Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1988 - 1998 GMT400 Chevy & GMC Pickups Message Board > projects and builds 88-98
Old 08-30-2010, 06:39 PM   #26
AverageJoe
Re: First truck project! 89 Silverado 5.7 350 V8!
yeah i did away with the y also
AverageJoe is offline   Reply With Quote
Old 08-30-2010, 06:50 PM   #27
Chevy350V8
Semper Fi!!!
Chevy350V8's Avatar
Originally Posted by Dotes15 View Post
True shorties would be best, and most do bolt to the y pipe, but i would get rid of the factory y pipe they kill hp. Ive seen 20hp gains from taking it off. Remember your exhaust is only as good as the worst flowing part
wow good call joe i was maybe 30 seconds into buying one lol. Yeah im thinking now maybe str8 them. But might just take the whole thing off and run shorties. Thanks for help guys.
Brandon...
"IT ONLY TAKES EVERYTHING YOU GOT!!"
Semper Fi
Chevy350V8 is offline   Reply With Quote
Old 08-30-2010, 07:25 PM   #28
Vega_67C10
Vega_67C10's Avatar
The thicker the flange the better, if you don't go with 3/8' flange I would think about these http://www.summitracing.com/parts/JEX-FLX3010B/
Nothings worst than spending all that money and 6 months later you have a warped or cracked header, plus for the price they look really cool.
I Saw Elvis at 1000 Feet - John Force
Vega_67C10 is offline   Reply With Quote
Old 08-30-2010, 07:26 PM   #29
AverageJoe
what i did was get a collector extension kit from jegs, have them bent like the stock pipes are and voila, true duals with no y pipe. But mine dump right where the bed starts. But if you want your pipes to exit by the bumper, you have to have them side by side cause of the tank.
Old 08-30-2010, 08:11 PM   #30
Chevy350V8
Semper Fi!!!
Chevy350V8's Avatar
is this what you got? http://www.jegs.com/i/Hedman/500/69440/10002/-1
Brandon...
Semper Fi
Old 08-30-2010, 09:05 PM   #31
AverageJoe
no, i got these shorties http://www.summitracing.com/parts/BIG-11504FLT/
And then these and bent them how i wanted them http://www.jegs.com/i/JEGS/555/30631/10002/-1
then welded my mufflers at the end of those with turndowns, it comes out right at the beginning of the bed though.
Cheaper than a muffler shop, but i do all my own stuff.
Old 08-30-2010, 09:33 PM   #32
Chevy350V8
Semper Fi!!!
Chevy350V8's Avatar
Cool, it did fit in place of the factory ones right? did it make it sound better?
Brandon...
Semper Fi
Old 08-30-2010, 09:43 PM   #33
AverageJoe
It should fit in place of the factory ones, but its 3" collector
Old 08-30-2010, 10:16 PM   #34
benoit454
Chris
benoit454's Avatar
The ones I bought from ebay instainless for $122 shipped fit directly in place of the stock manifolds and the top side is a very thick flange has to be at least 3/8 or so. The collector is thick as well and as mentioned uses no gaskets it's ball end to fit in place of the stock manifolds and bolt to stock pipes without a donut gasket. I love em.
Chris
GIT R DONE!!!!!!
Check out all our rides,
Old 08-31-2010, 09:50 AM   #35
AverageJoe
could you look those up for us?
Old 08-31-2010, 12:48 PM   #36
benoit454
Chris
benoit454's Avatar
I already did they are in my buid thread here, called 88 buildup on a tight budget or just go search ebay for the ones I had from tuning pros or 88 chevy truck headers, it aint hard.
I did it anyways took less then a minute...
http://shop.ebay.com/i.html?_trkparm...&_sop=15&_sc=1
tons there...
http://cgi.ebay.com/ebaymotors/CHEVY...Q5fAccessories
an auction for some just like mines..
http://cgi.ebay.com/ebaymotors/Chevy...Q5fAccessories
That's the ones I bought and are now cheaper of course lol.
my thread about halfway down this page is the headers and pics of them installed and such..
http://67-72chevytrucks.com/vboard/s...=376083&page=2
here's the other thread of mine with more pics including how thick they flange is and the ball end and how they discolored.
http://67-72chevytrucks.com/vboard/s...=395994&page=2
Chris
GIT R DONE!!!!!!
Old 08-31-2010, 03:35 PM   #37
Chevy350V8
Semper Fi!!!
Chevy350V8's Avatar
tons there...
Sweet, thanks man. About how long did it take to install and how happy are you with them? (The one that you got http://cgi.ebay.com/ebaymotors/Chevy...Q5fAccessories )
Brandon...
Semper Fi
Old 08-31-2010, 05:01 PM   #38
benoit454
Chris
benoit454's Avatar
I'm very happy with them, mine had duals and I didn't have a welder fo I didn't want to cut or weld anything, as for bolting thwem on not long. About as long as it'd take to remove the 3 lower bolts and the 6 upper bolts on each side, maybe a couple hours or so if that but mine had been off recently. If the manifolds aint been off might take a little longer. I removed all my plugs so I wouldn't drop one and break a plug, and that was the biggest PITA of the whole job putting the back 2 plugs in on either side. You need an offset 5/8 or short 5/8's socket made for plugs that let's you use a wrench on, but I got by with a regular box end 5/8 it just took some time.
Chris
GIT R DONE!!!!!!
Old 09-01-2010, 09:05 PM   #39
Chevy350V8
Semper Fi!!!
Chevy350V8's Avatar
Well i found out that i need some rear lights and high beam lights. Im going to try and get the bed armoured and clean up the cab corenrs. There not rusty just a little surface rust. I can post pics a little later when i get it done. Im using coke and rust stoppage black paint. Any one else have a better way? Thanks
Brandon...
Semper Fi
Old 09-11-2010, 08:34 PM   #40
Vega_67C10
Vega_67C10's Avatar
lol we will see come playoffs lol
Old 09-11-2010, 11:22 PM   #41
benoit454
Chris
benoit454's Avatar
sand it off and use self etch primer, then wetsand it and paint it.
Chris
GIT R DONE!!!!!!
Old 09-12-2010, 08:40 AM   #42
Chevy350V8
Semper Fi!!!
Chevy350V8's Avatar
Originally Posted by Vega_67C10 View Post
idk we coming for blood lol
Brandon...
Semper Fi
Old 09-13-2010, 07:20 PM   #43
Chevy350V8
Semper Fi!!!
Chevy350V8's Avatar
Getting some new chrome valve covers!! And i put a 4" Pipe with a flowmaster on it. SOUNDS SWEET! I made a video, let me know if you want to see it.
Brandon...
Semper Fi
Old 09-13-2010, 08:46 PM   #44
Dotes15
Dotes15's Avatar
Heck ya we want to hear it
"I can fix anything, unless it's mine"
5/22/11 Joplin Strong
94' Chevy Shortwide "Amanda"
94' Honda Accord 30mpg DD
67' Chevy C10 LWB (Current project)
04' Kawasaki ZR-7s
Dotes15 is offline   Reply With Quote
Old 09-13-2010, 08:51 PM   #45
jyaughn
jyaughn's Avatar
yeah i wanna hear it.
jyaughn is offline   Reply With Quote
Old 09-13-2010, 09:27 PM   #46
Chevy350V8
Semper Fi!!!
Chevy350V8's Avatar
Here ya GO!!! Ima make a video tomorrow getting it a little higher rpms. I didnt want to tick of the neighbors lol.
Brandon...
Semper Fi
Old 09-13-2010, 10:25 PM   #47
jyaughn
jyaughn's Avatar
sounds pretty good. sounds about like mine but mines a three inch pipe with a flowmaster with duel outlets
Old 09-14-2010, 05:44 PM   #48
bigblazerboy
bigblazerboy's Avatar
Headers are always good the link below is what I put on my truck good price for long tube.
And some flowmasters woulndnt hurt
is your truck a 4wd? i want a set for my 4wd tahoe
1995 tahoe lt 4x4
http://www.cardomain.com/ride/3856942
bigblazerboy is offline   Reply With Quote
Old 09-24-2010, 05:19 PM   #49
Chevy350V8
Semper Fi!!!
Chevy350V8's Avatar
Got the new Flowmasta on!! http://www.youtube.com/watch?v=rSljeChOZ4c sorry that i mention scyler alot. Its one of my friends that wants to drag with me.
Brandon...
Semper Fi
Old 10-02-2010, 07:08 AM   #50
Chevy350V8
Semper Fi!!!
Chevy350V8's Avatar
Well painting the rims today! I will get some before and after pics l8r! And also dropped the clutch for the first time! Heres the pics!
Brandon...
Semper Fi
