04-07-2011, 08:24 PM | #26 | |
Re: 47 1-Ton to S10 build
This is from BBEEP's build thread, the big bolt hood is on top of the 1/2 ton hood:
build threads: 86 Suburban 88 Jeep 6.0 swap 49 Chevy truck 54 Chevy wagon 86 Suburban lowered 4/6 54 Chevy wagon 49 Chevy/s10 mix 88 Jeep Wrangler rockcrawler Last edited by BlueJeep; 04-07-2011 at 08:27 PM. |
04-08-2011, 03:39 PM | #27 |
Doin' it live!
Thanks. I was leaning toward him having the standard front end but was hopeful I had found someone that was going to try and use the Big Bolt front end on this kind of swap.
I have a50 GMC with the Big Bolt nose and I want to put it on an S10 but the problem is i can't justify swapping the nose off because it is original to the truck and belonged to my wife's grandpa. We'll see what happens. -Panelrodder
-Panelrodder 1953 GMC Panel truck - 'Curly' 1961 Chevy Suburban - 'Larry' - Sold 2005 Harley Sportster - 'Shemp' |
04-17-2011, 11:24 AM | #28 |
Pic of the frame just needs shock mounts and sway bar mounts welded up.
Cab in the process of being mounted. Went on pretty smooth with the Kubota.
1947 5 Window bagged S-15 frame 5.3 w/4L80E 1960 Apache LS Swap 5.3 w/4L80E |
04-17-2011, 04:45 PM | #29 |
[QUOTE=bustac;4629832]Pic of the frame just needs shock mounts and sway bar mounts welded up.
Question: Is the sway bar stock s10 and did it bolt up in stock location? Confused on the sway bar I am thinking of installing one on my project and the frame I have does not have one. |
04-18-2011, 11:37 PM | #30 |
My S-15 already had one, so there bolt holes under the frame for the mounting brackets, I'm using one of the heavy duty ZQ8 bars which is a direct bolt on. I just need to weld some tabs to my lower arms to bolt the end links to.
[quote=eventytoo;4630316]
04-30-2011, 07:07 PM | #31 |
[quote=bustac;4632947]My S-15 already had one, so there bolt holes under the frame for the mounting brackets, I'm using one of the heavy duty ZQ8 bars which is a direct bolt on. I just need to weld some tabs to my lower arms to bolt the end links to.
ok, Can you show me a picture on how your endlinks are? Are you using a factory stye bar endlnk? I notice when the bags are deflated the endinks are way out of wack (at an incorrct angle and almost to the point of being bent). |
06-14-2011, 07:01 PM | #32 |
Cab bolted back up, 90% of the wiring is done, corner glass and windshield installed. Hood is back on now I need to hang doors and more pics.
06-15-2011, 10:49 AM | #33 |
Looks great! What gas tank and headers are you using?
Current project: 1946 GMC 1/2 ton on S10 Chassis, powered by a 5.3L LSx with a 4L60e Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=431631 |
06-15-2011, 01:02 PM | #34 |
Sumpped fuel cell was made up from a guy on Epay, headers are were for a 5.3 Silverado, stainless also from Epay about $200 and change, same for the tank.
06-15-2011, 01:47 PM | #35 |
Do the headers you used provide ample room for the steering shaft?
06-15-2011, 02:49 PM | #36 |
Clearance on the steering shaft was good, I had trim the two outer ears of the 4L80E transmission which I'm told is pretty standard.
07-09-2011, 06:52 PM | #37 |
She fires, nothing to exciting and only cell phone vid. But she does run and has throttle response. Still need rad and tranny lines hooked up.
First times starting... http://tkzdesigns.com/busta/1947chevy/IMG_0721.MOV
07-11-2011, 04:58 PM | #38 |
Could you pass along some info on your choice of black paint?
07-11-2011, 06:08 PM | #39 |
The paint is Hot Rod Flat Black from Eastwood.
07-11-2011, 07:46 PM | #40 |
Fine looking ride, what kind of motor mounts did you use and did the AC compressor clear ok. Thanks Bill
07-12-2011, 11:24 AM | #41 | |
1" I did notch the frame a little to fit the stock A/C compressor.
08-18-2011, 11:40 PM | #42 |
Anything new on this pickup lately?
1951 Chevy 3100/S-10: http://67-72chevytrucks.com/vboard/s...d.php?t=406072 1957 Chevy 3200 1971 2WD Blazer - Sold |
09-07-2011, 08:05 AM | #43 |
Couple of start up vids: Radiator, condensor, intake hood, doors installed.
Engine Compartment http://tkzdesigns.com/busta/1947chevy/IMG_0811.MOV Exhaust http://tkzdesigns.com/busta/1947chevy/IMG_0812.MOV
09-07-2011, 10:03 PM | #44 |
Did you use the truck oil pan or did you switch to an F-body one? What did you use for motor mounts? Looks good!
build threads: 86 Suburban 88 Jeep 6.0 swap 49 Chevy truck 54 Chevy wagon 86 Suburban lowered 4/6 54 Chevy wagon 49 Chevy/s10 mix 88 Jeep Wrangler rockcrawler |
09-07-2011, 10:21 PM | #45 |
Junior Member
Great build, gonna' be a great truck. Am enjoying watching your progress.
Cayoterun
Cayoterun Okla. Panhandle I think I'll do it myself and pay the extra $500. |
09-08-2011, 07:56 AM | #46 |
Right now I still have the truck pan and it does hang low. If I lower the bags all the way it sits right on the ground. Might just make some sort of skid plate?
09-11-2011, 05:08 PM | #47 |
Junk Yartist
why haven't I subscribed to this thread yet? Now I am!
-Jeremy YOU ONLY FAIL IF YOU STOP TRYING 70 Crew Cab Build Link 70 GMC Suburban 4X4 build thread 95 Yukon Daily Driver Rebuilding an NP205 |
09-16-2011, 02:37 PM | #48 |
Couple new pics.
Electronics installed under the fender, PCM, TAC module and fuse block. Fender installed with new lights.
02-04-2012, 11:50 AM | #49 |
Updates 47 1-Ton to S10 build
A couple of pics, got some new tires and reupholstered the factory seat.
wheels
04-03-2012, 09:42 PM | #50 |
Progress
I finally have some updates, making bed mounts and test fitting wheels with the bed. Couple pics and a shot of the 5.3...
