Old 02-05-2012, 11:16 AM   #26
ChevyTech
Re: 88-98 FAQ's "Is your truck running weird? Check here it could help"
Axle ratio by RPO codes.
http://67-72chevytrucks.com/vboard/s...ight=RPO+codes
http://67-72chevytrucks.com/vboard/s...67&postcount=3
Monitoring open or closed loop status on OBD1 vehicles:
http://67-72chevytrucks.com/vboard/s...4&postcount=13
Heated O2 senor upgrade & heated air intake.
http://67-72chevytrucks.com/vboard/s...3&postcount=12
http://67-72chevytrucks.com/vboard/s...=heated+sensor
Mismatched injector on 1987 4.3L light duty truck engines.
http://67-72chevytrucks.com/vboard/s...87&postcount=4
These two long threads cover most problems that can happen with the TBI fuel system trucks.
4 page thread on TBI diagnosis.
http://67-72chevytrucks.com/vboard/s...d.php?t=348308
3 Page thread that EGR fixed.
http://67-72chevytrucks.com/vboard/s...d.php?t=347247
Stalling - Code 54 – Thread covers Fuel relay & oil switch for fuel pump.
http://67-72chevytrucks.com/vboard/s...d.php?t=495054
No fuel – burnt fusible link – code 54
http://67-72chevytrucks.com/vboard/s...d.php?t=460116
Checking OBD1 computer codes without a scan tool.
http://67-72chevytrucks.com/vboard/s...5&postcount=11
V8 Vortec distributor installation & code 1345
Thanks to bwood
http://67-72chevytrucks.com/vboard/s...ighlight=P1345
Old 02-05-2012, 11:52 AM   #27
scotts62
One day...
scotts62's Avatar
Wow, good ones there, thanks chevytech
Scott
93 crew cab build
Project 62
Old 02-13-2012, 05:33 PM   #28
ChevyTech
Thank you Scott!
Here’s another one:
Thanks to bwood
Old 11-08-2012, 02:04 PM   #29
Keith Seymore
Keith Seymore's Avatar
Excellent thread; subscribing -
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Keith Seymore is online now   Reply With Quote
Old 01-23-2013, 11:36 AM   #30
ChevyTech
How to set the timng on 1988-1993 C/K trucks:
http://67-72chevytrucks.com/vboard/s...85&postcount=4
In 1994 the connector was moved inside the cab next to the computer.
On the square body TBI trucks the connector is by the brake booster.
Old 02-12-2013, 10:04 PM   #31
butternut1972
butternut1972's Avatar
Great info chevytech. I have a question for you, I have a 98 W/5.7, 4WD, 1/2 ton. The problem is it stumbles at higher speeds when climbing an incline. Example-Driving on the highway at 70 and start to go up a hill it wants to stumble/shake as its trying to downshift. This happens whether I'm pulling or not. Your help is appreciated.
1972 GMC (PROJECT LONG OVERDUE)
1998 SWB 4WD
butternut1972 is offline   Reply With Quote
Old 04-27-2013, 10:47 AM   #32
dragginmetal
here, just not logged in
dragginmetal's Avatar
1998 k3500 7.4
wiring diagrams
http://67-72chevytrucks.com/vboard/s...d.php?t=577359
dragginmetal is offline   Reply With Quote
Old 06-05-2013, 07:25 PM   #33
Enginebuilder
Testing of the 88-95 EGR system:
http://67-72chevytrucks.com/vboard/s...d.php?t=583327
Enginebuilder
(Eric)
1995 K2500 w/5.7 & A/T
Alaskan Members Check In
http://67-72chevytrucks.com/vboard/s...22#post5094422
Enginebuilder is offline   Reply With Quote
Old 10-10-2013, 01:21 PM   #34
FrankieD
FrankieD's Avatar
I didn't see this any where. So a a few years ago I replaced the 350 in my 95 K2500 PU with a 350 from a 88 K1500 Suburban after I got it all together and drove it the Trans didn't shift right and before the swap I had no problems with the trans so I started swapping all the electronics and sensors from the 95 350 and still no good. I only had one more thing that I could change and that was the Knock Sensor which I didn't think could have anything to do with the trans. After changing it the trans shifted fine turned out the part number of the sensors were one number different. Hope this helps somebody doing the same swap.
94 k2500 EXCab Long Bed 350ci New Toy
95 K2500 Suburban New PlowTruck 454ci
Support our Troops @ http://anyairman.com
http://www.woundedwarriorproject.org/
FrankieD is offline   Reply With Quote
Old 12-09-2013, 12:05 AM   #35
Dirty South 504
I have a 95 c 1500, 350 5.7 TBI I am having problems with the truck starting sometimes.Engine wants to turn over,but doesn't until I pump the gas pedal a few times then the engine starts and runs.Fuel or electric issue? Or both?
Dirty South 504 is offline   Reply With Quote
Old 01-12-2014, 09:31 AM   #36
dragginmetal
Identifying Drop Spindles & How to cut Coil Springs.
http://67-72chevytrucks.com/vboard/s...21#post6466621
Old 03-29-2014, 09:21 PM   #37
oldmans88
Just got my 1988 Chevy Silverado 350 auto tranny 196000 miles. Seems to run good but in drive with brake on, oil pressure drops to almost 0. I am the 4th owner, 2 older men and an older woman.
oldmans88 is offline   Reply With Quote
Old 04-11-2014, 07:31 PM   #38
Drewkimble48
I have found 2 websites that could be helpful at times and kind of gives a break down on a lot of different components.
www.aa1car.com
www.2carpros.com
Drewkimble48 is offline   Reply With Quote
Old 07-23-2014, 06:48 AM   #39
bufmatmuslepants
Junior Member
Stumble only at idle yet normal power everywhere else? Black smoke from the exhaust when you stab the throttle after idling for a few seconds? Do the paper on the exhaust pipe trick, if it gets sucked in, most likely an exhaust valve not sealing, could be a burnt valve, stuck open from carbon, or in my case, a bad mechanic lashed the exhaust valve too tight. The low rpm does not allow the cylinder to build enough pressure to ignite the fuel, at higher rpm the increased piston speed moving the air faster builds enough pressure before it can leak out the exhaust valve to ignite the fuel, hence only the stumble at idle.
http://67-72chevytrucks.com/vboard/s...d.php?t=635082
1979 K10 reg cab short bed 33x12.50s - GONE
1988 4x4 reg cab long bed 337k miles - GONE
1995 Z71 GU6 G80 F44 ext cab short bed 149k 305/70/16s - GONE
1995 NZZ GT4 2dr Tahoe 3" lift 14 bolt sf 155k 305/70/16s - GONE
1994 Z28 M6
1995 Z71 GT4 G80 ext cab short bed 215k GONE
1997 GT4 G80 Yukon 4 door leather, sunroof 168k miles GONE
2003 Avalanche Z71 GT4 G80 165k miles
bufmatmuslepants is offline   Reply With Quote
Old 10-31-2014, 02:25 PM   #40
68C15
blood type; Retumbo
68C15's Avatar
Re: If you remove the distributor from a First Gen. Vortec engine
Originally Posted by speedygonzales View Post
If you remove and replace the distributor in a generation I Vortec engine, it's correct position must be checked by scanning the cam retard number. According to GM it's referred to as the Camshaft Retard Offset Adjustment.
Here is the shop manual page for it.
http://carphotos3.cardomain.com/imag...arge.jpg?modal
The timing of a Vortec is not adjustable but the position of the distributor must be at a reference point of 0 degrees +- 2. This will have an effect on idle quality and fuel economy at least.
We know without doubt that a Snap-on Solus, Solus-Pro and Modis will show the cam retard value. Others may, but I'm not aware of them.
Just to let you know, mine was reinstalled without checking the cam retard going back as far as 2005. I was careful to reinstall it each of 3 times doing the intake gaskets. It never gave a code after the install. The last time a week ago after a complete rebuild, it was at -13*. Never had a code.
Now here's one thing you won't read in any shop manual.
Once I got it to 0, in no time it threw a code 1345. Let me repeat that. I was off for over 6 years and never threw a code. After I set it to 0, it threw a code.
My recommendation comes from others that have experienced the same thing. Set it slightly negative. The spec is +-2 away from 0.
Again I want to repeat for people using "google" looking for this information. If you remove and replace the distributor in a generation I Vortec engine, it must be checked by scanning the cam retard number.
A crank position relearn should have taken care of that. But I find they run best with -4 degrees
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 11-05-2014, 09:04 PM   #41
Drewkimble48
For you TBI guys, I found a great website that shows you how to test sensors and breaks down what things to check for certain symptons your vehicle is having.
http://www.tbiparts.com/techinfo.html
Old 11-23-2015, 04:11 PM   #42
Big Ugly
I am having a few things going on with my 96 Sierra SLE 5.7L 1500 ECSB. First, my gas mileage has dropped off considerably in this past year. I was getting 15 around town, 19 on highway now it is 12.5 city, 17 highway. I have a slight stumble at idle when the engine is 'hot' (more on that later) but no engine codes are thrown for O2 sensors. My scan tool picks up nothing.
The 2nd thing weird is that the temp gauge reads at 120*. I have switched both temp sensors, but nothing is making a difference. Is there any way to test the actual temp of my truck if the gauge is off?
Any help will be most welcome.
Big Ugly is offline   Reply With Quote
Old 04-24-2016, 11:01 AM   #43
ChevyTech
TBI (Throttle Body Injection) powered trucks, common problems.
In one spot, as short as I could make this post.
It is common for the gasket under the TBI unit to leak vacuum causing idle issues.
The throttle shaft can wear the housing creating a vacuum leak on the driver’s side of the TBI unit.
Testing the fuel pressure is a good idea if the idle is erratic or poor. I wish they would have put fuel pressure test ports on these trucks. The fuel filter, fuel pump, fuel pressure regulator (broken spring) and the rubber that connects the fuel pump to the sending unit are all possible causes of low fuel pressure. Low fuel pressure on these TBI trucks shows up as a poor erratic idle, and slow – hard starting, and just because it runs ok on the the freeway under heavy throttle you should not think it has good fuel pressure.
On these distributors the housing/upper bushing area gets so worn out that the shaft will move sideways so far that the points on the pickup coil pole piece get hit by the reluctor points on the shaft. When this happens the ECM receives compromised signal for RPM and timing issues. These distributors can also have problems because of loss of magnetism needed for the pickup coil to work, which cause more problems at low RPMs. If the magnetic material is cracked in pieces you should replace the shaft or the entire distributor.
Distributor modules are a common failure part. They can fail as they heat up. They can fail causing a no start, because of no spark. They can cause the injectors to not get triggered by the ECM even if there is spark. Or they can fail causing all kinds of poor running conditions. Many parts stores can test them. Make SURE you use heat sink compound under the module when you install it, or heat made in the module can't get dissipated and will destroy the module. Many replacement modules fail VERY quickly.
A bad TPS can make it so that the ECM does not know the correct throttle position and the ECM will not move the IAC. A TPS that shows wide open throttle can cause a lack of fuel for starting the engine because the system goes into the clear flood mode and cuts the fuel injected.
Coolant sensor failure on the sensor the the computer uses to set the mixture can cause the mixture the engine gets to be wrong. The most common problem it causes is a mixture that is too rich.
EGR valves can get carbon chunks holding them open. They can also drag on one side of the plunger and catch, sticking open at times. The EGR solenoids can also leak vacuum to the EGR valve at idle. If there is ever vacuum getting to the EGR at idle, unplug the electrical connecter to rule out an electrical problem, and if there is still vacuum getting to the EGR valve at idle replace the EGR solenoid. The solenoids can suck dirt in and stick.
The most common EGR system on the light duty TBI trucks is a “Negative Back-pressure” EGR system in which the EGR valve itself modulates the EGR opening. This system is very picky about the EGR valve operation and low quality replacement EGR valves can cause drive-ability problems that people are unable to find the cause of.
A common condition caused bad a bad EGR valve is a hesitation, or flat spot, at light throttle acceleration.
The TBI trucks from 1987 to 1995 are the OBD1 system and the computer trouble codes can be read without a scan tool. All you need is a paper clip.
You must unplug the set timing connector (wire) to set the ignition timing on these trucks, and if you don't the timing will be wrong. This will set a trouble code.
As these trucks age head gaskets leaking between the cylinders is a problem. As the head gasket fails, often the first symptom is pinging, and sometimes it causes a trouble code caused by high knock counts.
The none-roller lifters used in these engine along with the changes in motor oil removing ZDDP has shown up in the number of flat cam lobes on high miles engines.
Trying a different brand of gas is another thing you can try. It has been my experience that the TBI trucks do not idle as well on ethanol fuel and as they raised the ethanol content this was noticed by many people.
With a search you should be able to find discussion on all these topics in old threads.
Old 08-09-2016, 09:22 PM   #44
T_RAV
Hey guys, I have a 97 Sierra 4.3L V6. It idles just fine and under acceleration runs just fine but, at a steady pace, no matter the speed, it kicks/bucks/jerks and has actually backfired once. Always has since the day I bought it. I did notice when I was doing a tune up recently, there is a small chip in the base of the platic distributor where the cap seals to it....could this be my problem? I bought a distributor from a local junk yard but haven't put it on yet.
Any suggestions?
T_RAV is offline   Reply With Quote
Old 10-02-2016, 05:28 PM   #45
Chevyaz
Ive found out more great information on this thread dam. Very good job. Thanks very much. Brand new to this forum.
Chevyaz is offline   Reply With Quote
Old 10-29-2016, 03:12 AM   #46
98extracab
My friend has a 94 5.7 and at around 1500 rpm or so and deceleration it hesitates/bogs and has a code 43. We had recently changed the motor out because it was knocking and it ran great until about a week after and started having these issues. From what I read on the egr failure it seems more like that. He still has his old egr valve and will be throwing it on since there were no codes when that engine was in. But I was just wanting an input to see if that may be the issue.
98extracab is offline   Reply With Quote
Old 10-29-2016, 10:28 AM   #47
Chevyaz
Thats great information. Good work.
Old 11-14-2016, 12:44 AM   #48
diveplane
Originally Posted by mountie View Post
The wiper delay-pulse module and the motor they show doesn't look anything like my '88 GMC C2500......
WHO has the correct one? They claim it is for an '88, but they are wrong.
this was one of the known issues on the trucks newer boards are built better replacements today, i fixed mine.
diveplane is offline   Reply With Quote
Old 11-14-2016, 12:50 AM   #49
diveplane
whats the part number for the sensor sends a signal to temp gauge in dash
i think mine is reading wrong temp
i know theres 2 temp sensors in the engine block right v6 vortec 1994,
i have 2 new radiator hoses to replace and thermostat , also want to replace this sensor.
thx in advance.
Old 11-16-2016, 06:27 PM   #50
mountie
mountie's Avatar
Yea..... this post is a tad old from me... I replaced my wiper motor with the later design. It swapped easily. Same bolts, attachments, etc. Works perfect.
Even the harness plugged into the newer motor.
'70 GTO Midnight Blue
'88 GMC Sierra SLE 392,000 miles-(2018) sold to Classic car shop in Germany.
'93 Cadillac STS Black
'93 Mercedes SL 500 Teal
'86 Yamaha FZ750 - 15,000 RPM
'86 Yamaha FJ1200 - Criminally Fast
2016 Ferrari 488 GTB, I drive it - don't own it.
'05 GMC Yukon XL , SLT 4wd ( just purchased 2018)
mountie is offline   Reply With Quote
