Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 10-23-2010, 10:59 AM   #26
ripdog28
ripdog28's Avatar
Re: New to BBC
You do not need Alum heads AFR/DART/Brodix to make 500-600-700 HP at the crank. I have seen plenty 700 hp 496 with worked over stock Iron heads. Just look at the link i posted earlier. My Iron heads have been used on 680 hp BBC with no work done to them and pump gas. Check out some builds by David Vizard.
69 c-10 BBC
462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build.
ripdog28 is offline   Reply With Quote
Old 10-24-2010, 01:44 AM   #27
1971ls1longbed
1971ls1longbed's Avatar
Re: New to BBC
so who makes a good set of cast iron heads
1971 Custom 10 LWB. 461 BBC and built 700r4 to be transplanted
1997 C3500 DRW Ext cab. 454, 4L80E daily driver
1971ls1longbed is offline   Reply With Quote
Old 10-24-2010, 08:11 AM   #28
stich626
Re: New to BBC
dart
stich626 is offline   Reply With Quote
Old 10-24-2010, 06:11 PM   #29
1971ls1longbed
Re: New to BBC
hey i was wondering if 500 for a running 427 with big oval heads is a good deal or should i hold out for a 454
Old 10-24-2010, 06:32 PM   #30
1971ls1longbed
Re: New to BBC
its out of a truck
Old 10-24-2010, 08:04 PM   #31
ripdog28
ripdog28's Avatar
Re: New to BBC
Out of what kind of a truck? Find out if it is a tall deck block. IMO it would be worth it.
69 c-10 BBC
Old 10-24-2010, 08:42 PM   #32
djracer
djracer's Avatar
Re: New to BBC
I would not buy it if its a tall deck truck motor. Get the casting numbers and you can tell for sure.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 10-24-2010, 11:50 PM   #33
1971ls1longbed
Re: New to BBC
its out of an early 70s stake body truck
Old 10-25-2010, 08:10 AM   #34
djracer
djracer's Avatar
Re: New to BBC
Its a tall deck I would stay away. A454 shouldn't be that hard to come by.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 10-25-2010, 04:21 PM   #35
1971ls1longbed
Re: New to BBC
U were right i checked with a speed and machine shop in jersey and he has a 454 shortblock he want $400 for it im going saturday to get it
Old 10-25-2010, 04:27 PM   #36
C low
C low's Avatar
Re: New to BBC
If it has not been done pay the guy to magnaflux the block its good insurance
C low is offline   Reply With Quote
Old 10-25-2010, 07:12 PM   #37
1971ls1longbed
Re: New to BBC
it was magnafluxed apperently it was dropped off and checked and it has just sat for the last 3 years
Old 10-26-2010, 12:29 PM   #38
shawnt
shawnt's Avatar
Re: New to BBC
stock 454 shortblock or ????
I got a complete 454 for $250...
Shawn
Shawn
85 SWB
7.39 @ 93
Best so far with 0 tuning
Lesson in life: Never fry bacon naked!
shawnt is offline   Reply With Quote
Old 10-26-2010, 03:11 PM   #39
1971ls1longbed
Re: New to BBC
Texas is a long way from jersey if u were closer i would be all over it
Old 10-27-2010, 01:11 AM   #40
1971ls1longbed
Re: New to BBC
does anyone have a good set of heads for sale
Old 10-27-2010, 07:11 AM   #41
stich626
Re: New to BBC
Originally Posted by gearys 5600 View Post
$1100 bare ?? I paid $1800 for the brodix 2xtra cnc,d complete, ready to bolt on, Not having to spend $$ for port work is worth quite a bit.
no loaded..
a shop out of r.i. had them up at a super chevy show in N.H.
new in box, built for a customer that bolted..
they wanted 1600oo but I have no need for the springs,etc
so I said i'll take them for 1100.oo and you can keep the springs/locks/retainers/etc
they where like, na. but at the end of the last day, i stopped by again, and they gave my the heads and said keep the valve parts/springs/etc.
Old 10-27-2010, 09:22 PM   #42
getbent
Re: New to BBC
dart iron eagle 308,s jmo should produce plenty
getbent is offline   Reply With Quote
Old 10-28-2010, 12:16 AM   #43
1971ls1longbed
Re: New to BBC
ok ill look into iron eagles any other options
Old 10-28-2010, 02:23 AM   #44
ripdog28
ripdog28's Avatar
Re: New to BBC
I have not touched my Dart 308cc and i can not get the 30in tall BFG Drag radials to hook at anything under 50MPH. For the $$ im glad i got them. David Vizzard uses these on a lot of builds with crazy results. You also need to figure the brackets and other stuff for a BBC if you dont have it in your budget. Gets expensive fast. But is well worth it.
69 c-10 BBC
Old 10-28-2010, 10:31 AM   #45
1971ls1longbed
Re: New to BBC
Well if you're using them then they will definitely work for my build. As far as a cam goes i was looking to do a hyd roller setup any recommendations on duration and lift
Old 10-28-2010, 10:58 AM   #46
ripdog28
ripdog28's Avatar
Re: New to BBC
My cam is small but nasty with this set up. I have been told by a very reputable builder (Wolfsplace, AKA Mike Lewis) these heads like to go with a mid 240 int and a 250+exh. So 10+ separation. Lift depends on your Springs and the pistons you end up with. All honesty, if you want serious power call up Vortech pro. Best bang for the buck unless you want to build it. IMO, i would have went with him if i found him before building mine. I dont regret getting mine but he would have saved me some $$. Also figure a roller will set you back $1000 Springs, lifters, cam.
69 c-10 BBC
Old 10-28-2010, 03:23 PM   #47
1971ls1longbed
Re: New to BBC
I am going to assemble it myself
Old 10-28-2010, 05:48 PM   #48
ripdog28
ripdog28's Avatar
Re: New to BBC
I have about $4000 into my engine but had some killer deals on the parts. I can not complain about it one bit.
69 c-10 BBC
Old 10-28-2010, 06:10 PM   #49
1971ls1longbed
Re: New to BBC
im doing alot of careful shopping i do want to keep my costs down but im sure i can build an awesome rat with the help u have given me
Old 10-28-2010, 10:57 PM   #50
69trk
69trk's Avatar
Re: New to BBC
I have 3800 in mine. Came with dyno sheets and everything, carb to pan. I also have rectangle 088 gen v heads that makes good power.
http://67-72chevytrucks.com/vboard/s...d.php?t=494388
431 big block times, changed to a 6.0 ls with turbo
1.58- 60'
7.18- 1/8th mile@95.18
11.37- 1/4 @115.81
69trk is offline   Reply With Quote
