08-18-2010, 11:16 PM | #26 |
60-66 Nut
Re: Which way do the engine stands go in?
Aside from trying to explain to Clyde65 the differences in motor mounts between the '63-'66's and the '67-'72's. All I was saying is you need to just switch sides....take the one on the left side and put it on the right side and vice-versa. I think that would have solved your problem.
08-19-2010, 03:15 AM | #27 |
GM ONLY BABY!!!
I called my friend who has an unmolested 72 Chevy and his are in the same way that mine are in the pic. He also has a sbc 1/2 ton 2wd. I got it in. Just slotted most of the holes in the engine stands and frame in order to gain some width between the engine stands. It must be the 3/8" thickness of the plates that is the issue. thanks guys!
2 wrongs don't make a right, but 3 lefts do. 66 Chevelle Malibu 406ci, 573hp, 10.99@121mph 96 Chevy Silverado Z71 72 GMC 1500 Super Custom LS 6.0/4L65 on airride http://www.cardomain.com/ride/707879...mc-c-k-pick-up |
