09-28-2010, 12:00 PM | #26 |
Junior Member
Re: Extra parts
I have a complete frontend froma 72 with 1.25" rotors. will those spindles work with the correct balljoints? Are the wheel bearings the same. I might be interested in just the spindles if 71super still wants everything else...
frontstreetcycle on Instagram |
09-28-2010, 03:54 PM | #27 |
Re: Extra parts
They will work with the correct 73-87 ball joints. I thing only the upper are different but you will need to verify. I'm waiting on 10.5Stang to get back with me and then I'll let you and 71Super know if I'm going to separate.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
09-29-2010, 05:46 PM | #28 | |
Re: Extra parts
Do you want the proportioning valve?
09-29-2010, 09:31 PM | #29 |
Re: Extra parts
Still interested in the proportioning valve... however I have been trying to get some info from CPP ... I have 7/8" Wilwood master cylinder and wanted to make sure I didn't need the CPP upgraded valve.
Any ideas? |
09-29-2010, 09:41 PM | #30 |
Re: Extra parts
I'm not sure. What's the upgraded valve?
10-02-2010, 12:15 PM | #31 |
Re: Extra parts
Bttt
10-06-2010, 09:30 AM | #32 |
Re: Extra parts
Paging 10.5 Mustang. Do you still want these parts?????
10-06-2010, 10:08 AM | #33 |
GobbleStalker Calls
Re: Extra parts
What do you still have left of these?
72 Chev Longbox Highlander edition. Med Olive/White/ Med Olive 350 4bbl with 350Turbo trans. Truck currently under construction. Project Cappaccino. Stay Tuned! 1967 Chevy C10, 327, 4.11 posi 3 spd. The Driver Truck! SOLD! 09 GMC Sierra SLT All Terrain pkg. 2014 Jeep Wrangler Sahara unlimited. ( The wifes ride ) |
10-06-2010, 10:20 AM | #34 |
Re: Extra parts
I still have everything but the trackbar.
10-07-2010, 09:47 AM | #35 |
Re: Extra parts
bttt
10-08-2010, 12:33 AM | #36 |
Re: Extra parts
not sure what open carrier means on 373. is it posi? what will it fit? 12bolt? thanx rich
10-08-2010, 07:27 AM | #37 |
Re: Extra parts
Rich - it's a non-posi. It comes with the ring and pinion, carrier, spider gears, c clips....pretty much all the inner guts. I'm pretty sure it will fit 62 up to 80's 12 bolt truck rear ends.
10-10-2010, 12:40 PM | #38 |
Re: Extra parts
bttt
10-16-2010, 09:01 AM | #39 |
Re: Extra parts
bump
10-16-2010, 09:13 PM | #40 |
Re: Extra parts
Sorry people have not pulled the trigger on this stuff. Great deals. Here is a bump for you.
68 BB burb build thread Scott's super slam front/rear http://67-72chevytrucks.com/vboard/s...d.php?t=378084 |
10-21-2010, 03:38 PM | #41 | |
Re: Extra parts
R/
10-26-2010, 07:38 PM | #42 |
Re: Extra parts
New Prices!!!!! 10/26/10
10-26-2010, 07:52 PM | #43 |
67-72 parts collector,…
Re: Extra parts
Rob,... can you do $40 shipped on the CPP disc/disc proportioning valve to 65251?
I can Paypal you tonight.
10-26-2010, 10:08 PM | #44 |
Re: Extra parts
Sounds good. Do you want the front braided lines also?
10-26-2010, 11:06 PM | #45 |
Re: Extra parts
No,... just the proportioning valve.
PM me your Paypal info and I'll send you $40. thanks.
10-26-2010, 11:20 PM | #46 |
Re: Extra parts
Money Sent.
Thanks.
10-26-2010, 11:23 PM | #47 |
CopyWritten
Re: Extra parts
Rob,
I bought a set of front braided lines from Summit (russels) and they rub my front tires and have almost worn all the way through. Do the ones you have rub the tires? |
10-26-2010, 11:25 PM | #48 |
Re: Extra parts
Thanks Keith. I'll get it shipped by the weekend.
They don't rub on mine. Do you have pictures of how you have them installed?
10-26-2010, 11:35 PM | #49 |
CopyWritten
Re: Extra parts
not sure if this helps, but maybe they are too long I dont know?
10-28-2010, 11:11 AM | #50 |
Re: Extra parts
I looped mine. I'll try to get you a picture later.
