Old 10-17-2010, 07:59 PM   #26
raycow
Re: 87 2wd 1/2 ton lift
Originally Posted by 1FASTHOE View Post
Here's the 3/4 arms, i dont see a difference other then the zerk fittings and ball joint..
When you say the ball joints are different, are you seeing a difference in the taper diameter?
Ray
raycow is offline   Reply With Quote
Old 10-17-2010, 09:41 PM   #27
1FASTHOE
OK, you busted me. just the zerk fitting
i did call my local parts shop and they the difference between 1/2 and 3/4 ton is huge, not only in diameter, but also weight
1FASTHOE is offline   Reply With Quote
Old 10-18-2010, 03:26 PM   #28
Prerunner1982
Prerunner1982's Avatar
Ray
The diameter of the ball joint "base" where is fits into the control arm is different than the 1/2 tons... or should be.. that is the reason for swapping the arms. I would assume the "shaft" diameter/taper is different as well or else you could use the 1/2 ton ball joints as well...
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 10-18-2010, 08:32 PM   #29
1FASTHOE
HOLY CRAP.... i just did some research on ball joints and found brand new control arms for 100 bucks and it comes with the lower ball joint...
so if you guys are thinking about doing this lift, i would suggest going new.
i would if i did it over again. i spent 3 hours cleaning the ones i got from the bone yard... just some FYI for ya
Old 10-27-2010, 01:45 PM   #30
Prerunner1982
Any updates?
Jon
Oklahoma Roll Call
Old 10-27-2010, 06:59 PM   #31
1FASTHOE
between life and bills.....you know
hope to have it together by the end of the year, if not sooner...
you dont have any spare cash laying around do you ? i'll pay ya back....no really
Old 10-27-2010, 07:14 PM   #32
Prerunner1982
lol I understand... seemed you making good progress so I thought I would check..
Jon
Oklahoma Roll Call
Old 10-30-2010, 06:18 PM   #33
1FASTHOE
Installed a add-a-leaf to the rear, i couldn't take it being so low any longer.
Old 10-30-2010, 06:20 PM   #34
1FASTHOE
here's a shot of the front too...
Old 10-30-2010, 11:17 PM   #35
1FASTHOE
finally went down the to parts store and took the 4" lift spindle with me to if the 3/4 ton ball joints would fit....well quess what....they dont fit.
i even had the 3/4 ton a arm with me to compair it with...no luck
so i asked the guy for half ton joints and they seem to fit...
so i have to ask, why did i need to buy 3/4 ton control arms when my 1/2 ton arms will work, they are the same size, length and width...?
i didnt buy any joints today and i was researching parts numbers, 88 compaired to 87....they are the same part number, 88 1/2 ton truck to 87 1/2 ton suburban....any ideas boys ?
Old 11-11-2010, 06:43 PM   #36
Prerunner1982
I am sorry if I mis-lead you...I was just passing the information as I understood it. Unfortunately that is part of the process of being the first to do it and do a write up on it. Keep a record of the parts and part #s for the write up so there won't be any confusion... as there seems to be now.
I as understood it, the 88+ lower ball joint was larger than the 73-87... so an A-arm with a larger hole was necessary.
Jon
Oklahoma Roll Call
Old 11-13-2010, 04:31 PM   #37
1FASTHOE
i knew before jumping ahead this was going to be hit and miss, so dont worry about it prerunner.
let me ask this, what do you think about just installing 3/4 springs to the front of my sub ? there only 90 bucks a set.
Old 11-15-2010, 12:53 AM   #38
Matt Man
Matt Man's Avatar
i would throw some 1 ton diesel or severe duty coils in it, and maybe a coil spacer.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11
1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020
67 GMC Stepside Straight six/3 on the tree "The Peach"
2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver
K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934
The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903
Matt Man is offline   Reply With Quote
Old 11-16-2010, 12:07 PM   #39
Prerunner1982
I am not sure if there is a difference between 3/4 ton and 1 ton/diesel coils... if there is you might as well go with the 1tons...
I have HD front coils which I believe to be 1ton/diesel coils and it leveled my truck out front to back...the back is still stock. So I would say it gave me 1-1.5" of lift.
However from the pictures it appears you suburban already sits pretty level. Maybe it is just the perspective of the camera..... but it looks like the back end does not sit higher than the rear as a truck normally would. It is pretty typical of a Suburban to sit with it's rear lower.. If you put HD coils in the front you might end up with the front higher than the rear...
Jon
Oklahoma Roll Call
Old 11-17-2010, 09:01 PM   #40
1FASTHOE
are 1 ton springs going to make the ride very rough ?
and also, whats the tallest tire i could install without rubbing to bad,i have 31" on now.
tallest tire after the coils...
Old 01-11-2011, 01:28 PM   #41
78c10
Any progess? Curious about this swap myself, just want it to ride higher to make it through the occasional floodwaters around here (I know better than to drive into moving water, though)
78c10 is offline   Reply With Quote
Old 01-13-2011, 10:33 PM   #42
Billybob13
Billybob13's Avatar
just out of curiosity why didnt yah buy a body lift instead of this hassle that might fall apart in time?
'83 chevy c-10 scottsdale 400 cid 2wd "chelsea"
Billybob13 is offline   Reply With Quote
Old 01-14-2011, 10:00 AM   #43
Prerunner1982
In my opinion body lifts look cheap.. you end up with a gap between the body and frame, which stresses the body mounts especially in the bed if you haul things. Your bumpers don't look right unless you got the bumper relocaters, you still have to adjust things and fix things (lower fan shroud, steering column, shift linkage, wiring, etc.).
Jon
Oklahoma Roll Call
Old 01-14-2011, 05:53 PM   #44
Billybob13
Billybob13's Avatar
makes enough sense
Old 01-20-2011, 12:51 AM   #45
lsp1369
anyone have any idea where you might be able to get a coil spacer for these trucks.. i have a 73 2wd and i swapped for the 1 ton springs but i just need a little more to get the look i want..
1fasthoe.. keep up the good work id like to see how this one turns out. and those spindles look pretty stout.. where did you get them? price?
lsp1369 is offline   Reply With Quote
