02-27-2015, 09:50 PM | #26 | |
Re: 4x4 sway bars
Does any body have pictures of their rear swaybar setup; and from what application did they get the rear swaybar from? Thanks a bunch Steve
Steve 1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's |
02-27-2015, 10:15 PM | #27 |
Re: 4x4 sway bars
Speedway Engineering 1" bar. I made up the mounting tube. Quite a bit of fiddle to get it to work, and the driveshaft would actually hit the mountin gtube at full compression..... You get the idea anyway!
Have added air bag assist as you can see. "Floating' Bottom mount.
1972 K2500 Long Box 400/350 |
02-27-2015, 11:03 PM | #28 |
Re: 4x4 sway bars
"Floating" bottom mount? is that still PG rated?
That really looks like a system I could use. Air bagged and swaybar for load control.
02-27-2015, 11:08 PM | #29 |
Re: 4x4 sway bars
Airbags are the limiting factor for travel now. Will see how it goes. One day!
02-27-2015, 11:16 PM | #30 |
Re: 4x4 sway bars
is the bottom airbag bracket not hardmounted so it can travel with suspension articulation?
02-27-2015, 11:37 PM | #31 |
Re: 4x4 sway bars
Bolted to the top mount. Bag sits on bottom mount in normal driving. Just lifts off in articulation.
02-27-2015, 11:53 PM | #32 |
Re: 4x4 sway bars
oh, ya sure. you dont have any issue with it self aligning as the suspension articulates?
and tell me more about this crazy looking rear swaybar and the end links. is that a home jobber? nice bellow bracket by the way.
02-28-2015, 01:08 AM | #33 |
Re: 4x4 sway bars
Sorry. Distracted. Cricket World Cup. NZ vs OZ. Yelling at the TV helps!
All sway bar components are Speedway Engineering parts http://www.1speedway.com/Swaybars.htm Well, bar, arms, and links. Mounting tube is just some 2" pipe and my lathe guy turned up some urethane bushs. Nothing too technical! Oh, I had to move/cut down the bump stop mount. I may take it off completely. Truck still reeeally quiet, so it's all theory at this stage!
02-28-2015, 10:49 AM | #34 |
Re: 4x4 sway bars
Interesting. I'll have to look into that. It looks like the end links could be either coupled or replaced with quick disconnects easy enough.
Do I see a couple of very large air tanks or propane? I like how you routed your brake lines. Yell away!
03-01-2015, 02:38 PM | #35 |
Re: 4x4 sway bars
Sway bar disconnects wouldn't be that hard, just need to keep the sway bar out of the way when disconnected!
Propane tanks. Tight squeeze. Not massive capacity, but should get me to town and back!
03-01-2015, 07:03 PM | #36 |
Re: 4x4 sway bars
ya, maybe weld a couple heavy washers to the frame,or so, to clip the sway bar up and out of the way.
how far does a couple tanks like that get ya? haha, how far's town?
03-01-2015, 10:14 PM | #37 |
Re: 4x4 sway bars
Yeah, something welded to the frame in the right place would be the trick.
Trucks still a work in progress, so no actual figures yet!
01-17-2017, 08:12 AM | #38 |
Re: 4x4 sway bars
I have a 1970 k20 lifted 4" and want to add a front sway bar. does anyone make a direct bolt in kit? any help would be great.
