Old 08-17-2010, 02:27 PM   #26
MONTEZ
Re: MONTEZ's LSx thread......
Originally Posted by 68GMCCustom View Post
BTW...got my cam in and hope to get it in soon. Then I can send that OEM cam out to you. I know your not going to use it...but its yours just the same.
I wouldn't worry about it. It'd just be a waste of money to ship it. I have another stock VVT cam now lol. But thanks for still offering to ship it.
Smoke Tires, not Drugs
MONTEZ is offline   Reply With Quote
Old 08-17-2010, 10:16 PM   #27
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
OK...if you say so.
I guess I could make some garage art out of it or something.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 08-23-2010, 05:11 AM   #28
tk-mpl
tk-mpl's Avatar
So what kind of HP you going to be putting down with the cam change??
1968 short box stepside.
2007 5.3L 4L60, tuned w/EFI Live
2005 Silverado bucket seats.
Dominator 2600's all around.
Porterbuilt tubular control arms.
Magnaflow 3" dual exhaust.
tk-mpl is offline   Reply With Quote
Old 08-23-2010, 07:24 AM   #29
MONTEZ
Since I'm taking the DOD out, I will probably put a set of LS7 lifters back in it and possibly a set of LS3 valves. The m90 performance package that I will be using (cam,springs,harness,ecu,air filter) is rated at 525hp. That's a somewhat modest rating. They actually put down more around 540hp. Hopefully with the lifters and valves added, I may push it to 550hp, but even still 525hp will be more than enough for what I have planned for it.
Old 08-23-2010, 09:30 AM   #30
tk-mpl
tk-mpl's Avatar
Wow, that is impressive. What kind of mods do you have to do to the trans so it will hold that power. Your using the 6L80 right?
Old 08-23-2010, 09:58 AM   #31
MONTEZ
None. The 6l80 should hold that fine as long as I'm not out on the track beating the snot out of it every weekend.
Old 08-23-2010, 01:18 PM   #32
68GMCCustom
mine should produce similar numbers with the cam I finally went with (223/231 @ .050 - .610/.617lift 112LSA). I haven't seen any test results on it but based on comparisons to other cams tested with the same block/heads config I have...should be over 500hp, not sure how much though. An earlier cam choice was capable of 525-530hp or so...and this cams bigger.
My 200-4r was built for 500+hp and has a 2500rpm stall converter. I do plan on taking mine to the track and beating on it...and breaking parts until I get it tweaked.
Kurt -
Old 10-19-2010, 12:08 PM   #33
mac72
Montez,Thought I'd post over here ,few of those guys in the "dropmember " thread are a little snooty!
I looked into Mast A year or so ago & really wanted to use their controller package but just couldnt swing the $$$.I purchased a wrecked 05 gto from the auction & got the harness ecm etc. so I decided to go that route.I'll just tune it w/ hp or efi live.I wanted to use their Blk. Label fuel rails also but again price was the big factor
Its kinda hard on us working guys to afford stuff like Mast & Fast etc..But I know the quality is on par w/ the price.You ought to look into Mast doing some kinda deal for forum members,maybe they can get the price a little more reasonable.
The tape is just body shop 2"
mac72 is offline   Reply With Quote
Old 10-19-2010, 12:27 PM   #34
MONTEZ
I dont think i would be able to swing a member discount since they arent vendors but I could mention to him about maybe getting some group buys together. To be honest even before I got in on the employee discount, I had weighed my options on harness and pedal and ecm options etc... and when it comes down to it, you only save about $500 staying with the stock computer and harness, provided you don't modify the harness yourself. So I figured a 3 wire hook up with the added potential was the way to go.
I know how it is building on a tight budget. We have a newborn and my wife is now a stay at home mom, so I decied to get a side job to help fund the project, just happened to work out that I knew the guys at MAST . But I also decided where I would cut cost and where I wouldnt and the the M-90 was gonna happen one way or another....
Old 10-19-2010, 01:24 PM   #35
68GMCCustom
my budget is gone too
so... many things that would have been done....will be now be future upgrades.
Kurt -
