#26 |
Re: Low Budget '70 C-10
I checked out that website with the paint, it seems to good to be true, wonder how the quality is, I think for that price I might have to try it and find out for myself. thanks.
My low budget '70 C-10 project-->http://67-72chevytrucks.com/vboard/s...d.php?t=411959 |
#27 |
keep up the good work! looks great. cheers, pat
#28 |
Good job so far Piston! Your definately Low buck and on the right track.
#29 |
I talked to Hottruck for a while today and he gave me alot of good info on and air bag suspension, now I think I might stick with the true rat rod style, who cares what it looks like as long as it goes down the road good and hauls ass. think i'll drive her in primer for now and pull the trigger on doing the suspension.
#30 |
Welded in the cab corner and rocker in on the pass. side today, the rocker fit like a glove, the cab corner, well, I didn't like the fit but I made it work. Theres Ruger my junk yard dog.
#31 |
Redefining LowBudget
Np Dude I did the low show when I pulled in it was like a magnet...suddenly there wasn't another car in the lot to look at..even my buddy MK4 dragging the frame
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. ![]() Mikes Sandwich Fair Run OCT 8th 2011
#32 |
Grandpa in the rustmobile...
nice build man! havent seen this one before, I was just N of ya in Clearwater before we moved to TN.
And hotttrucks we know you have a pretty cool beater ![]()
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
#33 |
Thanx Blue.....it all time!!! as a matter of fact I scored another 500 yesterday I'm going to pull the heads and give it a valve job and clean up the bowls ( I think I have one burnt or bent??) get some new lifters and swap them out..I should be into it for the price of a set of gaskets and 5 hours labor but it will free up another few ponies.....
#34 |
gets board easy.......
good luck with the rust...makes me appreciate the trucks we have here ,wow
#35 |
lol thats a florida truck too?! must've been from north or ran on the beach or something?
#36 |
Me and my father inlaw were talking about that, the frame on the truck is nice, just a little surface rust here and there, and the bed is nice too, but the cab is wasted. I think its just from dirt and leaves getting down into the cowl and sitting for 40 years.
#37 |
I love Bondo!
#38 |
is very serious
keeping an eye on this one... pretty much what im looking to do with mine... get it prety much straight... slap it with primer... and then make it run like a top
1967 C-10 2wd fleetside LB 350 4spd (dads) - sold 1970 C-10 2wd fleetside LB 307 700r4 - sold ![]() 1969 C-10 2wd fleetside LB 327 3spd - sold ![]() 1969 C-10 2wd fleetside LB 350 th350 - sold ![]() 1967 C-10 2wd fleetside LB 250 th400 -project in progress Chevrolet=one who is dignified enough to expect every occasion is a special one and sees it fit to wear a bow tie... may others come under dressed. |
#39 |
I'd bang the dents out ot that old girl!! I should start a post and call it Prime time for just primers truck pics??
#40 |
is very serious
my c10 was grey primer... this one is about to be too when i get started on the body work...
#41 |
is very serious
you should seriously... love the look
#42 |
lol the clear coated primer...Id primer mind if I knew SOMETHING about bodywork..(3 diff colors, fixin to be 4) lol i love the low budget truck builds
#43 |
I had to do some crazy s#@t to my truck today, the hood and fender match up perfect on the pass. side but are way off on the driver side. the front edge is perfect, but the driverside fender is 1/4 in. further forward and the back of the hood hits the fender while there is a 3/4 in. gap in the front, I tried adjusting and shiming everything, but nothing helps. Also the driver fender is all the way forward, so it leaves a gap between the door, but thats only an 1/8 in. not much at all. So in order to make everything fit just right, I had to push the driver fender back, and to make this happen, I had to cut about a 1/4 off the back off the fender, I know its crazy but it worked perfect.
#44 |
dang lol pretty daraastic.
#45 |
I HATE BODY WORK!!!
but i would say that you have a rad support issue that is not holding up the DS nose and the sag is what is causing this...I have been fighting body fit crap for awhile .....this is what I was told check ALL you cab mounts first then hang your doors then the front can be shimmed to fit |
#46 |
Or beat it with an Ax cut it off weld it in and squirt it with primer....guess what I'm doing for now??
#47 |
the frame and rad. support is in great shape, all rust free, the hood and frenders are aftermarket, and someone beat the hell out of them, the driver side fender was longer than the pass. fender, so I cut it, i'm not scared (after about a 6 pack) to cut and weld. You should see what i can do after about 12 cold ones (like run a screwdriver through my hand doing a brake job)
#48 |
Here is some paint I can get for free, what do you think?
#49 |
is very serious
free paint is good paint... (cough frenches mobile) jk
1967 C-10 2wd fleetside LB 350 4spd (dads) - sold 1970 C-10 2wd fleetside LB 307 700r4 - sold ![]() 1969 C-10 2wd fleetside LB 327 3spd - sold ![]() 1969 C-10 2wd fleetside LB 350 th350 - sold ![]() 1967 C-10 2wd fleetside LB 250 th400 -project in progress Chevrolet=one who is dignified enough to expect every occasion is a special one and sees it fit to wear a bow tie... may others come under dressed. Last edited by ed70; 08-12-2010 at 09:58 PM. |
#50 |
This guy has got to be stopped
Pete, I saw your username on a Dakotas forum... Do you dabble in the dodge world too?
I am doing a low budget 70 chevy 4x4, but I'm a recovering mopar addict...
J P Evers 1970 4x4 LWB project: http://67-72chevytrucks.com/vboard/s...d.php?t=415134 |
