11-19-2016, 02:31 AM | #26 | |
Re: 68 C10 Yellow wire from firewall to starter/coil.
That cloth wire does not go into the fuse box on the fire wall, it is broken. The green wire you have pictured is melted from the inside out, I traced it to a sensor in the block on the driver's side. I am wondering what happened. |
11-19-2016, 03:18 AM | #27 |
Msgt USAF Ret
The cloth covered wire is the ignition wire from the key switch to the coil (OEM)
It comes into the cab through the firewall terminal block behind the fuse panel and becomes a pink wire which runs to the key switch after teeing with two other pink wires as shown in the first diagram and then the second. The green wire is the temperature sending wire which goes to the key switch if you have the idiot light dash, and then to the dash cluster to the no. 5 pin on the cluster plug. If you do not have the idiot light dash but have the gauge dash then the green wire goes to pin 6 on the cluster plug and then to the temperature gauge in the dash. It sounds like this wire may be shorted to a hot wire at some point since it is grounded through the sender to the engine block. Look at the two diagrams and on the lower left you will notice the firewall block and the pink ignition wire coming out of it in the top section. Follow this wire up to the tee and on up it turns right and heads to the ignition switch. Just to the left of it is the green wire for the temperature sender. and below it in the second diagram. Again this wire goes to the dash cluster plug if you have a gauge dash. Ignore the arrows, they point to the brown accessory wire which goes back to the fuse panel to power the turn signal flasher, the wiper switch and the hazard flasher.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
11-19-2016, 04:07 AM | #28 |
Awesome. So I guess I don't need to connect anything to the 'R' terminal on the starter with an HEI distributor then.
11-19-2016, 08:38 AM | #29 |
Msgt USAF Ret
Yes that is correct. VV
11-21-2016, 03:57 AM | #30 |
When re-wiring is it better to use thick strand wire or thin multi strand wire?
11-21-2016, 01:30 PM | #31 |
Msgt USAF Ret
Well most of the current runs along the surface of the wires so the more wires you have the more current can travel through the wire. This is not much of a factor in automotive use as long as you use AWG wire designed for vehicles.
The strength factor may come into play where movement can cause broken wires and loss of conductivity.I might use a larger strand in that case but I think I would just go with a larger gauge for less resistance than worry about broken strands. Case in point would be the alternator conversion to 100 amp or higher. Then go from 12 gauge to 10 or 8. JMO.
11-21-2016, 01:32 PM | #32 |
Msgt USAF Ret
Hey I'm not just another pretty face you know.
07-16-2017, 12:17 PM | #33 |
So my 1968 GMC 1500 had the old distributor set up, so I go and do the HEI like I have in countless other cars and trucks I have, I run the HEI from the fuse panel and have power to the coil, but can't seem to get any spark, I rebuilt the distributor with all new parts thinking that was the issue and still nothing, could this be a grounding issue? I'm Stumped and about to just reinstall my old set up with a petronix conversion, and yes I ran a jumper from the battery to also see if that was missed power issue and nothing, any ideas? Thanks!
Kelly 1967 El Camino COPO 427 4-speed 1968 C10 Panel 6.0 LS 1968 GMC 1500 Custom (454 in progress) 1969 C10 CST 6.0 LS 1969 Nova |
10-26-2018, 10:52 AM | #34 |
jumping on this thread for some help.
a bit of background - my son was gifted his great grandfather's 68 C20. i'm working with him to improve reliability and safety. it has decades of mickey mouse work and neglect that i'm working through. it hasnt run since we took ownership. i have a Holley Sniper as part of the upgrades. before i install, i wanted to get the motor to turn over (not start). we havent been successful so far due to purple wire not getting 12v at ignition turn. the harness was trashed so i bought a new one from LMC. when i pin the yellow and the purple wires without connecting to the starter, i get the following: yellow - 12v switched. it reads 12v when key is turned to on position. purple - nothing i'm just getting started on troubleshooting. i'm not too worried about the purple lacking power. i need to check the NSS and ignition switch. my concern is around the yellow wire. my understanding is that it receives 12v starter solenoid is engaged. is that correct? any experience here? |
10-26-2018, 08:29 PM | #35 | |
Here is a thread that shows what the resistor wire looks like, and also talks a little about the yellow wire. http://67-72chevytrucks.com/vboard/s...d.php?t=708975 |
04-06-2019, 08:37 AM | #36 | |
05-14-2019, 06:12 PM | #37 |
Still looking for a constant 12 volt with key in RUN position on my OEM 1972 C10. What are the blue and green wires that are labeled #1 & #2 in one of your posted examples? Still trying to marry a 2018 L83 harness with the 1972 key start.
TKX |
05-14-2019, 07:25 PM | #38 |
12 volt with key on:
Easiest: replace the points distributor coil resistor wire at the firewall connector. That wire will then have 12V. http://67-72chevytrucks.com/vboard/s...d.php?t=708975 Easy: connect to one of the IGN UNFUSED terminals on the fuse block. If you need that 12V with key on in the engine compartment, you should run the wire through a hole in the firewall with a grommet. Info on fuse block: http://67-72chevytrucks.com/vboard/s...d.php?t=741245 Last edited by dmjlambert; 05-14-2019 at 07:28 PM. Reason: fix link |
05-26-2019, 11:14 AM | #39 |
This thread is incredible. Tons of good info. Hoping for a little advice on wiring my new V8 and electronic ignition distributor. It’s EI but still has an external coil (I’m running a Pertronix with 1.5 ohm resistance). The dist. has 2 wires, red and black, Instructions just say to wire the red/black to the + and - terminals on the coil.
I understand i can get rid of the white braided resistor wire now that I’m not using points anymore, and the purple wire will still go to the starter solenoid, But I’m not sure how to wire the starter to the coil? Any info is appreciated. |
05-26-2019, 10:16 PM | #40 |
You don't have to. The Yellow 20 wire from Starter to Coil was for starting up after stopping [at the store, say]. The Resistor wire was heated and thus resistance increased -- to not burn up the points -- but the engine would not start with the 7.5 Volts, so the Starter/Coil line was a bypass for restarting when warmed up.
With HEI [and Pertronix] it's unnecessary, as the coil is always supplied with 12 volts.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 05-26-2019 at 10:25 PM. |
05-27-2019, 02:14 AM | #41 |
Hey Dracko, I'm posting here BC I'm having problems with my PM Inbox.
Here's the message I had to crib by hand onto an envelope so the PM system didn't wipe it out after not letting me send. "...Hi Dan, The Pertronix unit works best with a matching Pertronix coil. Ignitor II + Flamethrower II. [Or is it a Hellfire?] EBay vendors are all lying dogs. Don't leave an Ignitor [I] in the switched ON position for long w/o starting engine. It'll burn out. Ignitor II's are immune. I ran an Ignitor II on the 292 in my '68 C/10 Stepside for about 7 years, then I had problems at freeway speeds. Whole engine circuit quit at 60 - 65 MPH -- in gear -- engine cold milling -- no spark. I'd have to cut Ign Sw OFF, then ON, slow to 55 - 50 MPH and pop start in 4th gear. [I think that caused some bent exhaust valve spring issues later.] And always at rush hour with some yuppie jerk uptight on my 6 O'Clock -- wondering why I suddenly slowed down, and using his horn to let me know that I've inconvenienced him. Could've been the extreme desert heat in Southern AZ. Could've been the parts sitting on my shop shelf without AC for years before trying it out. Could've been spiking voltages from a runaway EVR/Alternator. Worked OK at city traffic speeds, but flunked State Emissions. IDK? I emailed a Pertronix' tech rep, and he said 'send it in'. So I did. Never heard back. I went back to Points for over a year. Glad I did not root out my old Yellow 20 or Resistor wires. Then I got an HEI unit for my 292 L6. Chinese dud straight out of the box. No good warranty. Left a scathing review on Amazon for "Assault Racing" but the damn chinks only changed the company name. Still selling junk. I was able to rebuild the L6 billet aluminum HEI distributor body, but now with all AC Delco or other premium US components. Went to a ''low-boy'' remote HEI coil for a Model Year 1977 Chevy C/10 w/ 292 L6. Basically a stock GM HEI. Working good, except last December, without clue or warning it just shut down in traffic. Downtown and on the way to work of course. Killed a day of work. But it was only the ignition module, a $15 part at any auto parts store. After a wild goose chase R+R'ing a perfectly good US-made Carter fuel pump for a Korean one -- we found out it was really an ignition gripe. Changed out the Module with the fresh spare from my glove box, and Bang! It started and purred. Up and running once again. When Pertronix works, they're great. When they don't you're on a long quest for parts. Cheers,Brian
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 05-27-2019 at 02:21 AM. |
05-27-2019, 08:46 PM | #42 | |
Haha thanks for scribing that down Brian! it sounds like you have similar luck as me for time and place of breakdowns...except it isn’t nearly as hot and there’s hardly any traffic up here.
I didn’t pay a ton for my distributor from eBay vendor skipwhite, so it might also be Chinese crap, hopefully find out shortly now that I know how to wire the ignition. I ended up with a Pertronix flamethrower 1 , so that’s good to know about not leaving the key on while engines not running. Sounds like I should keep a spare coil and control module in the glovebox. Thanks again for all the help. Dan Quote:
07-04-2019, 04:04 PM | #43 | |
Still Green but learning
Thx in advance, and now that I am working on getting the truck ready for my son when he turns 16 I will be back a lot more!
-- Cory 71 Cheyenne 10 - SWB, 350, "3 on the tree" AC cab 07 Suburban LTZ 4x4 2010 Acura TL 98 Mastercraft "FrankenStar" 225 27253 UPS/USPS IIOY....nope never was |
08-03-2019, 10:01 AM | #44 |
I think I figured this out, I am going to cut into purple closer to the firewall and run a new wire over to the dist. use that to get 12v to the HEI and see if I can get her to crank. if so I will clean all that up. It looks like the wire to the starter (from the diagrams above) doesn't really do anything.
Cant wait to get her running again, I have missed this truck.
08-03-2019, 11:19 AM | #45 |
08-03-2019, 11:45 AM | #46 |
will read, its not the purple one, thats thecolor on the diagram. once I got the casing stripped back from the bundle I found it is red..
08-03-2019, 11:48 AM | #47 |
The colors of the wire match the diagram. Red is also what you don't want, it is always on and not switched.
08-03-2019, 11:49 AM | #48 |
Excellent post, mine is red at the same spot on that terminal. I didn't realize they were on Pins. If I do it that way I dont have to snip the wire and if I did it wrong its ok. I was going to cut into it and use a but connector.
08-03-2019, 11:54 AM | #49 | |
Now I am confused because the stock diagram from post 2 on this thread shows purple coming out of the FW block, getting resistance and heading to the coil on Yellow. I am yellow at the coil but on my FW block that same position has a red wire coming out. I can put a volt meter on it and check for voltage at ACC and run position, but I dont want to rob that wire from another system that needs it (although I am not sure what that would be)
08-03-2019, 11:59 AM | #50 |
