Old 07-29-2010, 11:38 PM   #26
maxxxy
maxxxy's Avatar
Re: maxxy's 81 bagged c10 build
what do you guys think of an 88-98 door handle on my 81. i kinda did a photoshop in paint.
Max
Max's bagged 81
81 rcsb bagged, 22s, build in progress
09 ext cab, 24" U2's, DD sub/amp
maxxxy is offline   Reply With Quote
Old 07-29-2010, 11:59 PM   #27
dv8customs
dv8customs's Avatar
I am pretty certain your drive shaft isn't going to clear those support thingies.
dv8customs is offline   Reply With Quote
Old 07-30-2010, 12:13 AM   #28
grayharville
^^who I am^^ what I say>
grayharville's Avatar
i agree about the driveshaft hitting the support thingys, it looks close. might have to build a different style of thingy.
70 chevy LWB 350/TH350 Barn find (AKA the 70)
http://www.67-72chevytrucks.com/vboa...d.php?t=406364
East Tx Squares
grayharville is offline   Reply With Quote
Old 07-30-2010, 12:25 AM   #29
maxxxy
maxxxy's Avatar
The support had more clearance than the stock support had and it seems everything will clear, but I figure if when it's aired out and it doesn't clear, I'll just remove the brackets and notch the support
Max
Max's bagged 81
Old 07-30-2010, 04:03 AM   #30
Chevy623
Chevy623's Avatar
I like the newer door handles on these trucks.
If your going with a bright colorful paint, i'd use the early model handles because their smooth and paintable. my '95 has the textured black ones and i hate them. just my .02.
Jesse.
Chevy623 is offline   Reply With Quote
Old 07-30-2010, 09:28 AM   #31
JohnC
JohnC's Avatar
Only bad thing I have seen about the 88-98 handles on the 73-87 trucks is that you have to put them lower in the door, and after awhile they tend to want to pull out. A guy I know did it, and after awhile he wished he would have just shaved them all together. My uncle has shaved doors on his 85, and a keyless remote that works the poppers. That's the way I would go.
JohnC is offline   Reply With Quote
Old 07-30-2010, 09:36 AM   #32
RandyP
Getting Old; Going Broke
RandyP's Avatar
Knowing all the door handles on cars and trucks over the years, and seeing how they all react while frozen, I'm sort of amazed GM went away from the push button type like the squares have. I never really remember replacing outside handles very frequently until the 88's came out. Since then, during winter I'll try to keep a drivers outside handle in stock for modern trucks. Frozen handle, and a deep desire to gain entry with force, equals breakage these days.
Why is every used 350 sbc out of a corvette?
There's only two things that excite a man, expensive toys and real expensive toys.
VEGETARIAN: That's an old Indian word meaning "I don't hunt so good."
When the going gets tough, switch to power tools.
RandyP is offline   Reply With Quote
Old 07-30-2010, 09:39 AM   #33
JohnC
JohnC's Avatar
Yeah the door handles on my 03 aren't very strong at all. I know 3 or 4 people that have broken theirs due to the door being stuck with the colder weather. I make sure I'm extra gentle with mine due to it.
Old 07-30-2010, 10:11 AM   #34
BGRAFX
Here my 2cents about shaved doors. They look great on a weekend cruiser/ show truck but for a DD they can cause problems when the popper gets stuck or the doors get frozen shut. I had both things happen to me on my shaved door burb about 10yrs ago. I was stuck with no way to get into the truck.
BGRAFX is offline   Reply With Quote
Old 07-30-2010, 10:25 AM   #35
dv8customs
dv8customs's Avatar
When laid out your drive shaft will be much higher. You WILL need to notch the cross member you built so I wouldn't weld it in solid just yet.
Old 07-30-2010, 10:26 AM   #36
dv8customs
dv8customs's Avatar
I had shaved doors on my Nova and drove it daily for several years with no issues. Of course it doesn't get as cold down here in Texas
Old 07-30-2010, 12:03 PM   #37
Chlsnk
Chlsnk's Avatar
Sweet truck! I would kill to get a truck that cheep for what it has already done to it!
***My 84 short bed build up*****
http://67-72chevytrucks.com/vboard/s...68#post3481968
Chlsnk is offline   Reply With Quote
Old 07-30-2010, 02:03 PM   #38
justpball
justpball's Avatar
I have had shave doors on more car,trucks then I can remember, if they are set up right and have a good back up you will have no problems... I let some talk me out of shaving my burb... wish I would have done it now...
Fuzzy Dice Club Member
87 Crew SWB
Build for the crew
http://67-72chevytrucks.com/vboard/s...d.php?t=430082
http://www.cardomain.com/ride/3232925
90 burb 2wd
Build Thread For The Burb!
http://67-72chevytrucks.com/vboard/s...d.php?t=383055
justpball is offline   Reply With Quote
Old 07-30-2010, 02:41 PM   #39
BGRAFX
You guys in the southern states don't have ice storms or 6ft of snow. So shave away those mirrors and door handles.
Mine was done when I bought in the middle of summer. When its 100* I wasn't thinking about winter time until mid december I went out to go to work and my door poppers wouldnt open.
Old 07-30-2010, 03:33 PM   #40
justpball
justpball's Avatar
LOL...you mean it gets colder then 50?....
87 Crew SWB
Build for the crew
90 burb 2wd
Old 07-30-2010, 03:51 PM   #41
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
i welded some 3/4" all thread to some to make them adjustable
maybe its the fuzzy picture but the weld on such an important piece doesnt look that strong. I would double check the grade on that 3/4 all thread... i would want to know what grade for sure... im with everyone else.. ive never seen a grade 8 all thread. plus when you weld bolts, they arnt as strong as they use to be.
clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 07-30-2010, 04:13 PM   #42
Davidmichael
Davidmichael's Avatar
Yeah shaved doors would never work for me. I work the graveyard shift and in winter the temp can go into the single digits.
86 Suburban 2WD = rolled it and totaled it
83 LWB STD Cab 4x4 = went to the scrapper. Was my baby.
84 Suburban 2WD = stripped it/ scrapped it
81 8 foot bed made into a trailer
86 Suburban going to be made into a trailer
91 Suburban 4x4 = that's my baby
00 S10 Xtreme STD Cab
01 S10 ZR2
Davidmichael is offline   Reply With Quote
Old 07-30-2010, 05:55 PM   #43
maxxxy
maxxxy's Avatar
yall were right. i lowered the truck off the jack stands and the driveshaft doesnt clear. darn. :/
if the rod ends break and my whole truck falls apart i guess you guys can say i told you so. haha if i were to get rid of the all thread, what would you suggest i used to replace it to make my bars adjustable?
i was thinking the 88-98 handles are just more smooth with the body and give it the smooth look of being shaved but with the reliability of an actual handle. you suggest just keeping the stock handles?
Max
Max's bagged 81
Old 07-30-2010, 09:49 PM   #44
primrrd
primrrd's Avatar
the 88 on handles look pretty cool.
back in the late 80's - 90's when that was popular I would have every bodyman I knew cutting out and saving the handle mounts out of the doors and skins they replaced on the stock trucks for me. To add those handles was really double work from shaving handles... cause you had to shave the original handle, and cut and weld in the new handle skin/mount.
those 88 and up doors )ck) were easy to "pop" (thieves could jimmy under the handle with a thin screwdriver and work the lock rod..)
they made a theft preventer back then that was bolt on.. i used to double the area behind with tacking in an extra strip of sheet metal (typically trimed
off of the same door skin that the handle hole came out of ) to strengthen and help prevent a popper from access.
primrrd is offline   Reply With Quote
Old 07-30-2010, 11:16 PM   #45
joe231
joe231's Avatar
that's why you hide a manual release some where accessible from the outside
You could use the ends you have and weld them to pipe and get something like this
http://www.*****************/4-link-p...d-zerk-fitting
or find you some higher grade studs to weld on or bolts and cut the heads off
There is a build on another forum (I believe) who smoothed the ridges off the stock handles, it looked very custom
CHEVY ONLY
Old 07-31-2010, 12:52 AM   #46
maxxxy
maxxxy's Avatar
On the shaved doors and poppers, I know a lot about them and how they work but I I don't know about the emergency manual unlock. How does that work? Where do you hide it?
I don't think my welder can handle more than grade 5. And where do you find 3/4" bolts?
Max
Max's bagged 81
Old 07-31-2010, 08:54 AM   #47
scotts62
One day...
scotts62's Avatar
I got the 1" ones, yeah they are a little more but that is your suspension your playing with and i want to be safe than sorry.
If you need something welded just haller.
Scott
93 crew cab build
Project 62
Old 07-31-2010, 09:36 AM   #48
joe231
joe231's Avatar
You can hide a release cable under the cab.
If your welder can't handle it you probably shouldn't be welding on suspension parts with it.
Fastenal, Fastener World, J&E Supply
CHEVY ONLY
Old 07-31-2010, 11:41 AM   #49
primrrd
primrrd's Avatar
[QUOTE=maxxxy;4115624]On the shaved doors and poppers, I know a lot about them and how they work but I I don't know about the emergency manual unlock. How does that work? Where do you hide it?
Maxxy, the typical emergency release is a sheilded cable that hooks to the
release inside the door, and is routed thru the door jamb into the wheel well or some other inconspicous place for a manual release. A lot of the kits I see for solenoids actually come with one, or you are able to purchase one. But they are easy to rig.
Ive see folks use a universal choke style cable, and old section of speedometer cable, awnmower throttle cables, old bicycle brake or shift cables or even a piece of bailing wire! I knew of one truck that only had this type of release.
I left the lock cylinder on my 81 and use a key-pop.
Old 07-31-2010, 05:15 PM   #50
JohnC
JohnC's Avatar
Man you're killing me here! Hop on over here to Noble Hardware!
1981, bagged, c10, custom, oklahoma
