Old 06-29-2010, 02:27 PM   #26
68 short step
Re: project " Blue-Ray"
a bit more progress, got the harness broke down, de-pinned, and sorted...and started to re-work it...here are a few pics...also still chipping away at the firewall..
68 short step is offline   Reply With Quote
Old 06-29-2010, 02:57 PM   #27
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Damn thats alot of wires. I'm glad I paid someone to make me a standalone harness. That would have me scatterbrained for weeks! Nice work.
--Josh
Old 07-01-2010, 11:10 AM   #28
Coda O'Dell
Coda O'Dell's Avatar
don you have some big cajones to cut that wiring harness up
Coda O'Dell is offline   Reply With Quote
Old 07-01-2010, 11:43 AM   #29
RandyP
Getting Old; Going Broke
RandyP's Avatar
x2, wow.
RandyP is offline   Reply With Quote
Old 07-11-2010, 10:33 AM   #30
mcbassin
Still Learning
mcbassin's Avatar
Looks like another project to follow for sure! I'm subscribed.
+1 on the square body!
mcbassin is offline   Reply With Quote
Old 07-11-2010, 03:35 PM   #31
lnwlfbsktbll
lnwlfbsktbll's Avatar
Wow great progress, it's taken you a month to do what took me 6.
'87 SWB GMC LY6/6L90E
'70 JEEP CJ5... My new toy
'06 Hyundai Accent... DD
Build thread located at http://67-72chevytrucks.com/vboard/s...5708&posted=1#
lnwlfbsktbll is offline   Reply With Quote
Old 07-11-2010, 05:11 PM   #32
GmtGmt
Conversion Truck Addicted
GmtGmt's Avatar
i would not mind make that a stand alone harness that great work i love working on wiring but i hate rust wish someone could do the rust one mine lol
Thomas
Tonight mine pulled a few cars out of snowbanks, and is sitting in my driveway, icicles on the grille, wheels just white cakes of snow, buried up to the lug nuts in powder, straps and chains wrapped around the bumpers, the outline of the wipers clear in 4 inches of snow on the windshield... A tired warrior of the 1980s in a world of low profile tires, front wheel drive, and plastic bumpers, where people stay in their houses until snowplows move the offending substance from their paths, too helpless to travel without AAA and chains and salt, clearing their windows with longhandled brushes while gently stepping around in the snow trying to stay nice and dry.
GmtGmt is offline   Reply With Quote
Old 07-11-2010, 08:18 PM   #33
68 short step
little bit more progress to report....got the guages in, they are autometer sport comp....im working on making a backing plate to attach to the factory bezel, more on this later...drilled and tapped some bosses on the block, so i could add adels, to keep the wiring neat, and tucked in... also made a mounting plate for the ECM/TCM, so i could get started terminating the wires..the TCM mounting holes were to big for 10-32 screw, so i reamed the holes, and added proper bushing..the ECM already had proper hole size to tap to a 10-32, so i taped them, so i could mount everything...the wires that are off to the side (not terminated) will be integrated into the factory harness with OE weatherpack connectors, so it will be a simple 'plug in' deal.. and also make eng/trans removal easy (should you need to)...
Old 07-11-2010, 09:05 PM   #34
mcbassin
Still Learning
mcbassin's Avatar
Are you running the pcm behind the engine like you have on other builds? I like the mounting plate too!
Old 07-11-2010, 09:32 PM   #35
68 short step
yes, that plate will mount to the firewall.. it still needs to be trimed, preped, and painted tho
Old 07-11-2010, 09:40 PM   #36
Hart_Rod
Hart_Rod's Avatar
You need make some of those plates to sell.........
Hart_Rod is offline   Reply With Quote
Old 07-26-2010, 02:04 PM   #37
68 short step
got a bit more progress....got the autometer guages in, and started modding the existing cluster so they'll fit...basically i cut out the backside of the cluster and formed a peice of sheetmetal for the guages to mount to...i re-used the raised factory clear plastic peice, so the guages that needed to be raised, would be...then once everything was fitted in place i dissaembled everything and painted the sheetmetal, and started wiring them up...i used a weatherpack connector so everything is modular and can be removed/installed easily... the non-terminated wires that go up, are for the MIL light,and high beams, and those will be installed in the bezal (with weatherpack connectors as well.)
Old 07-26-2010, 02:17 PM   #38
68 short step
also got the firewall finished, filled all the un-used holes, cleaned all the old seam sealer outta the seam, then applied a 'nice' (unlike factory glob job) bead of seam sealer on the seam...got the paint matched to the glovebox, and painted/cleared the firewall....the firewall is a basecoat/clearcoat, while the factory was a single stage...needless to say the firewall looks nice and shiney compaired to the rest of the truck, but you get an idea of what the final color will look like...
Old 07-26-2010, 03:07 PM   #39
STOCKISH
STOCKISH's Avatar
WOW! Thats beautiful. I would love to just pay someone to do my cluster like that. Great work.
--Josh
Old 07-26-2010, 03:22 PM   #40
mcbassin
Still Learning
mcbassin's Avatar
Awesome cluster! and firewall! looks like a great match with the paint!
Old 07-26-2010, 03:23 PM   #41
RandyP
RandyP's Avatar
Wow. Looks awesome!
Why is every used 350 sbc out of a corvette?
There's only two things that excite a man, expensive toys and real expensive toys.
VEGETARIAN: That's an old Indian word meaning "I don't hunt so good."
When the going gets tough, switch to power tools.
Old 07-27-2010, 09:27 AM   #42
menace121978
menace121978's Avatar
very nice! i'm going to copy your idea with the cluster
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 07-27-2010, 10:04 AM   #43
menace121978
can you see the gauges clearly? in one of the completed pics it looks like the fuel gauge "E" i cant see. it may be the angle of the pic...
like i said i'm going to try and do this. going to order the gauges and if you have any other tips or instruction i'd apprieciate it buddy thanks! Dennis
"Dennis the Menace"
Old 07-27-2010, 03:47 PM   #44
STOCKISH
STOCKISH's Avatar
Dennis, if I had your money I'd just send the gauges, cluster and a few hundred bucks to him and let him do it! Looks like an amazing job doesnt it!!!
--Josh
Old 07-27-2010, 03:50 PM   #45
silvereagle07
silvereagle07's Avatar
Very nice!
Jeramy
'84 GMC project truck
'85 Chevy 4X4 SOLD
'07 Chevy Trailblazer SS
5th Annual SHPHC Car/Truck Show Pics
http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT
silvereagle07 is offline   Reply With Quote
Old 07-27-2010, 05:43 PM   #46
menace121978
heck yea it does! i love how you act like i'm rich just the damn gauges alone are $800!!!
hummmm..... that isnt a bad idea though!
"Dennis the Menace"
Old 07-27-2010, 05:56 PM   #47
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Nice project and nice work! I can relate to the mess of wires you have there. I'm working on putting a 2002 24v cummins in a 2004 F-250 that had a 6.0. It has it's moments for sure.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 07-27-2010, 11:58 PM   #48
mcbassin
Still Learning
mcbassin's Avatar
Heck, If I had either one of you guys money, I'd throw mine away. Wish I could afford to have him do my cluster like that too. Or even have the cash for sweet gauges like these.
Old 07-28-2010, 12:23 AM   #49
VA72C10
VA72C10
VA72C10's Avatar
Nice work!!!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 07-28-2010, 12:56 PM   #50
68 short step
thanks everyone for the complaments...
here is a pic of the guages, all the guages can be seen, pending on the angle you look, some spot are 'hidden' but with a slight move of the head, you can see those spots no problem.. i may open the holes on the bezels so you can see more of the guages, but it's very visible as is....
but, if they can be improved on, ill certainly do it, and post new pics...
