Old 04-29-2012, 10:08 PM   #26
Ford Assassin
Ford Assassin's Avatar
Re: got the notches put in!
Another run at the top....
Cable
-K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt
-Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608
Ford Assassin is offline   Reply With Quote
Old 04-29-2012, 11:57 PM   #27
Square_78
Square_78's Avatar
Originally Posted by stevieB View Post
I also plated the inside of the frame
Did you box it in, or just add another plate to the inside of the c-channel? I would BOX that whole notch in especially directly above the notch itself where its the smallest and weakest. Looks kinda scarey right now to be honest. I've seen setups like that where the top of the frame bends around the notch and all of a sudden your truck is sitting lopsided and dog legged. Kinda hard to explain, but you should box it in. Nothing wrong with the way you've done it, Looks like a solid start. I just think you should go the extra mile as you said and add some more plate to the inside to finish it up
Cheers
Lonnie
Square_78 is offline   Reply With Quote
Old 04-30-2012, 11:13 AM   #28
stevieB
stevieB's Avatar
well I plated the the inside of the frame, but that setup is gone now i have a step notch now, thats the reason i didnt want to box it in at first, because I knew i was going to change it out, but my step notch is boxed in on the inside from where the frame steps up in the back, but i didnt get any pictures.
stevieB is offline   Reply With Quote
Old 08-20-2012, 08:00 PM   #29
UKNOWME
UKNOWME's Avatar
Does anyone know how low it will lay on bags with only a c-notch? I do not want to cut the floor but would like to bag it. Thanks
2018 Audi S5- wife's ride
1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511
1981 Chevy Silverado- in pieces
1964 Chevy c10
2017 Jeep Wrangler JKU
UKNOWME is offline   Reply With Quote
Old 08-21-2012, 10:27 AM   #30
blazer2007
I,m just finishing my blazer with a c notch flipped with 3 leafs left in and a 1 inch lowering block and the pumpkin hits the floor,but the driveshaft hits the the crossmembers and some of the floor by the looks of it,so take your driveshaft out first and check later so you don,t bend shaft or brake tailshaft
blazer2007 is offline   Reply With Quote
