View Poll Results: Let's finish this once and for all!!! Your favorite carb: Holley? Edelbrock? Q-Jet? | |||
Holley | 162 | 33.96% | |
Edelbrock | 131 | 27.46% | |
Quadrajet | 184 | 38.57% | |
Voters: 477. You may not vote on this poll |
12-16-2010, 11:36 PM | #26 |
Re: POLL: Holley? Q-jet? or Edelbrock? Let's finish this once and for all!!!!
Here's my 2 cents in order of personal preference.
1 Edelbrock / Carter AFB 2 Quadrajet 3 Holley It's not that I don't like Holley, just don't like draining the fuel bowl to change a jet or have a bowl gasket leak. Edelbrocks are easy to tune and easy to work on. I have one on my daily driver and it starts easily and quickly everytime, even in cold weather. Throttle response is pretty good as well. Therotically, a Quadrajet is similar in design to the Edelbrock / AFB in that it uses metering rods, a secondary air valve and you just pop the top for any tuning. It's been a while since I've ran one, aren't parts getting harder to find? I understand Edelbrock is discontinuning their line of Qjets. It all boils down to personal preference I guess, some people like Dodge, some prefer Ford some like Chevy, but in the big picture, they all do the same thing. Last edited by silverstreak; 12-16-2010 at 11:38 PM. |
12-16-2010, 11:41 PM | #27 |
Quadrajet!
I'm not a pessimist, I'm just optimistic that bad things are going to happen. 1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets! 1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241. |
12-17-2010, 12:40 AM | #28 |
My Carbon Footprint
Funny.....I didn't expect Holley to be a strong second. I figured Eds or the jets to be first and Holley to be dead last.
....but just like the last elections.......long ways to go!!! |
12-17-2010, 01:24 AM | #29 |
What?
Q-jet is my favorite.
Chris 1968 K20 Suburban 1972 K10 LWB PU |
12-17-2010, 01:45 AM | #30 |
My elect. Choke holley never misses a beat best start up carb I've ever had. But my favorite carb is the Qjet. In my experience most people compare a 30 year old 200k mile q jet to a new or near new aftermarket carb. The number one problem with the quad is a warped air horn or body from someones wrenching. These carbs ran for decades intill an owner over torqued it. Edelbrock dropped their q jet because it was twice the cost of their standard carbohydrates. I wish I would have ponied up the bucks now.
Posted via Mobile Device |
12-17-2010, 02:32 AM | #31 |
Holley 850 4150 for me.
12-17-2010, 02:47 AM | #32 |
Cops, ha, catch me if you can!
1406 is my vote
72 C-10 Stepper 350/TH350 3.73 in the back Edelbrock intake and Carb Hooker Comp Headers 275/60R15 on Rallies |
12-17-2010, 05:08 AM | #33 |
i'll buy another crockobrock when i want to chance gas leaking all over a hot engine again. my holley runs tits right out of the box.
12-17-2010, 05:31 AM | #34 |
Redefining LowBudget
wow I would have to fight over a couple of beers with yea ^^^^
I voted edlbrock because every one I took out of the box ran perfect with min tuning but the truth is I have run Alot of Q jets until the throttle shafts have worn out..yea i know theres a kit but at that point I bolt on the EB... I personally find the Hollies a PIA seems they are always needing to be tuned...I mean its 14* now and in the summer its 100* and alot of parts to get in sink and the if you get a back fire you pop the vavles so I try to avoid them
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. Mikes Sandwich Fair Run OCT 8th 2011
12-17-2010, 07:36 AM | #35 |
I depends on the use.You can't beat the original Quadrajets on a stock manifold.The spread bores give a perfect balance of power and economy.There is no one specific carb for a modified motor.Q-jets on a stock manifold still do the trick on mild builds.It's when I change the manifold that I go to other carbs.I only change the manifold on a total build,not add-on.When a build will benefit from a dual plain,air gap,or dual feed I go to Holleys.My latest is a 670 cfm Street Avenger for a hot 327.One carb I have learned to stay away from is the Holley 600 cfms.
12-17-2010, 08:14 AM | #36 |
I have a Holley, custom built by Pro Systems. The best carb I have ever had!
12-17-2010, 09:52 AM | #37 |
12-17-2010, 09:57 AM | #38 |
Edelbrock was easy to install, I don't have any experience with the other two though so I won't vote...
2001 silverado stolen by family 1983 short n wide custom deluxe SOLD 1985 silverado longbed 305 engine 700r4 OH NO! NOT ANOTHER LEARNING EXPERIENCE!!! "Just because you can do it, doesn't mean that you should" |
12-17-2010, 10:01 AM | #39 |
I've got a lot more experience with Carter YF's, but I'm pretty sure the Rochester M-Jet has a higher flow. Wait where's my voting selection?
On the only V8 I have I run a Holley. They require more attention over time than both the Q-jet or Eddy, but are easier to work on at least in my experience. Well easier than an Edelbrock anyway. All three are good choices. They all have their goods and bads. Now who's going to add Carter YF and Rochester M-Jets to the voting choices? |
12-17-2010, 10:10 AM | #40 |
Easiest I have dealt with is a Carter AFB. If the vehicle sits very long with a Holley seems to me they have problems, dried up metering block gaskets and such.
70 Chevy SWB Fleet Project. 06 Lancer Evolution MR SE, stupid fast! 03 Ford f-250 crew cab, 6spd, diesel 56 ford f100 project My build thread. http://67-72chevytrucks.com/vboard/s...d.php?t=426739 |
12-17-2010, 11:46 AM | #41 |
It'll Buff Out!
Q-jet
I've had all 3 and it never lets me down. I found a local guy who can build them great with just a bit of info on what you have put into your truck. They are IMO the trickiest to work on, but the best.
"Instructions are just another mans opinion" Become a Supporting Member http://67-72chevytrucks.com/vboard/payments.php Man Card Rules http://67-72chevytrucks.com/vboard/s...d.php?t=634550 72 Chevy Cheyenne Super 400 LWB |
12-17-2010, 12:28 PM | #42 |
I dun gradjiated collij!!!
1405 on the shelf waitin' for Bessie, 1406 on Screamin' and an 1806 AVS on 'Boo. So yeah I guess I lean more towards Edelbrock...
Built NOT Bought. Viper Red 1971 LWB C10 355 Vortec W/700R4 4/5 drop AKA Screamin' You are missed!
2006 F150 XLT 5.4L Triton Rollin' on 22s the "F1" 67 C20 PS/AC/327/TH400 we call 'er "Bessie" 67 Malibu PS/ZR1-LS1 Brakes/350 Vortec/700R4 2/2 drop on 18" 338s - Tracy's "Boo" Boosted '67 Cougar EFI 5.0 HO roller motor/T5/8.8 Tracloc/ 4 wheel disks - "Project Panther" 79 Honda Z50 - stretched, cafe'd and hotrodded 125CC Lifan/5spd FEAR THE MONKEY! Last edited by screamin_c10; 12-17-2010 at 12:29 PM. |
12-17-2010, 12:37 PM | #43 |
I've owned all 3 in the past. The only thing I will install on a motor of mine now is a Holley. I bought a Pro Systems carb (Holley) for my race motor last year and gotta say best carb I have ever owned too.
12-17-2010, 01:36 PM | #44 |
q jet best as long as ur not realy radical then go to the holly spray it down lk agarden hose !!!
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
12-17-2010, 01:55 PM | #45 |
For modified engines Holley. Stock, Q-Jet all the way.
12-17-2010, 03:49 PM | #46 |
This was the third 1406 i've used and no complants yet.
NOW, that i've Bragged on them, Stay Tuned. |
12-17-2010, 03:56 PM | #47 |
Old Skool Club
I've got the Edelbrock and Q-Jet going on with my truck, equipped with an Edelbrock 1901 Q-Jet. Didn't get a chance to vote for both, but having had a 1405 Edelbrock, I shoulda gone with Edelbrock, I suppose. Between the two, I prefer the Q-Jet. Runs leaner and is better on the street, even though it is rated at 750CFM, compared to the 1405s' 600CFM.
This argument will never end, though.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
12-17-2010, 04:22 PM | #48 |
There is nothing like a good setup Q-jet.
12-17-2010, 07:52 PM | #49 |
My Carbon Footprint
.....to keep the shop door open in the summer!!!! Sorry....Imma sore loser!
12-17-2010, 08:21 PM | #50 |
just got 15 mpg out of my 454 with a q jet.
