08-29-2018, 08:09 AM | #26 |
Re: Fuel Gauge not working????
I don't think it's typically a wire. The tank gets grounded through the mounting hardware and brackets clamping it to the cab. You do want to make sure that there is nice clean metal somewhere for the tank to ground to the cab.
1972 C-10 [Boppa's Truck] |
08-29-2018, 12:42 PM | #27 | |
Msgt USAF Ret
Just do the ohms check from tank to cab and from the sending unit terminal to the tank. You may have fried the variable resistor in the sender . I ordered mine from Parts Geek.com and it is amazing. There is a difference between them. The stock units for six cylinders are 5/16ths and the V-8s are 3/8ths inch diameter tubes.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
10-18-2021, 11:56 AM | #28 |
Anyone have any working fuel gauges that they would sell ?
10-18-2021, 05:10 PM | #29 |
I have one out of a 72 C-10. If you want it I will bench test it to verify it is good. $30.00 + shipping. PS it is from a non gauge truck.
10-18-2021, 06:31 PM | #30 |
What’s a non gauge truck
10-18-2021, 09:20 PM | #31 |
Instead of a temp gauge and a amp meter it has idiot lights. The fuel gauge and speedometer look the same in a instrument cluster.
