#26 |
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
Re: One Piece Window Conversion Kit for '67-'72 GM Trucks *
Free shipping in the Continental US For the Month of August!
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
#27 |
![]() Join Date: Apr 2007
Still selling these?? If so can you pm me with price and shipping to 70633? thanx .....................jim
Build thread at http://67-72chevytrucks.com/vboard/s...d.php?t=475791 |
#28 |
Yes, I will be selling them as long as OPP produces them.
BTW, if you put the item in the basket it will tell you the shipping costs prior to purchase...
#29 |
do you offer a [ower window kit?
#30 |
Not sure what you are asking.
Posted via Mobile Device |
#31 |
Think he's asking about power window kit...jim
#32 |
Yes, does this kit work with power conversion ? Do you offer one?
#33 |
Yes it will work with power window kits, It was designed around Electric-Life kits, the link to them is in the catalog with the window conversion, or they are here:
http://store.73-87chevytrucks.com/me...tegory_Code=6T
#34 |
any thing for burban rear door that would be great
#35 |
Its a Truck Thing......
There is a company in NC that does the rear doors for the 67-72 burbs. I can get the name for you if you like. I am going to order a set for my burb. To clarify, they do the third door and the window behind the driver....
Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 71 C20 Longhorn/Ole Yellor 69 C30 Former Motor Home, Flat Bed time Last edited by 71meangreenc10; 02-08-2012 at 10:37 PM. |
#36 |
![]() Join Date: Jan 2009
[QUOTE=Captkaos;4346790] This is one of thee best designed kits on the market.
With that said, And I am not trying to through another company under the bus, but I just want to make sure before I go ahead and spend all the time to do this. What makes your product better, or different then the others? So all together with Power window kit. This would run about? And what do you get that cost $50 more for the Blazer Kit? Thanks in advance, just don't want to make a mistake.
Build Thread, |
#37 | |
I'm sure all your hard effort will not go unnoticed. And save a lot of us a lot of time and money.
Build Thread, |
#38 |
One thing about this kit --he has 8 you-tube vids showing installation-so I am going to try this kit after watching the vids and "knowing up front" I can handle the process--always some tweaking with a full glass like this but he addresses those concerns...........jim
#39 |
![]() Join Date: May 2007
There are a few things I did not like about the OPP kit some have been addressed from what I understand...... You will have to grind the door latch and the window will still "rub" the little piece of felt is a joke and only will last a couple roll ups, the window will only go down to top of the scrubber, ( I like to rest my arm there) but can easily be fixed by cutting the stop in the door and moving it down. The window at the time depended on the scrubber to keep it in the center of the door (IMHO) this will put strain on electric window motors over time, I understand they have made the roller adjustable to correct this issue, Door checks are simply too flimsy do not open the door on a uneven surface they will bend and your door will get creased (even if you are easy). We also had to clearence the scubbers at top of the door for the window Track it would hit and spring up the scrubber, and i didnt like having to glue in the scrubbers (I understand they clip in the factory places now).I really like the look of this kit but the function for everyday and was not quite there at the time. I did give some good feed back to Ben at OPP and some changes were made I can not speak about the current kit, Maybe someone will chime in that has recently installed one
#40 |
Rob those last couple vids show some changes and tweaks--thanx for the "on the ground" input....I too love the look and realize with a window and door that "square" it's a challenge......In your opinion was there a fix for the door check problem??.........thanx...jim
#41 |
It needs some re inforcement at the end where all of the pressure from the hinge is.
#42 |
![]() Join Date: Dec 2004
looks way better then the brothers kit that i had on my last truck,,i hated the glass wasnt attached to the track
21 2500hd duramax 58 apache HILLJOB GRAPHIX--for all your graphic needs My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=542497 LS ENGINE SWAP INFORMATION THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=377348 4l60 to an NP205 http://67-72chevytrucks.com/vboard/s...43#post3697343 |
#43 |
![]() Join Date: Nov 2002
Any chance for a group buy to help lower the price a little?
Thanks. |
