12-21-2010, 01:54 PM | #26 |
needs more $$$
Re: No Limit '72 C-10
I personally like the stock bench, nice and comfy. Don't know about trying to take hard corners in a bench seat though. The only thing I would do to it is cut the legs down a little so it sits lower for more head room.
1970 2wd Blazer |
12-21-2010, 03:32 PM | #27 |
Tot Roddin'
Buckets... or the stock bench IMO.
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
12-21-2010, 03:36 PM | #28 |
67-72 parts collector,…
The 88-94 seats (remove the head rests) are perfect except the stock seat mount needs to be "angle cut" to kick up the front a little.
They seem to work fixing the height and depth problems of the stock seats. Otherwise,... I'd use a stock bench, with shortened seat mounts, for head room.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 12-21-2010 at 03:37 PM. |
12-21-2010, 06:22 PM | #29 |
dazed and confused
not to hi jack, but what would be the best way to shorten the stock mounts?
members met: redbaron69, billsbowtie,nc67 |
12-21-2010, 06:50 PM | #30 |
If you go with 99-up seats, they have integrated seat belts, but they're kinda tricky to make look "just right".
However, a stock bench can be made to look good and still be somewhat "supportive". I need to have the seat brackets lowered and some good 3-point belts in my truck though.
12-21-2010, 07:09 PM | #31 |
This sounds great - I am interested in what you are doing for the seats as well - I am 6'3, and I have not determined my seating arrangement yet
Best Regards, Leon 1970 C/10 LWB Cummins Turbo - Build in Progress Many other toys as well... |
12-21-2010, 10:01 PM | #32 |
Eat, Sleep, Drive a Chevy
ok, ok lets see some updates already
Trey Silence may be Golden, but Duct Tape is Silver! 72 Short Step 57 "big window" short step |
12-22-2010, 02:38 AM | #33 |
88-98 bench would be top choice for seating. Readily available & usually @ a decent price (if not free). Low/no hassle bolt-in. Easy fab work for the height adjustment as Lolife described.
The end years of the production run had each seating position 'formed' into the seat foam which would be better once you start killing cones .
12-23-2010, 02:47 AM | #34 | |
'69 Chevy SWB
i gotta get in on this one. If it turns out like any of the other trucks for your shop, it will kick a$$!!
X2 on the 88-98 benches , I have one in mine with the built in arm rest and I love it.
Matt '69 Chevy SWB Fleet, Primer Black; Project No Name '06 Chevy Trailblazer, Blueish Silver?; Wifes DD, Sold '08 Chevy Impala SS, Silver; the new DD, AND IT IS FUN!!! '99 Dodge Dakota R/T, Intense Blue; DD, Sold Quote:
12-23-2010, 03:45 AM | #35 |
As far as seats go, I guess it depends on what you plan on doing with the truck, I've seen a lot of built up and tricked out shop trucks. If you are planning on putting a suspension that handles (I know you will), then a bench seat might not be the best choice to keep you in place in the corners. I've got one of those stock benches in mine and even modest corners and I am sliding around. I also am going to be getting rid of that bench for a 60/40 slit with head rests, I just don't like the idea of the back glass being the first thing my head hits in an accident.
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961 Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583 |
12-23-2010, 07:23 PM | #36 |
Rob....good to see you building a chevy.....finally!! Go for the 67-68 buddy buckets, super comfortable for a driver and work pretty well at keeping you put in the seat. And they should work ok for your 6'2" physique! You should put the 72 grille back in it, looks way better than the 69-70 grille it has in it. I have a rebuildable 5.7 ls1 all aluminum v8 if you want it..$600 it's not mine but I have it at the shop. And if you want something really cool I have a 6 sp auto out of a 09 Cadillac CTS-V, which we bought and couldn't use. Give me a call I have a ton of stuff for that truck!
Posted via Mobile Device Last edited by PCHRODS; 12-23-2010 at 07:25 PM. |
12-23-2010, 07:28 PM | #37 |
Oh....save me the clutch pedal assembly. I need it for a project!! Call me!!
Posted via Mobile Device |
12-23-2010, 11:01 PM | #38 |
Thanks, got any of those seats around? clutch pedal is yours. wait till you see the next pict - wow! Ohh, Merry Christmas to you and you family.
12-24-2010, 09:37 AM | #39 |
PCHRODS, what kind of seat do you have? If you didn't live on the other side of the country, I'd take that engine/trans. off your hands.
Rob, those buddy buckets aren't too hard to find, but they're usually pricey when you find them. They would look pretty sweet though.
12-24-2010, 09:56 AM | #40 |
Rob I put a 88/98 60/40 split bench in my 71 GMC about six months ago and that is one of the better moves I made but you would most likely need to section the seat bases to get it a bit lower for you. Good back support for the driver and the truck will still haul three people when you need to. I think the standard cab seats may have a bit thinner backs than the extended cab seats though.
12-24-2010, 10:06 AM | #41 |
Old School
Subscribed
#1 Project...69 Chevy swb Fleetside (Dad's truck) #2...1983 El Camino SS (Choo Choo Custom) #3...1974 Datsun truck (4.3L V6/4L60E) #4...1951 Cadillac Limo (1975 Caddy running gear) #5...1938 Dodge M38 3/4 ton Military truck #6...1968 Sportster XLCH trail bike 5 GMC & Chevy parts trucks 68 to 72 Last but not least; My 1978 Harley Davidson Electraglide (trusted & reliable companion for the last 30 years) |
12-24-2010, 10:38 AM | #42 | |
12-24-2010, 12:33 PM | #43 |
New Member
Here is my .02 worth, stay with the bench from the late 80's/early 90's. If you're sliding around put suede insert to keep your butt more planted.
Certain year models had a fold down arm rest built in. I'm guessing but I think it was 1993?
My Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=366351 Last edited by ctrow; 12-24-2010 at 12:34 PM. |
12-24-2010, 01:17 PM | #44 |
Ctrow, that looks pretty good, I like it re-covered with the 50/50 look. fits the truck nice.
12-30-2010, 01:34 PM | #45 |
Registered Cruiser
Definitely checkin this one out!!!
12-30-2010, 01:48 PM | #46 |
Junk Yartist
When I bought my Burb it had a 2005+ base F250 bench in it... It was nice but I ditched it because the back was too high. I will be using a 73-91 Suburban/truck bench because the mounts are shorter from the floor kick up... I have the same height issue.
Second, if your first post it looks like the exhaust manifolds are GLOWING! I can do that with the sequential turbo setup on a cummins (QSK60), but WOW!!
-Jeremy YOU ONLY FAIL IF YOU STOP TRYING 70 Crew Cab Build Link 70 GMC Suburban 4X4 build thread 95 Yukon Daily Driver Rebuilding an NP205 |
12-30-2010, 02:07 PM | #47 | |
subscribed
1965 GMC shortwide big window 1969 Chevy C20 long (for now) 2005 Silverado 2500HD Crew Cab Quote:
01-02-2011, 12:45 PM | #48 |
nice project, U got something to work with & good luck
01-02-2011, 02:32 PM | #49 | |
Grand PooBaa Member
Also, you do know any custom pieces you guys at No Limit make for the C-10, your going to have to make extra to sell to us. LOL And im in. Last edited by VDOG; 01-02-2011 at 02:32 PM. |
01-02-2011, 03:02 PM | #50 |
im in....cant finish mine,might as well watch someone else have all the fun....
Tags |
1972 chevy, c-10, no limit engineering |
