#26 |
Re: Another 1959 Apache build!
Yes, I cut just behind the steering box on one side and just lopped off the other with the old eyeball. They are now equal and square.
Last edited by Wheelie; 12-26-2010 at 10:42 PM. Reason: didn't make sense before! |
#27 |
Don't cut your arms under there - think how many miles of welds will be there to keep the frame and subframe hooked together!
#28 |
![]() Join Date: Nov 2010
i amk curious as to how this turns out, looking good so far.
#29 |
Thx guys, I am hoping to get back on it soon. I need to finish all the fab work so I can blow it apart for blasting and silver hammertone powder coating but we are slammed. Im tired of it looking like a rusty turd!
#30 |
Just a quick update on mine. I have the 383 stroker motor at the machine shop. I am using a resin mock block and trans to complete fab of the trans and engine mounts. Also I have laid out the location of the rebuilt ford 8.8 reared and 4 link. I am waiting till I can head to the metal yard to get box plate and some rec tubing for the 4 link bracket mounting. Things have been slow on the project but its starting to come together a bit more now.
#31 |
#32 |
Incase anyone is wondering where the truck will sit with control arms level (General rule of thumb to set ride height after removing springs for mock up.) here it is. Its about 5 inches to bottom of subframe and almost 6 to cab rockers.
#33 |
#34 |
Yep, I left the arms on mine too....Hey, Wheelie....you are pretty close to me. I live just south of Denton. If you need any help let me know and I will do my best to help if you need it.
Better to have it and not need it, then to need it and not have it. Fork In The Road....Cummins Build My Build Thread... Alternative A/C Mounting for LS Engines 4L60E Transmission Rebuild Info Trailing Arm How To |
#35 |
Thanks man! I appreciate that. Unfortunately I need more money/time at the moment but I may take you up on that! I have been through Corinth a time or two. My sister lives out in Sanger.
#36 |
Progress today, got the doors off and removed cab bolts.
![]() I was alone today, I got impatient and had to pull the cab off now. A dolly, 4 ft 2x4 and my new bad ass floor jack and some muscle I worked the cab off....ALONE. ![]() front view of impatience. ![]() Cab off! ![]() With the cab off its time for some heavy metal ![]() ![]() and for fun I wondered if I could draw my truck without looking....and I don't draw. ![]() |
#37 |
Looks to be a cool project...can't wait to see more!
#38 |
So things are still slow but I recently located my engine placement and welded up my motor mounts. Still need to box them but here ya go. I chose to place the engine higher then it would have normally sat in the subframe. The pics should give you an idea. Reason being that I personally think the engine sits way too low if using stock camaro mounts. Raising it looks better too, and I can go over bumps and lay frame without tearing off my oil pan.
#39 |
Looking good.
Kim |
#40 |
Not a bad idea, the engine compartments on these are SO deep you can raise the motor 6" or run outrageous intakes without touching the hood. I think you can even mount a blower and have the hood shut. I keep reminding me of that when I get wound up about how something down by the frame looks.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
#41 |
I had my control arms powdercoated satin black and rebuilt them with all new bushings and balljoints. What a pain in the ass!
My '59 Build Thread Last edited by Wheelie; 11-29-2011 at 10:41 PM. |
#42 |
A320 Pilot/USAF Retired
Powder coating is always cool!
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
#43 |
I have a 58' that i am eagerly awaiting to get tearing into, it is all original, but 75% of the fenders are trash. But it has the OE 235, with a 3 on the tree.. I am so glad to have found your thread, i have been wanting a visual on someone actually doing a sub frame swap on a 58-59.Thanks for the pics! keep em' coming!
#44 | |
My '59 Build Thread |
#45 |
#46 |
Navy Radioman Veteran
Any more progress?
I'm starting a similar project on my '57 stepper with a '78 Clip. Is 28.5 still the magic number or is that with the 2" considered for front to rear centering? Btw, I found this thread via jalopyjournal and am still finishing Lux's thread... Nice work also!! ![]()
1987 Chevrolet R10 Silverado BBC Build thread - SOLD 1986 GMC Sierra Classic - SOLD 1957 Chevy Step Side - At the Body Shop Daily Driver; 2005 Chevrolet Silverado 4x4 Z71 Stepside |
#47 |
whats the size of your wheels n tires. i like your ride height and stance. great job
#48 |
Looking good so far. Can't wait to see this one around town.
#49 | |
My '59 Build Thread Last edited by Wheelie; 05-13-2012 at 07:34 PM. |
#50 |
Thx! 205/75R15 on 15x7 (I think) rallys and 275/60R15 on 15x10 rallys in back.
