Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 06-21-2016, 03:11 PM   #26
turp mcspray
turp mcspray's Avatar
Re: Painting "CHEVROLET" tailgate lettering
Here are some pics of both ways.
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 06-21-2016, 05:10 PM   #27
RestoreAmerica
Originally Posted by AnotherWs6 View Post
This. This is how skilled pros do it. It's not really difficult, have done it a few times in my former autobody life.
Obviously I am no pro. I screwed up my tailgate. Next go round I will paint the band or entire face white then use the decals with tape as a masking tool. I will apply the decals with the masking tape to the recessed letters and paint the green. Remove the masking/decals and clear the gate.
I am no pro but I can tell you that in my opinion prepping the tailgate is a lot of work and not something you want to have a painting problem with.
RestoreAmerica is offline   Reply With Quote
Old 06-22-2016, 10:25 AM   #28
AnotherWs6
AnotherWs6's Avatar
You dont need to be a pro, honestly. If you paint the whole thing a solid color with clear coat and it comes out good then you are most of the way there. Now that you have a nice, smooth surface you sand it with fine grit sand paper like you would if you were going to sand and buff it. You can also use a grey scotchbrite with stuff called Blend-prep. Its this toothpaste tube of stuff that makes getting all of the edges and nooks sanded without worrying about burning through the paint. Then you spray the white and sane it again with a small block, then clear once more. Saves a TON of taping and loos great. If you can paint you can do it.
1968 C-10 Suburban - Original 396/TH400
2002 Transam WS6 - M6 - Black/Black - Evil Garage Queen
2000 Silverado - DD - Small lift+Body lift+35" Duratracs+4.88's + Eaton TruTrac - Monster Truck
2010 Cadillac CTS Wagon Sport - Wife's DD and the only classy car we have.
AnotherWs6 is offline   Reply With Quote
Old 07-12-2018, 11:59 PM   #29
stevenfromtexas
stevenfromtexas's Avatar
did mine a few days ago...
painted the letters first then placed the vinyl letters as "masking". i did put a strip of pin-stripe tape under the vinyl letter prior to masking. it made it a lot easier to remove. i put the pin-stripe tape on the bottom of the vinyl just incase i ran some blue paint, didn't want it to bleed where the pin-stripe tape was.
Steven
'67 SWB, 250ci, 3OTT.......this is my first build......
I wonder if my grand kids will say, "I would give anything to have my grand dads 2005 Chevrolet Z71"
stevenfromtexas is offline   Reply With Quote
Old 07-13-2018, 12:00 AM   #30
stevenfromtexas
Steven
Old 07-13-2018, 12:33 AM   #31
Foot Stomper
Foot Stomper's Avatar
Well done! Great documentation! Should be pinned in the "How to" section.
So when is this "Old enough to know better" supposed to kick in?
My 1959 GMC build thread http://67-72chevytrucks.com/vboard/s...d.php?t=686989
Foot Stomper is offline   Reply With Quote
Old 07-13-2018, 08:08 AM   #32
stevenfromtexas
thank you sir!!
Steven
Old 07-24-2018, 01:04 PM   #33
oem4me
Originally Posted by Musclerodz View Post
original stenciling was horrible at best. If you want it clean show quality, this is how I did it. I painted and cleared the tailgate. then I masked the letters at the top of the stamping, not in it like factory. Spray couple light coats to keep paint thickness minimal, color sand with block to remove any from top surface, then reclear entire tailgate.
More of this. I did mine nearly the same way, the difference being no clear coat before, between, or after. Decent quality white spray can enamel applied sparingly, directly on blue base color.
- IMPORTANT- Notice the masking technique. Quickly masked with tape edges overhanging the letters giving a "soft" edge not unlike like the lame factory stencils. I could've almost left it alone at this point for a true factory slop look.
Next, I "blocked" the fuzzy edges off with a rubber sanding block wrapped with T-shirt cloth and rubbing compound, NOT sandpaper. Far more control and less risk of burning through this base color way.
I did end up burning through on some spots though, but this was intentional, as I was mimicking natural wear and adding fake patina to some degree. The rest of the truck's paint is heavily worn and a pristine tailgate would just look wrong. I easily could have stopped rubbing before burning through.
Old 07-24-2018, 01:07 PM   #34
oem4me
couple more.
