Old 12-19-2010, 11:38 PM   #26
Leedogg
Re: 1979 Bonanza/10.
so far so good man! nice to see them getting saved, vs going to the scrap heap.
Leedogg is offline   Reply With Quote
Old 12-20-2010, 01:24 AM   #27
1BadSS
NOT REALLY BANNED!
1BadSS's Avatar
Thanks, this one almost went to the scrapper and then turned into a honda.
1987 Mustang Coupe - 2.7 Stroker, 78mm turbo, Stainless header, 3" Exh, FMIC, 160lb/hr Injectors, MS3, twin walbro 255's, 34psi. Eating V8's daily.
04 Pontiac GTO
04 Ford Mustang GT
68 C20 LWB stripper truck
73 K5 Cheyenne
76 C20 Sierra Crew SRW
88 K20 Suburban
I'm not hammering on metal just to hammer, i'm creating a piece of art.
1BadSS is offline   Reply With Quote
Old 12-26-2010, 11:16 PM   #28
1BadSS
NOT REALLY BANNED!
1BadSS's Avatar
Picked up a $50 "Test fitted once and I found all new GM metal for my truck door"
Also picked up new full size inner rockers w/ floor drop offs, battery mount and tray, gauge lens for my tach cluster and a floor support.
04 Pontiac GTO
04 Ford Mustang GT
73 K5 Cheyenne
88 K20 Suburban
Old 12-26-2010, 11:36 PM   #29
S10Fan
Old Heap Driver
There's nothing like fresh metal!
You mentioned the Harbor Freight welder.......Another good handy tool from Harbor Freight is this spot weld cutter......Item number 95343. The cutter works better than some I've bought for 3 times the price.
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'30 Model A Pickup, suicide front end, 350, 350, traditional style hot rod.
S10Fan is offline   Reply With Quote
Old 12-26-2010, 11:59 PM   #30
1BadSS
NOT REALLY BANNED!
1BadSS's Avatar
I picked up two of them. As long as you keep them covered in panther piss. They'll last forever. I used the first one to cut both cab corners and rockers off of the truck.
04 Pontiac GTO
04 Ford Mustang GT
73 K5 Cheyenne
88 K20 Suburban
Old 01-09-2011, 03:32 AM   #31
1BadSS
NOT REALLY BANNED!
1BadSS's Avatar
Just got done with the tach cluster.
04 Pontiac GTO
04 Ford Mustang GT
73 K5 Cheyenne
88 K20 Suburban
Old 01-09-2011, 04:16 AM   #32
Pop's C-10
Pop's C-10's Avatar
sweet
Pop's C-10 is offline   Reply With Quote
Old 01-09-2011, 08:55 AM   #33
big10ratrod77
big10ratrod77's Avatar
man i love your build thread, im not much of a guy for lowered trucks either becouse they loose there practicality and most of them trucks probly dont get much street use or off road use for sure. i wanna buy a round eye 4x4 some day to fix up but i gotta finish what ive started if ya know what i mean. are you gonna lift the truck eny?
77 chevy BIG 10 350/sm465/12bolt w 3.73 bout 240 horse power NO power steerin
79 chevy 1/2 ton 250/three on the tree/3.08s soon to get built 250/floor shift conversion/3.08s
81 mercedes 300d 25 MPG
77 chevy BIG DOOLEY 454/sm-465/14 bolt 4.10s "fully loaded"
73 plymouth duster 225 slant six/230 3 speed/8 1/4 trying to acheve 300 horse six http://www.cardomain.com/ride/3135091
'77 chevy trucks. built to stay tough.
life is short build a hot rod
big10ratrod77 is offline   Reply With Quote
Old 01-09-2011, 01:09 PM   #34
Chlsnk
Chlsnk's Avatar
Looks like it progressing well. I think I have seen this truck around town before.
***My 84 short bed build up*****
http://67-72chevytrucks.com/vboard/s...68#post3481968
Chlsnk is offline   Reply With Quote
Old 01-09-2011, 01:26 PM   #35
1BadSS
NOT REALLY BANNED!
1BadSS's Avatar
I'm going to windup going with a 4" lift and 33's. I don't want to go too high on the truck. But with 4inches, I should be able to handle most of anything out here.
04 Pontiac GTO
04 Ford Mustang GT
73 K5 Cheyenne
88 K20 Suburban
Old 01-09-2011, 08:05 PM   #36
1BadSS
NOT REALLY BANNED!
1BadSS's Avatar
Went ahead and took a picture of the passenger side of the cab. Still need to cut the floor pan down a little bit and then fit the new floor drop offs.
04 Pontiac GTO
04 Ford Mustang GT
73 K5 Cheyenne
88 K20 Suburban
Old 01-17-2011, 02:31 AM   #37
1BadSS
NOT REALLY BANNED!
1BadSS's Avatar
Got the new brake lines installed on the rear of the truck, new wheel cylinders and completely rebuilt rear brakes. By the way, the rear axle lines that LMC sells for 1/2 ton 2wd trucks, will also fit your 1/2 ton 4wd truck, on the axle. I'd imagine the front to rear frame lines would fit as well. I'm not too sure of that though.
Had a chance to throw a spare door on the passengers side to check final fitment and it looks good. The door is a little wavy though, but the rocker is good for final welding.
04 Pontiac GTO
04 Ford Mustang GT
73 K5 Cheyenne
88 K20 Suburban
Old 01-22-2011, 10:40 PM   #38
1BadSS
NOT REALLY BANNED!
1BadSS's Avatar
The above is why the taiwanese need to stick to making lead based baby toys. They're much better at that. In the picture it shows the inconsistency of the press process when the door was made. The bottom of the skin isn't straight and true but arches up and down. The rocker is perfectly straight.
The trucks starting to look like a truck once again. The fenders still need to be shimmed a bit.
Threw the NOS emblem on the side for a shot so I can convert it into my avatar here.
04 Pontiac GTO
04 Ford Mustang GT
73 K5 Cheyenne
88 K20 Suburban
Old 01-22-2011, 11:39 PM   #39
Shaun1162
Shaun1162's Avatar
Looking good! Like others have said, always good to see another one saved!
Shaun1162 is offline   Reply With Quote
Old 01-23-2011, 12:39 AM   #40
Zoomad75
K5Camper
Zoomad75's Avatar
Nice build. Keep up the good work.
Rob Z.
1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP
1991 K5 8.1L/NV4500/241/D44/14b FWC Camper
Zoomad75 is offline   Reply With Quote
Old 01-28-2011, 03:40 PM   #41
SS Delux
SS Delux's Avatar
Great job on the truck, keep it up and you will have an amazing ride. I wish that I had bought new rockers instead of fabricating them, they would probably be a bit better.
SS Delux is offline   Reply With Quote
Old 01-30-2011, 09:53 PM   #42
1BadSS
NOT REALLY BANNED!
1BadSS's Avatar
Installed my new-to-me original 74 dash pad in the truck, also threw one of my tach clusters in the truck. Waiting for the new gauge bezel to come in. Also cruised over to LMC to pick up a new full exhaust for the truck and a new passenger side door.
04 Pontiac GTO
04 Ford Mustang GT
73 K5 Cheyenne
88 K20 Suburban
Old 02-02-2011, 09:05 PM   #43
85chevy4x4
85chevy4x4's Avatar
This is an awesome build!!! i dont really see many 4x4s in the build section keep the pics commin
85 custom deluxe 4x4 4 speed 350sb
85chevy4x4 is offline   Reply With Quote
Old 03-05-2011, 11:34 PM   #44
1BadSS
NOT REALLY BANNED!
1BadSS's Avatar
Well, the old girl is going on to greener pastures. By way of scrap metal. Pulled most of the goodies off of it this weekend. It's getting traded for a 76 Short wide on Monday.
04 Pontiac GTO
04 Ford Mustang GT
73 K5 Cheyenne
88 K20 Suburban
