Old 01-24-2013, 12:04 PM   #26
Cracksrubi
Cracksrubi's Avatar
Re: 6L80 swaps
Nice score btw that combo should make sure you have plenty of motivation under the hood
68 c-10 lwb
Cracksrubi is offline   Reply With Quote
Old 01-24-2013, 12:17 PM   #27
Hart_Rod
Hart_Rod's Avatar
Re: 6L80 swaps
Originally Posted by Cracksrubi View Post
No way to tell cause if you find a shop that will swap just the shaft it could be pretty cheap but I'm pretty sure with having it for down there gonna say it needs a rebuild to be safe
It only has 135 miles on it.....
I also have a TVS1900 Magnacharger to put on top of the motor.....
Hart_Rod is offline   Reply With Quote
Old 01-24-2013, 12:23 PM   #28
Billett
Billett's Avatar
Re: 6L80 swaps
That's going to be one hell of a truck. Post a link to the build here, I really want to follow some of the info for this swap. I've seen a couple combos on ebay, but I just can't pull the trigger right now.
Will
1968 C10 - Project Texa Go 6.0/4L80e
2003 Mitsubishi Lancer Evolution
2002 Ford Excursion 7.3L
2024 Toyota Sienna
Billett is offline   Reply With Quote
Old 01-24-2013, 12:28 PM   #29
Hart_Rod
Hart_Rod's Avatar
Re: 6L80 swaps
http://67-72chevytrucks.com/vboard/s...d.php?t=358692
Old 01-24-2013, 12:31 PM   #30
Billett
Billett's Avatar
Re: 6L80 swaps
Thank you! that should last me the whole weekend haha
Will
2024 Toyota Sienna
Old 01-24-2013, 01:18 PM   #31
Hart_Rod
Hart_Rod's Avatar
Re: 6L80 swaps
Pretty sure tranny shop cause from what I gather you have to change the input shaft that everything rides on
I think I found my answer:
http://www.driveshaftshop.com/domest...ece-driveshaft
$700 for a new 3.5 aluminum driveshaft that takes care of the conversioin with no need to mess with the transmission!!!!!
Old 01-24-2013, 02:02 PM   #32
thor
thor's Avatar
Re: 6L80 swaps
This certainly is the easiest option versus tearing into the tranny just to swap output shafts. Nice score on that combo BTW!!!
1972 Chevy Blazer CST.....Project: Polished Turd
thor is offline   Reply With Quote
Old 01-24-2013, 04:23 PM   #33
Cracksrubi
Cracksrubi's Avatar
Re: 6L80 swaps
Agreed on the driveshaft and sorry bout the 135 miles I miss read and thought 135k not 135 period that really is a good score barely even got out of dealership
68 c-10 lwb
Old 01-24-2013, 05:29 PM   #34
Hart_Rod
Hart_Rod's Avatar
Re: 6L80 swaps
Thanks!
No worries .
Old 01-29-2013, 08:33 PM   #35
namyzzo
Post Re: 6L80 swaps
I've got a 6.2/6L80E out of a 2013 Camaro SS. It's got the funky looking triangle output shaft on tranny. I need to convert it to a slip yoke style like the 6L90E's. I found a kit that provides the necessary parts to do the conversion, but I have been unable to find anything talking about doing the actual swap. Can you DIY or does it have to be done at a transmission shop? Thanks in advance.
Rob
>work at a driveline place...Can you get some specs of that "tri-bolt" companion flange? or maybe part with it?..Would like to check the specs of the flange and see if danamate.com has any normal slip yokes near your specs (internal spline count/spline major diameter, ground hub diameter..etc..) = would be nice to know if theres any easy options..
iv'e seen a few of these "kits" on the net..From bolt on adapters to output shaft swaps!
What kinda of conversion kit did you purchase/where from? It appears by "taking it to a trans shop" - that maybe your "kit" changes the output shaft?
...Just trying to get more knowledge about these newer trans/transfer cases...So much conflicting information out there...
>>> Ha - just got my account approved - now I see the kit your going with!... sounds like an easy choice... Would have loved to know what that flange spec'd out at..
Oh -well...if anyone else get the opportunity - would like to hear what they find out..
Thanks guys!
namyzzo is offline   Reply With Quote
Old 01-30-2013, 10:49 PM   #36
Hart_Rod
Hart_Rod's Avatar
Re: 6L80 swaps
Thanks guys!
Take a look at t his thread. It has all the specs that you are talking about and better explanation than I could give you, .
http://ls1tech.com/forums/automatic-...slip-yoke.html
Old 11-27-2015, 08:52 PM   #37
Leeforbes
Leeforbes's Avatar
Re: 6L80 swaps
Just received my 6L80e for thanksgiving! I will add pictures as I drop it in over the coming month.
My 1966 C10 short Bed Fleet Project.
Build Photos
Accessory Drive System I used
Leeforbes is offline   Reply With Quote
Old 11-30-2015, 05:27 PM   #38
Tom
driving is in my blood
Tom's Avatar
Re: 6L80 swaps
Until they make a decently priced stand alone unit to control this trans and not do a LS swap this trans is a no go for most people. I don't think you can call it just a trans swap when it required a new engine to go with it.....
Old 12-02-2015, 05:51 PM   #39
Leeforbes
Leeforbes's Avatar
Re: 6L80 swaps
Just ordered this conversion kit to switch from 4WD to 2WD with a slip yoke. Thought I would share the link. $350 for the kit...
Build Photos
Old 12-02-2015, 09:57 PM   #40
clinebarger
Re: 6L80 swaps
Are you going to do this yourself? If so....Get prepared for the Center Support snap ring......It is the stoutest snap ring I have ever ran across!
clinebarger is offline   Reply With Quote
Old 06-10-2020, 11:54 PM   #41
Chvy2NV
Re: 6L80 swaps
good info here, subd
Chvy2NV is offline   Reply With Quote
Old 06-15-2020, 01:18 AM   #42
toolboxchev
Re: 6L80 swaps
So I have a question. Drove a truck with that combo while back kinda remember a lag when hitting the throttle with towing a load.
Do this sound familiar? If so, would a custom tune on it bring about more responsive changes?
Posing the question, yeah it may not matter.
toolboxchev is offline   Reply With Quote
6 speed, 6l80, 6l90, swap, tranny
