10-26-2010, 07:27 PM | #26 |
Re: sound deadener
Hy tech coating with glass sphears first layer under color, Top bottom and everything else!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
10-26-2010, 07:28 PM | #27 |
Re: sound deadener
^^^That is what we have always used at the shop and no one has ever came back and said that the sound levels were to high or it was to hot inside the vehicle.
James
Ain't no way in the world I'm going out that front door. 69 SWB Fleetside 327/5spd 76 blazer 383/700R4 95 2Dr Tahoe 5.7 4x4 LT |
10-26-2010, 07:43 PM | #28 |
Re: sound deadener
I used lizard skin, and dynamat on project codfish....... sure make a huge difference
10-26-2010, 08:08 PM | #29 |
Re: sound deadener
google home made lizard skin ... you'll be amazed at how cheap you can make your own.
10-26-2010, 10:13 PM | #30 | |
Re: sound deadener
The kid Build threads: 51 Jimmy http://67-72chevytrucks.com/vboard/s...d.php?t=154951 http://67-72chevytrucks.com/vboard/s...d.php?t=219902 http://www.classictrucks.com/feature...uck/index.html 68 C10 http://67-72chevytrucks.com/vboard/s...ad.php?t=50348 |
10-26-2010, 10:41 PM | #31 |
Re: sound deadener
Do you have any pictures of what it looks like?
1972 Chevy C10 SWB 1999 GMC Sonoma Mini 2008 Yamaha R1 2007 Harley Nightster |
10-26-2010, 11:13 PM | #32 |
Re: sound deadener
some pictures in link below, minus the Damplifer Pro, didn't take pics of that
http://67-72chevytrucks.com/vboard/s...=154951&page=3
10-26-2010, 11:17 PM | #33 |
Re: sound deadener
Curious cause i'm not a body man, if i decide to use the stuff and down the road a rust problem pops up because it was hidden inside a rocker or cab support, how hard it it to remove the stuff you use? can it be media blasted off? Thanks,
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
10-26-2010, 11:42 PM | #34 |
Re: sound deadener
I'm curious as to what some of you are doing with the exposed areas of the sound deadener? Like up front on the firewall where the carpet ends. Is the stuff paintable or do you make sure you have something to cover it all up?
1970 Chevy CST/10 1970 Chevy CST/10 1972 Chevy C/10 1972 Chevy Suburban K/10 2019 Silverado 2500 Duramax Kevin |
10-27-2010, 12:15 AM | #35 |
Re: sound deadener
I have experience with just about every deadener out there. My advice is stay away from anything tar based. The only two that in my opinion are even worth buying is FatMat's MegaMat or Second Skin Damplifier. They're both Butyl and work 10x better than anything else out there. The tar based stuff easily peels off and in some cases the smell of the tar lingers in the car forever. If you're going to deaden, do it right. FatMat MegaMat is the cheaper of the two (100 sq. ft. for $240) and works very well. I have about 130 sq. ft. in my cab along with a layer of Second Skin's Luxury Liner Pro. It's about as quiet as a new luxury car.
Butyl based is the only way to go. Edit- as for the spray stuff I have never used any but really want to. Everyone I know that has used it says it's excellent stuff.
'70 K10-- 4" lift on 35"s-- For Sale http://www.ksl.com/index.php?sid=733...iew&ad=4578305 Last edited by Nova70; 10-27-2010 at 12:18 AM. |
10-27-2010, 12:56 AM | #36 | |
Re: sound deadener
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD Click here to support the board Philippians 4: 6-7 |
10-27-2010, 01:10 AM | #37 |
Re: sound deadener
What's the best for Heat AND Sound insulation?
When the air temp is 115 out here the asphalt is usually 150... Hoping to keep the truck semi-coool. |
10-27-2010, 04:54 AM | #38 |
Re: sound deadener
That would require a two step process. The sound deadener does just what it says, reduces sound. For some insulation you would want to go with some second heat wave or a similar product.
Heat Wave Pro
'70 K10-- 4" lift on 35"s-- For Sale http://www.ksl.com/index.php?sid=733...iew&ad=4578305 |
10-28-2010, 09:28 PM | #39 |
Re: sound deadener
Does anybody have any experience with B-quiet. I was going to try it..
Trevor
1968 short box stepside. 2007 5.3L 4L60, tuned w/EFI Live 2005 Silverado bucket seats. Dominator 2600's all around. Porterbuilt tubular control arms. Magnaflow 3" dual exhaust. |
10-28-2010, 10:18 PM | #40 |
Re: sound deadener
I would still like to know if any of the products listed are easy to remove if you end up having a hidden rust issue rear its ugly head? by sander or maybe heat gun?
10-29-2010, 01:24 AM | #41 |
Re: sound deadener
You can remove it but it will not be re-usable. You can peel it off while applying heat.
B-Quiet is tar based and I would not recommend it.
10-29-2010, 01:40 AM | #42 |
Re: sound deadener
I did my whole interior and inside my doors and door panels with butyl window sealer from Home Depot! 50 ft roll for $17. Used two rolls. It's half the thickness of Dynamat but like 1/10th the cost. I figured I would just double it up if I needed to. but after putting just one layer on I'm happy.
10-29-2010, 10:23 AM | #43 |
Re: sound deadener
Anybody know what the square footage is to do the inside of the cab (floor/back cab, etc)
10-29-2010, 10:28 AM | #44 | |
Re: sound deadener
I bought 100 ft/sq of FatMat (two 50 ft/sq rolls) and have covered the areas described above and have little less than one full roll left to do the doors. hope this helps. |
10-29-2010, 10:29 AM | #45 | |
Re: sound deadener
10-29-2010, 11:37 AM | #46 | |
Re: sound deadener
If something like that would work I'd have no problem using two layers under foot or on the inside of the firewall...as long as it doesn't feel "squishy" under foot, smell, move after installtion, etc. Did all you guys sandblast, wire wheel, or at least sand (and maybe paint?) before putting these products on? |
10-29-2010, 06:28 PM | #47 | |
dazed and confused
Re: sound deadener
was this what you used?
members met: redbaron69, billsbowtie,nc67 |
10-29-2010, 07:28 PM | #48 |
Re: sound deadener
Thanks Nova70!
12-10-2010, 09:04 AM | #49 | ||
Re: sound deadener
Protecto Wrap BT25XL Window & Door Sealing Tape http://www.protectowrap.com/pdf/msds/bt25xl-msds.pdf It is an asphalt based product. APPEARANCE AND ODOR: Opaque black, tacky solid with no odor. MELTING POINT: 220°F (104°C) (Softening Point) EMERGENCY OVERVIEW This product is a black, opaque, tacky solid with no odor. Product is not flammable but will burn under fire conditions. May cause mild eye and skin irritation. Contact with heated product may cause thermal burns. Inhalation of vapors from heated product may cause irritation of the nose, throat and respiratory system. This product contains crystalline silica in the form of quartz. Prolonged overexposure to respirable crystalline silica may cause lung disease (silicosis) and increase the risk of lung cancer. Last edited by lakeroadster; 12-10-2010 at 02:48 PM. |
12-10-2010, 11:43 AM | #50 |
Re: sound deadener
Protecto window and door wrap is a butyl rubber like the other sound deadeners. They also make a .60 mil thick, aluminum backed product called Audio Wrap. Also butyl for $156 for a 15 inch by 50ft roll. They claim better test results than the leading competitors. www.audiowrap.com
