Old 12-02-2010, 06:10 PM   #26
West Texas Z
El Mero Mero Frijolero!!
West Texas Z's Avatar
Re: Suburban K20 1986 Silverado
Originally Posted by kikkegek View Post
thanks man!
appreciate it!
No prob, glad to help.
West Texas Z is offline   Reply With Quote
Old 12-02-2010, 06:45 PM   #27
Pop's C-10
Pop's C-10's Avatar
nice truck...
Pop's C-10 is offline   Reply With Quote
Old 12-03-2010, 02:58 AM   #28
kikkegek
kikkegek's Avatar
Originally Posted by Pop's C-10 View Post
nice truck...
thanks man!
kikkegek is offline   Reply With Quote
Old 12-03-2010, 04:41 PM   #29
chevak20
Thumbs up Re: Suburban K20 1986 Silverado
Nice suburban- I have two myself not as rust free though as your's.
I planning to paint one of them in blood red as this beauti.
I understand why import one from the CA.Rust free and the fact that it is a rare truck here, everything here in the EU when it comes to trucks has to be small and useless for me anyway Of course semi trucks huals majority of goods but for a house owner or country residents suburban fills all the needs. It is a daily used work horse.
chevak20 is offline   Reply With Quote
Old 02-24-2011, 06:54 AM   #30
kikkegek
kikkegek's Avatar
My bi-xenon bulbs were broken. didnt go from low to hugh beam, so highs were on all the time...hahahaha.
got them back yesterday, hopefully they work now and I can reinstall them...pics will be up soon!
Old 02-24-2011, 02:59 PM   #31
kikkegek
kikkegek's Avatar
GRRR...one of the two bulbs is till broken. I contacted the webshop...I hope they can solve this quickly.
Old 02-28-2011, 05:28 PM   #32
kikkegek
kikkegek's Avatar
wanted to change the rear too for LED versions.
tried these:
1157 bulb with 60 SMD's.
the difference between normal taillight and brake or signal is almost un-noticable.
check these videos from 2nite.
normal bulb 5W/21W
then the 60SMD Led version: no reflector
then the 60SMD Led version with red reflector:
too bad they didnt bring the result I wanted. changed back to the orignal bulbs again....
Old 03-21-2011, 05:41 PM   #33
kikkegek
kikkegek's Avatar
finally replaced the fuelpump 2nite.
at least something is shiny on my engine...I think the valve covers are leaking...
Old 04-02-2011, 03:27 PM   #34
kikkegek
kikkegek's Avatar
upgraded the dashboard:
- painted inside glossy white.
- added 5 strips of 3 SMDs attached them to the original bulb connections.
- added a small tach bottom left.
finish it of tomorrow.
before:
after:
Old 04-02-2011, 03:28 PM   #35
kikkegek
kikkegek's Avatar
5 LEDs:
5 strips of 3 SMDs:
Old 04-02-2011, 10:07 PM   #36
motornut
78K & 79C Jimmys
motornut's Avatar
we call that rust proofing here.........i'm diggin the lights gona paint mine soon too
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 04-02-2011, 11:58 PM   #37
iluvmy72
I like it....can I give you a pointer?....You might want to make a heat shield for that fuel cell. Looks too close to the exhaust. Your baby is really cute....hate to see the child hurt from a bad mod design.
iluvmy72 is offline   Reply With Quote
Old 04-03-2011, 06:05 AM   #38
kikkegek
kikkegek's Avatar
thanks, but I dont really know what you mean. Can you point it out in one of my pics?
Old 04-03-2011, 11:03 AM   #39
motornut
78K & 79C Jimmys
motornut's Avatar
it might just be the angle of the pic ,it seems close
John
Old 04-03-2011, 11:49 AM   #40
kikkegek
kikkegek's Avatar
connected the sender from my LPG tank to my regular gasgauge.
closed the dash again.
the new Tach is bottom left. And my LPG tank seems to have the same sender (0-90ohm) as my original gastank, because I just filled her up and she now also shows F (full).
now these lights dont work anymore :
- high beam
- handbrake
- 4WD
well, thats for next weekend.
Old 04-07-2011, 02:57 PM   #41
kikkegek
kikkegek's Avatar
took the charcole filter out 2nite. no need for it and lost some extra weight again :-)
Old 04-07-2011, 05:07 PM   #42
motornut
78K & 79C Jimmys
motornut's Avatar
every bit helps
you will be able to drive by more gas stations now!
John
Old 04-12-2011, 05:31 PM   #43
kikkegek
kikkegek's Avatar
got the electric fan setup done and it looks pretty fine.
and finally, my engine gets up to operating temperature. It hadnt gotten above 150F for over a year now! main reason...damn Flexfan! took it off, replaced it with an electric fan and voila..engine heats up nice and quick and when the fan hits 200F, it cools down within 1 or 2 minutes to 185F.
only thing left is to attach a LED parellel to the electric fan, so I can see on my dash if the fan is running or not...thanks for the tip Gchemist
Old 05-14-2011, 04:42 PM   #44
kikkegek
kikkegek's Avatar
removed the chrome pipes from my exhaust manifild that used to connect to the airpump.
finally I can see my valve covers :-)
Old 05-23-2011, 03:53 PM   #45
kikkegek
kikkegek's Avatar
just finished custom speaker door panels.
Old 05-24-2011, 09:23 AM   #46
motornut
78K & 79C Jimmys
motornut's Avatar
custom cool
they look puuuuurrrrrrrfect
John
Old 06-02-2011, 04:35 PM   #47
kikkegek
kikkegek's Avatar
FINISHED!
for a first custom door panel, I think these came out pretty nice!!
The tweeters are near the power windows knobs.
Old 06-03-2011, 02:03 AM   #48
chevak20
very nice job!!
What type of material are they made of?
Old 06-03-2011, 06:09 AM   #49
kikkegek
kikkegek's Avatar
Originally Posted by chevak20 View Post
very nice job!!
you can see how I build it a couple of posts back.
I used 12mm MDF, wooden rings, stretched t-shirt over it, epoxied it, then applied 200gr/m2 glasfibre and expoxied that again...used some body filler and then glued the lepardskin over it....came out pretty cool for my first custom door panel build.
Old 06-07-2011, 09:44 PM   #50
68Timber
I know the pieces fit
68Timber's Avatar
Nice work!
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
