body forum on here, tons and tons of great info.
I got the bed mocked up tonight. Looks like the axle needs to move back about 5.5 inches on this short bed s10 frame. I pushed the bed up as far as I could and it looks pretty good. I always hated the gap between the bed and cab on these trucks. Ill need to cut a little out of the running board and filler panel but I dont think im going to shorten the bed like I wanted originally. I dont want to mess up the proportions too much. Ill just contour the front of the bed to match the cab a little better.
This works out pretty well. The engine is in the stock location on the S10 frame, the bed can mount to the stock S10 bed supports tho ill need to add about 8 inches to the rear of the frame. It looks like I could even run the original 1950 radiator if I kicked it out a few inches at the bottom like when it was in the camaro clipped frame. I spaced the engine and cab just like it was on the old frame. The engine sits higher now, ill need a different brake booster to be able to take the left valve cover off. Gotta figure out headers next, trying to avoid using those goofy S10 V8 swap headers. If I cant get shorties to work ill run manifolds.
Tomorrow night ill unbolt the axle and take some pictures of it laid out. Gotta decide if I need to notch the frame in the rear, and if ill need dropped spindles up front. I want the front fender on the ground and a little rake in the rear.
Old 09-24-2010, 08:27 AM   #35
a5Ben
Need more pics!!!
a5Ben is offline   Reply With Quote
Old 09-24-2010, 11:28 AM   #36
blitz'd
vintage car junkie
blitz'd's Avatar
Ill put some up tonight. I dont really understand why or how everyone moves the engines back so far on these swaps. My engine is in the stock S10 location and the HEI and trans dipstick are pretty close to the firewall.
Old 09-24-2010, 01:23 PM   #37
a5Ben
It seems to be that you wouldn't have enough room in the front for your fan with the motor in the stock location. I hope to mock mine up this weekend so we'll see....
Ben
Old 09-24-2010, 01:45 PM   #38
blitz'd
vintage car junkie
blitz'd's Avatar
Ill have to put up some pictures. I have tons of room in front of the motor. The HEI is about 3 inches from the firewall.
Old 09-24-2010, 06:11 PM   #39
hotrod1
56 - autocross
hotrod1's Avatar
What kind of paint is that and what color (cab)? Is it an intentional semi flat finish? Pearl, Metallic? I like it.
hotrod1 is offline   Reply With Quote
Old 09-25-2010, 12:08 PM   #40
blitz'd
vintage car junkie
blitz'd's Avatar
Yes, its Omni flame red pearl metallic base with satin clear.
Old 09-27-2010, 12:15 PM   #41
blitz'd
vintage car junkie
blitz'd's Avatar
Spent a good chunk of time on this thing sunday. Made plates for motor mounts, modded the S10 trans cross member to work with my setup, cleaned up the trans and cut off all the un-needed mounts from the frame.
Old 10-04-2010, 10:39 AM   #42
blitz'd
vintage car junkie
blitz'd's Avatar
Frame is off to the suspension guy for the 4 link. Last night I started re-doing the fire wall. Decided I dont need the heater so the hole for that is gone, going to take another stab at the body work on it now that it is more accessable with the cab on dollies. Going to re-clear the whole truck while im at it. I got a little dry spray on part of the roof.
Old 10-04-2010, 11:07 AM   #43
rollinrooster
rollinrooster's Avatar
Great lookin build! I,ve got a '49 on a s-10 frame. On my truck i've just got the motor mocked up for now,but i plan to move it back a little so the headers will clear the crossmember. Sorry i dont have pics of my motor but it is in the stock location for now and i have tried several different headers and manifolds but they all seem to hit on the frame.From what i've seen if you move the motor back a little it seems to make alot more room for headers or manifolds.Hope this helps.
rollinrooster is offline   Reply With Quote
Old 11-30-2010, 10:40 AM   #44
blitz'd
vintage car junkie
blitz'd's Avatar
Still working on this thing. Finishing up some body work while the suspension is at my buddies shop getting done. Heres a sneak peak at the frame. Should pick it up this weekend then it goes for sandblast and some gloss black.
Old 12-07-2010, 05:56 PM   #45
blitz'd
vintage car junkie
blitz'd's Avatar
Old 12-21-2010, 01:46 PM   #46
blitz'd
vintage car junkie
blitz'd's Avatar
Frame is home and torn down for paint. Should look like truck again next week! Bunch of pics coming soon!
Old 12-21-2010, 11:50 PM   #47
70C10Toejam
Hellasick
70C10Toejam's Avatar
Lookin' real good. As several have said already, the thread title is very appropriate. Been 4 months since buying my '52 and I'm still waiting for the guys in the white coats with the special one that zips up the back.
I keep two MAGNUMS in my desk. One's a gun, and I keep it loaded. The other's a bottle and it keeps ME loaded. I'm Tracer Bullet. (Calvin and Hobbes)
This life was a test. It was only a test. If this had been an actual life, you would have received instructions on where to go and what to do.
RED meat is not bad for you...FUZZY BLUE/GREEN MEAT is bad for you!!!!!!!!!!!!!
BUILT FORD TOUGH WITH CHEVY STUFF--sticker at Goodguys
70C10Toejam is offline   Reply With Quote
Old 12-22-2010, 01:56 AM   #48
blitz'd
vintage car junkie
blitz'd's Avatar
Frame is painted! Might change the gray to red, looks great but doesnt really go with the truck.
Took it all to bare metal, ospho, epoxy, paint. Not perfect but beyond good enough for a driver. Link bars and rear end tomorrow, hopefully roller with engine by the weekend. Still have to add body mounts, bed mounts, engine mounts, running board mounts, and finish the rear frame section but it can be easily touched up.
Old 12-22-2010, 02:23 AM   #49
67chevy1series
67chevy1series's Avatar
all that one needs is new chroe bumper and grille
67chevy1series is offline   Reply With Quote
Old 12-22-2010, 03:24 PM   #50
Fat Mike
Fat Mike's Avatar
I noticed you didn't cut the front frame horns off. Are you going to or did everything fit without having to cut them.
Fat Mike is offline   Reply With Quote
