Old 04-06-2011, 09:28 PM   #26
76kcfdeng
Re: "Like I need another hole in my head" 70 chevy short wide project
It a has been a while since I posted, not that anybody is paying attention.
Anyhow I got the suspension back on so the frame is rolling. I got some of the frame bracing welded up. I still have to add bracing behind the trailing arm crossmember. I also have to install the rear sway bar. After all that I will have to take most of it apart to replace bolts with and paint the frame and pieces. I had to move the ECE panhard mount on the trailing arm lower because it would hit the frame at full bumpstop with the notch. I made custom front sway brackets for the front.
Any comments or questions welcome.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
70 Chevy SWB Fleet Project.
06 Lancer Evolution MR SE, stupid fast!
03 Ford f-250 crew cab, 6spd, diesel
56 ford f100 project
My build thread.
http://67-72chevytrucks.com/vboard/s...d.php?t=426739
76kcfdeng is offline   Reply With Quote
Old 04-06-2011, 10:48 PM   #27
yunkyarddog
yunkyarddog's Avatar
Name:  my notch.jpg
for sure doing this to my truck
Im stright up ESL student........ fixin my truck a trip to the yunkyard at the time
94 s10 4x4 4.3/5speed (dd)
68 lwb GMC 350/4speed
52 5 window GMC I6/4speed 12v (8lugs and long bed)
53 bel air 235 I6/powerglide
yunkyarddog is offline   Reply With Quote
Old 04-06-2011, 11:06 PM   #28
76kcfdeng
Originally Posted by yunkyarddog View Post
Attachment 726494
It was not really necessary for the 6" drop but i don't like bottoming out and I may go 7". Just make sure to brace it well as it does weaken the frame quite a lot.
My build thread.
Old 04-25-2011, 04:45 PM   #29
76kcfdeng
Finally had some time to work on the frame bracing. I think I am done with bracing, may add a couple small braces. Now I have to clean it up and paint. I also started mocking up the fuel tank out of a 69 Camaro. I am trying to keep it as tight to the frame and as far forward as possible and still be able to fill it.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
My build thread.
Old 04-25-2011, 05:19 PM   #30
67cheby
67cheby
67cheby's Avatar
Looking good
67cheby is offline   Reply With Quote
Old 04-25-2011, 07:32 PM   #31
76kcfdeng
Thanks Cheby, not quite to level of your build which is very nice.
My build thread.
Old 04-26-2011, 10:11 AM   #32
67cheby
67cheby
67cheby's Avatar
the "LEVEL" of mine is forever unfinished ...dont aspire to be me !! get yours done !! LOL
Old 04-26-2011, 02:03 PM   #33
76kcfdeng
I plan to get mine done, but they are never "done" really. I plan to get the firewall done and put it together. Work on the bodywork a bit at a time while its drivable. Plans do change though so who knows.
My build thread.
Old 04-26-2011, 02:06 PM   #34
67cheby
67cheby
67cheby's Avatar
Keeping it driveable is a great plan....i wish i would have went that route , havent driven mine in 8 years...hopefully i am on the downhill side now, 1 more year !!
Old 10-26-2011, 12:59 PM   #35
69gmcc10
69gmcc10's Avatar
did you make the swaybar mounts like that to push them forward & match the lower a arms? is there much binding in the coils, shock mounts or steering with the relocation of the lower arm? this seems like an easy solution to get more caster. I like it! give us an update.
69gmcc10 is offline   Reply With Quote
Old 10-26-2011, 06:48 PM   #36
76kcfdeng
I made them that way due to lowering the truck, similar to what ECE sells. They may be slightly forward, just put them where they fit best. The coils are slightly angled but other than that no issues, granted I have not driven it yet but cycling the suspension and turning the tires causes no issues. Need to get back at it soon.
My build thread.
Old 11-01-2011, 03:34 PM   #37
69gmcc10
69gmcc10's Avatar
where did you get teh bushings for your rear sway bar? ECE?
Old 11-04-2011, 09:40 AM   #38
76kcfdeng
They are from energy suspension, not sure when or where I got them. They happen to be the right size and they were in my pile of spare parts.
My build thread.
Old 11-16-2011, 03:25 PM   #39
69gmcc10
69gmcc10's Avatar
Have you made any progress on this build lately?
Old 11-18-2011, 01:22 PM   #40
76kcfdeng
I have not made any progress recently, had a couple of other things to finish. I needed to make some room in the shop. I plan to get back to it soon.
My build thread.
Old 11-20-2011, 08:39 PM   #41
RCbowtie69
RCbowtie69's Avatar
Just catching up on your build & it's looking great.Keep the pictures coming & the progress going forwards.Keep on truckin'
My Truck: 2.5 drop front, 4 & 5/8 in rear, 350cubic in. been bored .60 over, 700r4 (soon), 3 speed (on tree for now).rims & tires size,15x8 ralleys 5 on 5,P275/60R15.
Members I have met: Pickupman, 1972 Super Cheyenne, Stepside,Chis Mc Bride. tsnow67,joel.e,
RCbowtie69 is offline   Reply With Quote
Old 11-22-2011, 12:07 PM   #42
76kcfdeng
Thanks RCbowtie69, Now that summer is over it is time to get back at it. Had boat projects and watersports keeping me busy.
My build thread.
Old 01-09-2013, 12:38 AM   #43
c10monkey
c10monkey's Avatar
I can't wait to see your grill installed!
Great idea from the mod thread...
1971 Chevrolet C10 Inflation Fighter
1994 C3500 Crew Cab Dually 454
c10monkey is offline   Reply With Quote
Old 01-09-2013, 09:24 AM   #44
Low Elco
I like the bracing, and the rear Swaybar plan. The links can be found at O'reilly's in the performance section.
Low Elco is offline   Reply With Quote
Old 05-11-2014, 08:18 PM   #45
76kcfdeng
I have not posted or worked on the truck in a LONG time. Got back on it this last week. Gas tank mounted, started filling holes on the firewall. Still need to paint the frame, will do that soon. Pictures in a couple of days. Since I lasted posted, finished a divorce, got remarried, redecorated the house, restored a vintage travel trailer and finished a ton of landscaping.
My build thread.
Old 05-31-2014, 03:08 PM   #46
76kcfdeng
Some pictures of recent progress.
My build thread.
Old 12-18-2020, 06:08 PM   #47
Circular Pastry
Most threads don't start with a ton of followers, they come as you put in the work. …so, let's see that van grille mocked up!
Circular Pastry is offline   Reply With Quote
