08-14-2010, 04:34 PM | #26 |
1961 crewcab
Re: Crew cab ??
page 2!
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
08-14-2010, 04:38 PM | #27 |
1961 crewcab
Re: Crew cab ??
cc's
08-14-2010, 04:43 PM | #28 |
1961 crewcab
Re: Crew cab ??
green 61- proctor-keefe
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 Last edited by jonzcustomshop; 08-14-2010 at 06:14 PM. |
08-14-2010, 04:49 PM | #29 |
1961 crewcab
Re: Crew cab ??
last one has a suburban rear 1/2
08-14-2010, 04:54 PM | #30 |
1961 crewcab
Re: Crew cab ??
08-14-2010, 05:00 PM | #31 |
1961 crewcab
Re: Crew cab ??
08-14-2010, 05:04 PM | #32 |
Re: Crew cab ??
Wow...
You really came through with the pics! You must have been waiting for a newbie like me to ask the question, lol. I really like the truck on post #26. That is perfect! Now my question is the rear doors... Do they use the stock size glass, and just remove the wing window portion? For some reason it looks like the glass might be bigger (maybe surburban glass?). Thanks for all the pics/inspiration/intimidation, lol! |
08-14-2010, 05:06 PM | #33 |
1961 crewcab
Re: Crew cab ??
more
08-14-2010, 05:10 PM | #34 |
1961 crewcab
Re: Crew cab ??
that #26 is norms truck, also same door as dinos, the door measures 32 1/8 long, and I don't know for sure, but think they might just be a 456 door cut down at the vent window...
08-14-2010, 05:18 PM | #35 |
1961 crewcab
Re: Crew cab ??
08-14-2010, 05:28 PM | #36 |
1961 crewcab
Re: Crew cab ??
pic#5 is a canadian one, have seen pics of a couple different ones of these, they have no rear doors, and fixed rear windows...
08-14-2010, 05:38 PM | #37 |
Re: Crew cab ??
That nice truck in the last post shows the 456 door with the wing window cut out (the edge toward the B pillar is squared off vs. round). I wonder if the only difference between the two is how the metal was shaped. For all I know it still could have the same glass inside the channel. Great stuff jonzcustomshop .......PS with all this CC info, shouldn't you have one in the works?
08-14-2010, 05:39 PM | #38 |
Check The Champ, Demonstrator
Re: Crew cab ??
I feel so inept, thinking of building one jonz........
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
08-14-2010, 05:39 PM | #39 |
1961 crewcab
Re: Crew cab ??
...l
08-14-2010, 05:48 PM | #40 |
Re: Crew cab ??
Shouldn't you change your user title to 17 trucks and parting!
08-14-2010, 06:01 PM | #41 |
1961 crewcab
Re: Crew cab ??
^ haha new pics to save thanks aero!
some of the info i have gathered: these were coach built. you ordered your truck, and then 6 weeks later the coach builder delivered it. some of the builders were stageway, crown, proctor -keefe. they all approached the build differently. pretty much all the "factory" crews I have seen piccs of were small back window-not every last one, but bbw was rare in this already rare truck! the wheelbase was all over the board, but most common was just a stock 127 inch lwb with the bed cut back. some were also the 133 inch wb cab/chassis frame. however norms (flat black 456) and a few others pictured were a lwb box, resulting in a 33 inch extension of the frame. there is a nice tan 66 I have pictured in the thread that was a stageway with a 12 inch frame extension. some (all?) of the stageways replaced the wood bed floor with a steel plate. there are 2 different kinds of doors- the earlier 60-61's used a cut down 60-63 door, about 30 inches long, and retained the vent windows. 62^ or (just stageway?) used the 32 1/8 inch door with the square cut front. most of the 456's seem to have this door as well.. a third door was in the mix, I have a green 61pictured with this cab, which used an almost full length door from a 60-61 -literature says it adds 36 inches to the cab. some crews were a 3 door, and some a 4... there are 2 different styles of roof skin. one stays low all the way to the crown in the back. the other meets the stock crown in the middle of the cab, and then is higher through the 2nd half of the cab. I do not have many pics of the headliner, but from what I have seen , it looks like the metal headliner was removed, and portions of tin were installed around the perimeter , like a suburan.
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 Last edited by jonzcustomshop; 08-14-2010 at 06:09 PM. |
08-14-2010, 06:04 PM | #42 | |
1961 crewcab
Re: Crew cab ??
1 project, and a couple scrap runs are going to cut the fleet down by a third! V -dinos truck
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 Last edited by jonzcustomshop; 08-14-2010 at 06:08 PM. |
08-14-2010, 06:11 PM | #43 |
1961 crewcab
Re: Crew cab ??
got about 10 more pics, and maybe 50(?) of dinos, that I will load later...
pictures = 1000 words right? hope all these helped!
08-14-2010, 06:11 PM | #44 |
Re: Crew cab ??
My preference is the rear door that follows the form of the front door with no filler in between. As for the interior I would prefer to use a complete door bottom and modify the top section to follow the front door. This would require reworking the rear door panel as not to retain the dip. Suicide the rear doors.
Headliner, could copy the rib design to the rear section as to the original front. A complete fleet short box with grafted stepside fenders, dually! Now burst my bubble! Edited: And all the original accessories! LOL!
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 Last edited by aerotruk63; 08-14-2010 at 06:14 PM. |
08-14-2010, 06:33 PM | #45 |
1961 crewcab
Re: Crew cab ??
here you go (photo shop)
08-14-2010, 06:48 PM | #46 |
Re: Crew cab ??
yeah but a 63, don't know why!
08-15-2010, 06:37 AM | #47 |
Re: Crew cab ??
08-16-2010, 12:03 AM | #48 |
60-66 Nut
Re: Crew cab ??
Now this is a cool Crewcab truck! Just too bad they didn't use the '60-'63 doors on the rear, then it would have been perfect.
08-16-2010, 01:21 AM | #49 |
chevy only
Re: Crew cab ??
jon nice job!! the picture of the 4x4 with the bike is my truck before i bought it. the change it to a two wheel drive then i bought it , the truck wasnt drivable since 1979
CHEVY ONLY... Nothin Else ! |
08-16-2010, 09:46 AM | #50 |
1965 Chevy C10, 2005 4.8L/4l60
Re: Crew cab ??
Posting #11 truck at bottom and #19 The charcoal long bed is my dad's truck.
Leg room in the rear is very tight for a taller person, the seat is a stocker cut down.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
