04-17-2011, 02:37 AM | #26 |
Cruzzzn' Vet
Re: notching when u drop
04-18-2011, 01:33 AM | #27 |
nice thanks alot guys imma post my pictures of my truck tomorrow of my sanding and body work. Im almost done with it next would be matte black paint... YAY! with some aggressive old school cragars 15x8 in the front and 15x10 in the rear... what would be a good size tire for a 15x10 the one it has on there now is a 275/60/15 but it bubbles too much its too streched it looks like one bump will pop it off...
04-18-2011, 01:34 AM | #28 |
Malo83 i also have an 83 shortbed that im working on. what drop amount are you running?
04-18-2011, 08:35 AM | #29 |
6.0 powered square
malo's has a 4-5 with cut coils an flip, he said but looks like a 5-6
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
04-18-2011, 01:53 PM | #30 |
Im thinking of notching for my 5inch flip kit just incase but drilling into the frame doesnt look fun....might try those short bumpstops first.
1979 c30 3+3 dually 1946 GMC |
04-19-2011, 01:05 AM | #31 |
How did malo83 get the 5 inch flip kit in the rear to become a six inch drop and how many coils did he cut on the front i am thinking if i dont like the 3/5 drop to get it to a 4/6...
04-19-2011, 01:14 AM | #32 |
here are pics of build up
04-19-2011, 01:25 AM | #33 |
here are some more i have the bed sanded down already i will post those pics tomorrow
04-19-2011, 01:30 AM | #34 |
here are the cragars i will b running on the truck i bought these for 50 bucks i just need a good set of tires for them. What would be a good tire for the rears since they are 10 inches wide? right now it has a 275/60/15 but its too bubbly looks like its about to pop off cause its too small...
04-19-2011, 03:18 AM | #35 |
Doesnt look like this has been said, but you can drop the rear of your truck 7"s with out a c-notch. However you have to take off the factory bump stop location. And dont plan on hauling a load unless you have an air over leaf system.
04-19-2011, 01:53 PM | #36 |
I keep reading that you don't need a notch with a flipkit, but on my crew project I have had a chance to drive it around a few times and pulling out of parking lots and going over speed-bumps it seems to bump pretty good.
*EDIT* - this is with the c-notch's installed, I guess I didn't make that clear. I get a pretty good bump coming down the backside of a speed-bump WITH THE C-NOTCH INSTALLED. If I didn't have the notch installed, I would be hitting the axle housing with every pebble in the road. I assume I am hitting the bump stops that came with the flipkit (Belltech), but it sems like a pretty rough bump? I know it is a crew, but the rear half of the frame is from a 1/2 ton swb so the shouldn't be an issue. I was told the same thing on my '06 GMC swb when I did shackles & hangers, but it bottomed out on every bump in the road I went over. I had to do a notch on that one for my own sanity...
2009 Honda Fit CfC (bsf 44.9 mpg) 2000 Tahoe Limited 1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below 1991 GMC CrewCab Dually 4x4, just going to fix things up for now 1982/1989 K5/GMC Jimmy 2wd 1987 GMC 1/2 ton swb 2wd Crew (sold) Last edited by kevinr1970; 04-20-2011 at 05:17 PM. Reason: Not clear |
