03-27-2010, 01:27 PM | #26 |
Jonny
Re: Pipe Notch
I also definately learned something from ths thread. I guess this is another situation were logical reasoning and engineering bump heads! I'm just curious about how crunch the numbers on a boxed section of frame. This info will come in very handy in the near future.
1966 C30, Cummins, stacks, and a flat bed in progress... "Honor.....simply put, A veteran - whether active duty, retired, national guard or reserve is someone who, at one time in his life, wrote a blank check made payable to 'The United States of America', for an amount of 'up to and including his life.' That is Honor, and there are way too many people in this country who no longer understand it." -AEC Hundley USNR |
03-27-2010, 09:15 PM | #27 |
Shlong Bed Club
Re: Pipe Notch
All of this is exactly why i post here. I came to this site to look for fresh ideas and information and thats exactly what i get, and am very appreciative of that. I have never been to any other forum where the people are so helpful and respectful to each other; i love it! This site is what has kept me moving on my project, and i thank yall for that.
"If it ain't broke, hit it with a hammer, then fix it.." |
03-28-2010, 12:05 AM | #28 |
Jonny
Re: Pipe Notch
03-28-2010, 08:54 AM | #29 |
Check The Champ, Demonstrator
Re: Pipe Notch
To bridge the structure where the weaken point exisits could restore or even improve the rating on the frame but who wants a dinner triangle hanging under the truck? LOL
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
03-28-2010, 11:01 AM | #30 | |
Resistance is Futile
Re: Pipe Notch
I guess to make a more extreme example, using the 4.75'' frame rail from page 1 (d).....what if, centered on the frame rail, one was to holesaw a 3'' hole thru the frame. What does this do? My father was an engineer at Caterpillar for 40+ years so I'm used to physics, equations, and math blowing holes in my 'common sense'.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
03-28-2010, 03:19 PM | #31 |
SSN 706
Re: Pipe Notch
That CAD stuff is cool. I don't even want to know what it says about this. Well I do kinda. Maybe it's better not to know. I'll just drive slow most the time. Not
Daverods 64 C10 Daily driver 292 3 speed "Driver" Daverods 66 Build C10 Bags 350/350(On Hold) Daverods 52 Build 3100 S10 chassis,Bags, 350/700r4 "Click it" Last edited by daverod; 03-28-2010 at 03:20 PM. |
03-29-2010, 02:37 PM | #32 |
Jonny
Re: Pipe Notch
Man I love this stuff!!
Am I reading this wrong or is the c-notched frameW/ box and repad showing to be stronger than stock? Also wondering how well it would work if you were you put a second arch inside the frame rail? Maybe using 6" pipe? And am I interpreting the procedure correctly where the re-pad is actually replacing part of the frame? I personally appreciate all the time you've spent on this. It's been a real eye opener for me and will help me build a better truck.
03-29-2010, 05:32 PM | #33 |
I'm just glad to be here!
Re: Pipe Notch
This is an interesting discussion.
Could you post the section modulus for a square tube shape? Like you did above for the C channel.
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
03-29-2010, 06:40 PM | #34 |
Shlong Bed Club
Re: Pipe Notch
would something like what i've drawn here on my work table restore some of the lost strength? its simply the remainder of 1/4'' wall pipe with 3/16" plate on both sides.
03-30-2010, 01:11 AM | #35 |
Re: Pipe Notch
I sat down tonight to try & decipher my set-ups values but seemed to be getting lost somewhere because of the notched area. Man, I wish I was better @ math calculations.
I'm tired so I'll try again tomorrow ....
03-30-2010, 02:40 AM | #36 |
Jonny
Re: Pipe Notch
John, I think you opened pandora's box of frame mod calculations!
03-30-2010, 09:27 AM | #37 |
Re: Pipe Notch
John, Thanks for the link. I can use that...
03-30-2010, 10:13 AM | #38 |
Jonny
Re: Pipe Notch
Fabrication would be a hight, but the way I see in is:
1. weld the 6" pipe to the box 2. weld the 6" pipe to the re-pad 3. weld the 4" pipe to the box and re-pad 4. put it all in place and weld it to the frame This process would allow you to back weld the 6" pipe. If you wanted to be able to back weld the 4" pipe instead all you would have to do is put that one in first. I couldn't think of a process to et both of hem back welded.
03-30-2010, 10:32 AM | #39 |
Shlong Bed Club
Re: Pipe Notch
is this workable? sorry its so crude. and yes, the extra 1/4'' wall pipe is used above the frame and plated on both sides with 3/16" steel.
"If it ain't broke, hit it with a hammer, then fix it.." Last edited by DWright; 03-30-2010 at 10:33 AM. |
03-30-2010, 01:30 PM | #40 |
Re: Pipe Notch
We may have to start paying consultation fees soon!!!
03-30-2010, 10:51 PM | #41 |
Jonny
Re: Pipe Notch
I think (yes, I know it's dangerous) that if you were going to do a notch that big you would be better off just doing a step notch.
03-30-2010, 11:03 PM | #42 |
Shlong Bed Club
Re: Pipe Notch
the pipe was 6" od. i wasnt too concerned with the bed floor as mine is currently a sheet of plywood. i was thinking of raising it about 2" to clear the diff. when aired out anyway. what kind of steel do you recomend be welded to the top of the frame? i was only asking about the remainder of the pipe because i already had it and hate wasted steel.
03-30-2010, 11:16 PM | #43 |
Re: Pipe Notch
x2.
03-31-2010, 12:22 PM | #44 |
Re: Pipe Notch
The issue w/mine will be there's not much room to plate the sides of the frame between the c-notch, Panhard bar c.member, & shock c.member. I'm trying to come up w/something that can be welded to the top of the frame rail & add strength.
Solid bar,thicker c-channel, what do you guys think?
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 03-31-2010 at 12:24 PM. |
03-31-2010, 07:17 PM | #45 |
Shlong Bed Club
Re: Pipe Notch
thanks for the work Lakeroadster. i notched the frame lastnight and installed the 6" pipe notch. i'm definitely gonna add a piece of heavy wall 2x4 steel to the top of my frame.
04-01-2010, 12:12 AM | #46 |
Re: Pipe Notch
You've got mail.
04-02-2010, 12:41 PM | #47 | |
Re: Pipe Notch
04-02-2010, 06:37 PM | #48 |
Re: Pipe Notch
I can't even begin to tell you how interesting this whole discussion has been. Thank you for sharing your knowledge with us.
Rockin' a '66 and loving every minute of it |
04-02-2010, 06:46 PM | #49 | |
Re: Pipe Notch
Here's what I'm thinking.... Looking @ the contours of the frame, simply attaching a generic piece of steel 'tube' to the top of the rail will require considerable chopping of the material & will look like an after-thought (would work great on a nice straight frame though). In keeping w/the concept, I still have the extra frame that I originally intended to use for this build (but the frame was bent). I'm thinking I'll cut that proposed area from the extra frame & weld it to the compromised section of this frame adding an additional ~3" of height in that area & add the solid .500" piece @ the rear portion of the notch. I'll add three 90° 'L' shaped pieces of angle under the 'new' section that will tie the top of the current frame to the side & top of the new section. I'll space the three brackets equally (one @ each end & one in the middle). The end pieces will be where I'll start the 45° transitions that will tie the old & new @ the ends of the 'truss' & I'll box the back side similar to what I did for the current c-notched area. This should leave the frame visually consistent (like it was planned all along ) while reinforcing the area I didn't think through before commencement of fabrication.
04-02-2010, 08:20 PM | #50 | |
Re: Pipe Notch
