Old 03-28-2011, 12:26 AM   #26
WigglesTheHoly
IT Guy/ Father/ Chevy lover
WigglesTheHoly's Avatar
Re: 1987 Chevy Long Bed
looks good man. Just saw in your sig you have a 03 sentra. Is it a plain janer or a ser spec v? I had an 04 that I totaled I love those cars.
78 Chevy (Pictures) SOLD
79 Chevy LWB (pasture)
83 Chevy LWB (crushed rusted beyond repair)
02 TrailBlazer SOLD
03 VW Passat wagonSOLD
95 extended cab silveradoSOLD (still in family)
05 Crew Cab Silverado 5.3 (The Turd)
WTB: 66 El camino
Technology Specialist aspiring to be a gear head.
WigglesTheHoly is offline   Reply With Quote
Old 04-03-2011, 10:24 PM   #27
texasbigbear_wink
texasbigbear_wink's Avatar
Ok I am down to making a bracket for the power steering pump. I want to use the bolt holes on the head and I work with water jets so making one is no problem but just having a good designe to go with is the problem. If you have some ideas or pic's please hit me up.
87 Chevy R10 LB
02 Nissan Sentra GXE
texasbigbear_wink is offline   Reply With Quote
Old 04-03-2011, 10:29 PM   #28
texasbigbear_wink
Mr Wiggles its just a 2002 nissan sentra GXE plain but it is a nice car never any problems out of it I am needing to do some service work to it but want to get this truck done first but I am running out of time and need to get it service up soon.
87 Chevy R10 LB
Old 04-07-2011, 10:36 PM   #29
texasbigbear_wink
I hope to have this truck running by saturday at the latest.
87 Chevy R10 LB
Old 04-15-2011, 08:55 PM   #30
texasbigbear_wink
Sorry but I have to put the truck on hold for a bit. I need to take care of some other things first.
87 Chevy R10 LB
Old 02-10-2012, 10:34 PM   #31
texasbigbear_wink
My new tires and rims! 18x8 with 255/55/18 front and 18x9 with 275/60/18 back. We Started working on it again. We will be dropping the front 3'' with drop spindles and doing an axle flip to the back. I will add pic's as we go.
87 Chevy R10 LB
Old 02-13-2012, 11:40 AM   #32
Desert1957
Desert1957's Avatar
Here are 2 pics off my 83 Power Steering Bracket , If you have factory A/C you should have this bracket laying around somewhere.
I have an 87 Non A/c Truck also if you need pics of the OEM bracket
Desert
Desert1957 is offline   Reply With Quote
Old 02-13-2012, 11:44 AM   #33
Desert1957
Desert1957's Avatar
There is also a space about 3/8" thick that goes here
Desert
Old 02-20-2012, 11:39 PM   #34
texasbigbear_wink
Thanks Desert I have took a different rout. Pics to follow.
87 Chevy R10 LB
Old 02-20-2012, 11:53 PM   #35
texasbigbear_wink
I have went with a used serpentine kit I pulled off a 95. We also have installed 3 inch drop spindles in front and I made the brackets and flipped the rear axle but now the back is lower than the front. I was looking for it to level the truck out. I have 18x8 255/55/18 in front and I think 18x9 275/75/18 in the back. I think the leaf springs are worn flat out because the axle is know 2 3/4 inches from the frame. Not sure what I am going to do about this yet. I don't want to lower the front anymore than it is so the back needs to come up. Let me know if ya'll have any info or pic's on resolving this.
87 Chevy R10 LB
Old 02-20-2012, 11:59 PM   #36
texasbigbear_wink
The back after the axle flip.
87 Chevy R10 LB
Old 02-21-2012, 12:03 AM   #37
texasbigbear_wink
This is the Serpentine Kit installed.
87 Chevy R10 LB
Old 02-21-2012, 12:09 AM   #38
texasbigbear_wink
This is the flip brackets I made at work if you need the prints they are in the forums or I could email them to you just PM me.
87 Chevy R10 LB
Old 02-21-2012, 05:49 PM   #39
Desert1957
Desert1957's Avatar
Nice!!!!
Old 02-21-2012, 05:51 PM   #40
Desert1957
Desert1957's Avatar
Looks Great , Did you measure before and after to see exactly how much drop?
Dez
Old 02-21-2012, 09:10 PM   #41
texasbigbear_wink
No Dez I did not. I should have. The drop spindles on the other hand brought the bottom of A frames at ball joint point down from 9.5 to 6.5 inches from the ground. I added new stock springs to the front before I decided to drop the truck.
87 Chevy R10 LB
Old 02-21-2012, 11:29 PM   #42
Telecasterjoey
How'd you get the control arms so clean? Sandblast? Looks awesome!
Telecasterjoey is offline   Reply With Quote
Old 02-22-2012, 12:35 AM   #43
threeonthetree
threeonthetree's Avatar
this thing is sick!
did you modify the intake to fit on those heads?
because of the horizontal center bolts they dont work with older intakes. what intake number is this?
threeonthetree is offline   Reply With Quote
Old 03-11-2012, 12:26 PM   #44
texasbigbear_wink
Telecasterjoey.. I just sandblasted them and then painted them. Sorry so late on reply.
87 Chevy R10 LB
Old 03-11-2012, 12:30 PM   #45
texasbigbear_wink
threeonthetree... this is the link to the one I got http://www.summitracing.com/parts/EDL-3704/ there was no modifying because my motor was a 87-95 tbi 5.7 The 87 chevy truck was the first year for tbi so mine was ready to go.
87 Chevy R10 LB
Old 03-11-2012, 12:33 PM   #46
texasbigbear_wink
Some pic's after we added the serpentine belt kit off a 95.
87 Chevy R10 LB
Old 03-11-2012, 12:46 PM   #47
texasbigbear_wink
2 more pic's
87 Chevy R10 LB
Old 03-11-2012, 01:02 PM   #48
texasbigbear_wink
The 87 first time running.
http://youtu.be/zZusRCuQC7k
87 Chevy R10 LB
Old 03-11-2012, 02:19 PM   #49
terryj
Just one suggestion, if your going to run Headman headers you might think about a heat shield for your starter, those headers can heat that starter up pretty quick.
terryj is offline   Reply With Quote
Old 03-11-2012, 09:21 PM   #50
texasbigbear_wink
Terryj--- Thanks for the heads up. I have not pictured it yet but we have installed a Mini Hi-Torque starter that should hold up to the heat from the headers. The one pictured is a stock one and yes I agree it would not hold up to the heat.
87 Chevy R10 LB
