Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 06-11-2010, 12:21 PM   #26
C20-67_N_MO
Champagne Taste on Beer Budget
C20-67_N_MO's Avatar
Re: New project
What the specs on your heads?
And what induction you gonna be running?
Coming Soon: Project 1970 Country Truck
C20-67_N_MO is offline   Reply With Quote
Old 06-11-2010, 04:28 PM   #27
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
The heads are GM fastburns (210 cc intake runners )that are rolled a touch . I had them for a class i used to run that required a 23 degree head . Out of the box they will support 500 hp . These have had some touch up in the way of polishing and severe duty valve installed . Quench ended up being .041 , which is within the gap but a little bigger than i wanted . Compression should be 10.2-10.3 to 1 . They are raised runner and the Edelbrock rpm air gap is port matched . I would run a single plane , but a victor won't work with these heads due to the raised runner ( .210 i think ) plus i would have to have a new intake ported and this is only a "street truck" I will be topping that off with a cheater plate and 750 speed demon . This will be my 4th speed demon and i have never had a problem . Might step up to a custom built carb later .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 06-11-2010, 06:02 PM   #28
shortbed70
shortbed70's Avatar
Re: New project
Well dang I didnt get to hear the 396 run so I'll subscribe to this one.. Looks fun I've always thought about building an s-10.
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 06-11-2010, 06:46 PM   #29
dammitmitchell
the pollock
dammitmitchell's Avatar
Re: New project
holy hell sleeper!
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
Old 06-12-2010, 06:30 AM   #30
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
Yea sorry about that . I had back surgury and the offer was too good to pass up . Next time i see it i'll try and get some video .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 06-12-2010, 10:44 AM   #31
noonzor
Re: New project
sounds like shes gonna be mean!
69 c10 Shortbox Build
http://67-72chevytrucks.com/vboard/s...d.php?t=360622
noonzor is offline   Reply With Quote
Old 06-18-2010, 09:05 PM   #32
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
Well i got the trans off to the shop for a rebuild . It is a long tail th-350 . The shop said they could make it a short shaft as i will be swapping back and forth between it and a powerglide with a brake .
And i got a little farther on the motor . Intake on and torqued and a few other parts added . Headers and mounts should be here monday and i should be starting the motor install on friday and working towards getting it running the following week .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 06-19-2010, 10:54 PM   #33
ripdog28
ripdog28's Avatar
Re: New project
Looking mean.
69 c-10 BBC
462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build.
ripdog28 is offline   Reply With Quote
Old 06-20-2010, 12:42 AM   #34
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
Headers & mounts will be here monday . I intend to start the install the 25th - the 1st . I think i got most of the parts in a pile . More ics to come .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 06-24-2010, 06:28 AM   #35
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
Headers and mounts came in . Waiting on the transmission .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 07-07-2010, 10:24 PM   #36
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
A buddy of mine had a set of Landrum monos and caltracs for a first gen camaro that i thought might work . Well the Caltracs didn't work and im back to square one there . I did get the axle housing ends and axles . I ended up getting a smokin deal on a set of used 31 splines . I already have a 31 spline spool , so i went that way .
Just about got the motor ready to pull . I got it about half way apart and found out why it was running rough . O2 senser wire was pinched under the valve cover and grounded . The little motor was probably O.K. Oh well its coming out . GOing to try and trade it for a set of buckets at the salvage yard .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 07-08-2010, 06:22 PM   #37
dammitmitchell
the pollock
Re: New project
you need a entire rear end?
Army vet 02-08
Old 07-11-2010, 04:36 PM   #38
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
I am replacing the 7.5 with a 9" Ford .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 07-11-2010, 08:11 PM   #39
dammitmitchell
the pollock
Re: New project
theres one available here in abilene at my buddys shop.
it's narrowed everthing (was under a vega dragster)
probably comes with slicks too and i do believe he has a second gear set also.
interested?
Army vet 02-08
Old 07-12-2010, 09:28 PM   #40
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
Well i got the 2.5 out and the mounts bolted in . Only 2 of the 3 bolts are accsssible and they are a pain to get in so welding the mounts is mansitory in my opinion . I cleaned up the frame with my 4 " grinder and a wire wheel so i can haul it down to the race car shop and have them welded . I'll get the motor in when i finish the mounts . Im going to see if he has a panish hammer for an air chisel and have the floor flange messaged while i got it over there . Here are a couple of pics i'll add some more later .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 07-12-2010, 10:50 PM   #41
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
Here are the motor mounts in the hole . Also got the axle shafts in today .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 07-13-2010, 01:29 AM   #42
noonzor
Re: New project
its comin together! keep it up!
Old 07-13-2010, 07:04 AM   #43
djracer
djracer's Avatar
Re: New project
What rear and axles?
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 07-13-2010, 08:24 AM   #44
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
I bought a 9" ford local off Craigslist with a back brace , early style large bearing ends and is 48" . I also found a set of 31 spline Mosers on the bullet that were built for the exact set up ( believe that luck ) . I have a 31 spline spool , but im thinking about buying an aftermarket case and using a Nascar detroit locker off ebay as they can be had for around $200 shipped . This will give me a wheel mount to wheel mount of 53" . Factory is 54.5" , so 3/4" per side narrower allowing me to run up to a 4.5 backspace wheel . I currently have 15 x 10 4 " back space but 4.5 backspace is alot more popular .
I am stuck on the "stock suspension" classes . I could have back halved it but then i'd be limited class wise . The old school backhalve classes are fast (4.80's) . Stock suspension classes run 275's or 26 x 8.5's and are around the 5.90's , this will give me a place to work into . Primary goal right now is Pinks all out and 7.0 index . I have a daughter going to college soon so it's going to be slower index stuff or nothing for a few years .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 07-13-2010, 10:53 AM   #45
ripdog28
ripdog28's Avatar
Re: New project
looking good man, cant wait till that beast is in its new home.
69 c-10 BBC
Old 08-28-2010, 06:44 PM   #46
a1953mdl
Rusty but Trusty
a1953mdl's Avatar
Re: New project
Good to see you back with another truck.
But really seems like in over a month you could post at least a few progress pics....lol
Lee
72 SWB, 454 / th400... hoping the kids don't get all the parts before it gets built
a1953mdl is offline   Reply With Quote
Old 08-29-2010, 03:40 AM   #47
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
Sorry , i did get the housing finished , but my dad has congestive heart failure and has been hospitalized on and off for 2 monthes . He has only 15% heart muscle alive . Just got word he will not be getting released . They have already sent him home with the "nothing more we can do". Just the dye to check for blockage would probably shut his kidneys down & he is having 2 to 5 seizsures a day . Been spending most of my free time with him . Pretty much put projects on hold to enjoy what time is left .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 08-29-2010, 11:45 AM   #48
ripdog28
ripdog28's Avatar
Re: New project
Sorry to hear, I would rather enjoy the time also.
69 c-10 BBC
Old 08-29-2010, 02:23 PM   #49
Marv D
Registered Truck Offender
Marv D's Avatar
Re: New project
Thoughts and prayers with you hotrod. It's a very tough time in a boys life. There will be plenty of time for the toys later. Keep your chin up.
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 08-29-2010, 06:49 PM   #50
djracer
djracer's Avatar
Re: New project
Prayers sent from the Tolliver's. I lost a very dear uncle a couple weeks ago and I'm so glad I spent the weekend with him the weekend before he passed. My Uncle Larry was recently diagnosed with cancer and his heart couldn't take the chemo.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
